SRAM Red GXP crank installation
Old 04-04-18, 04:34 AM
Fort02
Hi,
I'm trying to install a Sram Red GXP crank on a Cervelo S5 2014 with a Wheels Manufacturing Bottom Bracket but I have a hard time compressing the wave washer enough that it's almost flat. The Wheels Mfg installation guide says to add some cup spacer on the non drive side but if I do that, my chainring is rubbing against my chainstay. Should I add spindle spacers instead ? On which side ?
Thanks for the help.
Fort02 is offline
Old 06-21-19, 11:06 PM
Teamprovicycle
Bikes: Specialized tarmac sl2 giant tcx zero
Quoted: 319 Post(s)
Liked 3 Times in 3 Posts
i know you usually add the thicker spacer on the drive side , but if its hitting the frame you might not need one , just the internal ring adapters , but each company deals with gxp in a different way !!!!
Teamprovicycle is offline
speling_champ
Bicycle Mechanics
4
06-21-19 11:04 PM
Fort02
Road Cycling
2
04-03-18 09:14 PM
ethan.g75
Bicycle Mechanics
3
07-07-13 11:57 AM
kblaine123
Road Cycling
3
03-17-13 10:02 PM
hodie21
Road Cycling
8
02-13-10 02:44 PM
