bike shifts down but trouble shifting up
Hi,
Working on an old 18 speed WM bike. It shifts from 1 to 6 perfectly but hesitates on going up from 6 to 5 and 5 to 4. then it works fine the rest of the way.
How do I know if this is the derailleur or shifter?
Thanks
Thanks
Quoted: 1438 Post(s)
Liked 1,092 Times
Being able to upshift or downshift but not both, and being able to switch between the two by adjustment is usually indicative of a cable friction problem. Check/lube/replace your cables, especially the last loop going into the derailleur; don't forget to check under the bottom bracket if it runs there, road gunk tends to accumulate both places..
Quoted: 1935 Post(s)
Liked 2,150 Times
Think about it. You can muscle it from 1 to 6, but to go the other way the derailleur has to supply the force. If the cable is binding more than the derailleur spring can overcome it won't shift.
John
Going from 1st gear to 6th requires no muscle at all and shifts smoothly. it's going from 6th gear to 5 that is the problem-when you are applying force
