DT Change SIS to Friction?
Old 12-06-18, 11:50 AM
dwing
Quoted: 80 Post(s)
Liked 3 Times in 2 Posts
Is there a special tool that's used to switch SIS DT shift option between index & friction? I don't want to break anything so I'm wondering what the proper procedure is to turn the "dial/red arrow pointer" from index to the friction option. It seems stuck in my case.
I see there's a tiny hole on one side(11 o'clock position in attached pic) , and another tiny hole with groove the opposite side (can see the groove near the M5 screw). Am I supposed to use a tool to turn it counterclockwise so red arrow currently pointing to "SIS Set" to "Friction Set" ? Thanks!
dwing is offline
Old 12-06-18, 11:58 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1879 Post(s)
Liked 104 Times in 81 Posts
The industry accepted special tool is a screw driver to loosen the mounting screw enough to rotate the bezel with the missing "D" ring. The "D" ring is essentially the wrench to turn the bezel. It would not be hard to cut and bend a spoke to fit, although it will likely fall off if left on during riding. Andy (trying to blend humor with reality)
AndrewRStewart
Andrew R Stewart is offline
Old 12-06-18, 12:04 PM
robertorolfo
robertorolfo's Avatar
Bikes: 82/82 Lotus Unique, 86 Lotus Legend, 89 Basso PR
Quoted: 594 Post(s)
Liked 36 Times in 26 Posts
Yeah, looks like you are missing the D ring. Maybe take one off another set of shifters just to help actuate it?
robertorolfo is offline
Old 12-06-18, 12:15 PM
blamester
Blamester
Bikes: Peugeot teamline
Quoted: 77 Post(s)
Liked 6 Times in 5 Posts
This.
You could find somenthing small enough to fit in there. The holes are 180 degrees apart. Small allen keys , circlip pliers etc.
But best find a d ring.
You will probably find that with a little practice and a hg cassette they work just as well in friction mode.and a hg cassette
blamester is offline
Old 12-06-18, 12:24 PM
canklecat
canklecat's Avatar
Quoted: 2936 Post(s)
Liked 274 Times in 207 Posts
Yup, just replace that D ring, or see if you can rig up something using a paper clip. That'll let you adjust tension while riding.
Keep in mind that friction mode with indexed shifters may not work well. Depends on the design. My Suntour GPX downtube shifter modules have two index modes and one friction. The friction mode doesn't have any clickstops and relies solely on friction between the washers. The problem is finding a balance between good friction feel and retention of the desired position. It tends to creep and ghost shift unless I really crank down the pressure -- in which case it loses any reasonable tactile feedback and I end up missing shifts.
It wasn't too bad in friction mode with an old Shimano 600 rear derailleur, but still tended to creep and ghost shift when standing to climb or sprint. I tried it that way for months and finally got tired of it. Switched back to the original Suntour GPX RD and index mode last week.
A purpose-designed friction shifter may work better. My other shifters on various hybrids, including a dirt cheap SunRace thumbie set and a Shimano bar-end shifter with index/friction modes, both include clickstops for a better feel and better resistance to creeping and ghost shifting.
canklecat is offline
Old 12-06-18, 01:01 PM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 2246 Post(s)
Liked 81 Times in 47 Posts
Mine, for reference and perspective:
DiabloScott is offline
Old 12-06-18, 01:03 PM
dwing
Quoted: 80 Post(s)
Kinda thought it was a missing D-ring but wasn't sure. Put an ice pick in the hole and tapped it over to friction. It's 6sp SIS, new 7 speed freewheel, new chain, friction setting now... You guys are correct, shifts as good if not better than 6 indexed. Very cool, thanks again!
dwing is offline
Old 12-06-18, 01:16 PM
Random Tandem
Random Tandem's Avatar
Bikes: Disc-Brake Sturmey-Archer S5 Hub All-Weather Commuter, 1970's Sekine, 1980's Kuwahara Tandem, plus a few dozen
Quoted: 44 Post(s)
If you would prefer 7spd SIS and you have a bike co-op nearby, you can often find a replacement shifter that is indexed to the number of cog you have. Similarly, co-ops are often a good source for reliable friction shifters.
Random Tandem is offline
Old 12-06-18, 02:10 PM
djb
Quoted: 1218 Post(s)
Liked 63 Times in 54 Posts
as an aside, I still have a 7 spd dt indexed bike that I put on my trainer for winter, and Ive owned teh bike since 90 or 91 and it index shifts as reliably and crisply as it ever did-in other words, it just plain works and so if yours are not working properly, I also suggest finding some old ones as indexing is just plain nice to use.
Once in a blue moon I would shift with my bike bottle when I was taking a drink, and could easily use the bottle to tap up a shift.
The rest of my bike had deore or deore lx stuff, so without checking, Im sure my shifters were mid level stuff like this, nothing fancy, but even then, given how old this stuff is, you should be able to find some 7 spd index units as give aways somewhere.
djb is offline
Old 12-06-18, 04:04 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 737 Post(s)
Liked 97 Times in 78 Posts
https://www.buckleguy.com/brass-d-rings/
https://www.michaels.com/frame-hange...ings/979630573
dedhed is offline
dbruening80
Bicycle Mechanics
12
02-15-14 10:44 AM
bianchi10
Road Cycling
12
05-15-12 09:49 AM
Chombi
Classic & Vintage
0
04-05-11 05:13 PM
tpelle
Bicycle Mechanics
2
03-13-11 08:31 PM
antfrogboy
Bicycle Mechanics
3
11-14-10 04:10 PM
