Road tire patch
Road tire patch
Old 06-06-18, 12:23 PM
John9
Road tire patch
Any suggestions for patching a small puncture on a road tire? It's a very small puncture where the tire comes into contact with the road, and most likely from rolling over glass or through a construction zone. The puncture doesn't go all the way down to the tube, so I was hoping i may be able to fix the issue before it gets worse and I have to buy a new set of tires. Bought these Specialized Roubaix Pro tires about 700 miles ago, so they have plenty of life left in them.
John9 is offline
Old 06-06-18, 12:46 PM
pesty
Master Sarcaster
pesty's Avatar
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
In my experience, there really isn't anything good for filling the crack in the rubber and you're just as well off to leave it. I've tried super glue, rubber cement, gorilla glue, none of it really adheres to the rubber, or it gets too brittle to do any good. If you're REALLY worried about it, you could glue a tube patch on it from the under side. I will sometimes slap a tube patch inside my tubeless tires if the same spot opens up frequently, no reason it wouldn't work for a tube setup.
pesty is offline
Old 06-06-18, 01:28 PM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 2248 Post(s)
Liked 82 Times in 48 Posts
Yeah, Shoe-goo or super glue might help, might not, can't hurt.
Once you got the bit of glass or whatever out of there most of the danger of cutting through the casing is gone, but you can try to stop new bits from getting in there by filling it up.
DiabloScott is offline
Old 06-06-18, 01:58 PM
rumrunn6
rumrunn6's Avatar
Quoted: 3191 Post(s)
Liked 216 Times in 168 Posts
got a photo?
rumrunn6 is offline
Old 06-06-18, 02:04 PM
le mans
Steel is real
le mans's Avatar
Bikes: Raleigh Grand Prix 1977. Custom - Record Vortex 8 spd Nexus & Mistral Le Mans 3 spd Shimano. Upgraded Wheeler Crossline
Quoted: 151 Post(s)
Liked 14 Times in 11 Posts
im guessing you could use a vinyl leather repair kit, providing you first clean the surface with acetone so it bonds
or you could patch [tube repair kit] the inside of the tyre if you were worried about it
le mans is offline
Old 06-06-18, 02:15 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 1770 Post(s)
Liked 165 Times in 123 Posts
The big thing is to make sure you get all the glass or whatever out. The likelihood of the cut itself causing any future issues is very small unless the initial cut is quite big. I'd just ignore it. (If you ShooGoo in even the smallest piece of glass, that glass will cause a future flat. Trust me.)
Edit: for smal cuts, I just use a regular innertube patch on the inside of the casing to keep debris out and the tube bulging into the cut. Larger and I use structurally strong casing patches from Dacron sailcloth (but that calls for another thread).
Ben
79pmooney is offline
Old 06-06-18, 02:29 PM
dwing
Quoted: 80 Post(s)
Liked 3 Times in 2 Posts
I've used Shoe-goo after pulling out metal shards & glass from a tire. I would like to believe it helped prevent small grit from getting into the hole making it bigger and/or puncturing the tube, but, I have no proof other than I never flatted due something getting into that exact same spot.
I think the few flats I've experienced were result of the shard passing all the way through the tire case touching the tube on the ride it was picked up on, or, on subsequent rides where I didn't inspect and pull out shards before the next ride(s) and it worked deeper until it hit the tube.
dwing is offline
Old 06-06-18, 02:31 PM
woodcraft
woodcraft's Avatar
Quoted: 1085 Post(s)
Liked 70 Times in 41 Posts
Shoe Goo.
Force a dab into the (usually a cut) with the tip of a screwdriver.
I do it almost weekly in the winter.
woodcraft is offline
Old 06-07-18, 01:45 AM
canklecat
canklecat's Avatar
Quoted: 2941 Post(s)
Liked 279 Times in 212 Posts
Shoe Goo on my hybrid tires. Doesn't work as well on my road bike slicks. So I patch the inside of the tire where it's been cut enough to be visible when the tire is inflated. I use the ultra-thin Lezyne self-sticking patches on both the tubes and tires. They're paper thin so they don't interfere with seating tires even on tight fitting rims. I figure the patch will help slow down debris from infiltrating the tiny cuts. Seems to work. I managed to keep another tire going for a few months even after it had been sliced up by broken slate. I finally had to scrap the tire when one cut finally wore through the inner shield and began to avulse.
canklecat is offline
Old 06-07-18, 01:06 PM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 789 Post(s)
Liked 79 Times in 63 Posts
Plug it. With tubless tires has come the need to plug cuts like these. I would think this would fix you up nicely.
google: Blackburn Plugger Tubeless Tire Repair Kit
or
bicycle tubeless tire plug kit
I have a set in my bike bag. I've used these (larger version) on my cars and they work great.
chas58 is offline
Old 06-07-18, 01:19 PM
le mans
Steel is real
le mans's Avatar
Quoted: 151 Post(s)
Just the other day I was wondering if there were specific tube patches for skinny road tubes
I was slicing my regular patches to size to make them fit
how do they hold up on high PSI?
BTW, on one of the tubes, it had a very thin green patch which needed to be re-patched i wonder if it's the same product you're referring to
le mans is offline
Old 06-07-18, 01:25 PM
rumrunn6
rumrunn6's Avatar
or this
https://bikerumor.com/2010/11/23/rev...ire-patch-kit/
rumrunn6 is offline
Old 06-07-18, 02:12 PM
canklecat
canklecat's Avatar
The Lezyne patch kits are great. Comes in a little plastic envelope, dimensions smaller than a credit card, about the thickness of three cards. Includes self sticking patches that are paper thin but very tough; a tire boot for bad cuts, thin but tough plastic with the kit instructions printed, a metal scuffer.a
The regular tube patches hold against small cuts on my road bike tires, usually 90-100 psi. If the cut goes through the inner puncture shield it probably needs the tire boot and the tire should be replaced. Some folks will repair cut tires that are otherwise in good shape, but that's a topic for another thread and covered in the archives.
I've been satisfied enough with the Lezyne patch kits they're all I carry for myself. On casual group rides I'll bring a regular adhesive glue patch kit for the newbies. Folks who aren't accustomed to the self sticking patches tend be skeptical. Can't speak for the Park and other brands but the Lezyne has been great for me.
Old 06-07-18, 06:17 PM
pesty
Master Sarcaster
pesty's Avatar
Quoted: 190 Post(s)
I'd be really surprised if this is in any way different than a tube patch kit. I've been using tube patches on the inside of tubeless tires for years.
pesty is offline
Old 06-07-18, 07:04 PM
Kontact
Kontact's Avatar
Quoted: 2146 Post(s)
Liked 4 Times in 4 Posts
If you were trying to close a hole in rubber, wouldn't vulcanizing compound be the stuff to use?
Kontact is offline
raja_mastana
General Cycling Discussion
23
10-13-18 04:10 PM
Shadowx
8
09-14-17 08:26 PM
Bikram
24
07-04-15 11:13 AM
cvcman
Bicycle Mechanics
9
07-15-12 05:20 PM
sciencemonster
Classic & Vintage
25
01-21-10 07:46 PM
