Chain slipping, tension and chainline seem right ??
Quoted: 157 Post(s)
Liked 17 Times
Hi folks - just built up an older Cannondale 3.0 for my wife. Used an HG90 cassette, 13-30 in what looks like good condition, Shimano 105 (RD1050) RD. Wipperman chain.
The chain is slipping under power on the first 3 upper gears (13t, 15t, 17t). There also seems to be a bit of chain suck on the 13.
The chainline seems to be ok (see pic) and the cogs look to be in good shape (other pic). But when I adjust the RD tension, I get a slight improvement, less slippage. So I would normally attribute the slippage to low chain tension, but the tension feels right. If I remove another link, the RD will be stretched out past normal limits with the chain on on the 30t cog. I have thought to replace the 105 with a wider range derailleur (it's rated for 28t max, though I think this is conservative) so I could remove a link and still have the derailleur handle it. I'm just thinking I'm missing something obvious (?) Or I'm wrong about what I think is right ...
Thoughts? Appreciate any suggestions!
Chainline. Is the cage bent a bit inward? Significantly?
cog wear
cog wear
Quoted: 1819 Post(s)
Liked 1,696 Times
A longer derailleur cage will not allow you to remove links from your chain. If the chain is too short for the big-big combination the cage will not change that fact
Liked 1,696 Times
According to OP: " Used an HG90 cassette, 13-30 in what looks like good condition,"
It is pretty much impossible to tell how worn a cassette is by looking at it. The true test is if the chain slips on some cogs
Likes For alcjphil:
Quoted: 157 Post(s)
Liked 17 Times
Well, the chain is indeed too short for that, and that's why I can't see shortening it even more. But I'm not talking about crossing the chain all the way to extremes (large front to large rear)
Quoted: 2483 Post(s)
Liked 2,955 Times
In at least 9 cases out of 10, skipping on the smallest cogs means that the chain is worn out or the cassette is worn out or both are worn out. Install a new chain; if the skipping persists (which it almost certainly will), install a new cassette.
And get the derailleur alignment checked at a bike shop.
Once everything is squared away, start using the big ring and the middle of the cassette rather than exclusively using the middle or small ring and the small sprockets. The cassette will last much longer.
Quoted: 1438 Post(s)
Liked 1,092 Times
But if you or your wife does choose the big-big (and probably will at some point) combination with a too-short chain you will damage your derailleur and/or frame.
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Have you measured the chain for wear?
The hanger does look slightly bent in the photo.
Quoted: 157 Post(s)
Liked 17 Times
True - and its about as tight as I'd want it as is. I think the suggestion that the hanger is out of line may be the situation - going to check into that and also try another cassette just to check it isn't a wear issue.
Quoted: 157 Post(s)
Liked 17 Times
Quoted: 157 Post(s)
Liked 17 Times
I don't see any significant rounding off on the cog teeth but I know that can be subtle.
the hanger may be slightly bent - will have it checked.
pretty sure the derailleur cage itself is out of line - probably happened when I rebuilt it.
Quoted: 3376 Post(s)
Liked 5,518 Times
And also, RD tension and chain length have nothing to do with a chain skipping on the cassette. Sometime back as an experiment, I installed a new chain on one of my bikes, and didn't remove any links at all. It has massive slack (on the lower chain) when on the small chainring and on the smaller half of the cassette, but functions perfectly.
Quoted: 157 Post(s)
Liked 17 Times
^This.
Quoted: 714 Post(s)
Liked 800 Times
The amount of "tension" the chain puts on the derailleur cage can have a slight effect on the distance from the upper pulley to the cogs, but that can be corrected with a B-screw adjustment. A slack chain may result in slower shifting, but it has nothing at all to do with the chain slipping on the cogs. If the chain is slipping under load, it is definitely a worn cog that is to blame.
Likes For dsaul:
Liked 2,955 Times
Replace the cassette as soon as possible. Riding with a worn cassette can wear out a chain prematurely.
Quoted: 581 Post(s)
Liked 921 Times
if used cassette + new chain = chain slip under load, the cassette is worn.
There may be minor hanger misalignment but the problem is almost 100% definitely caused by worn cogs. If it still slips with a new cassette I will eat my hat.
(I own a hat made out of gingerbread so this is no big sacrifice.)
Likes For ClydeClydeson:
Quoted: 157 Post(s)
Liked 17 Times
