rebuild rear hub
rebuild rear hub
Old 07-01-19, 08:55 AM
arsprod
arsprod's Avatar
Bikes: Fairdale Weekender Drop, Motobecane 29LTD, Cannondale H400, Basso Coral
Quoted: 142 Post(s)
rebuild rear hub
I think my rear hub is going, SRAM MTH 406R, probably 12k+ miles. Trying to decide if it's worth rebuilding, replacing (not excited about building a wheel), or will replacing the freehub body give me more life? Thanks in advance
I'm slow, go around
arsprod is offline
Old 07-01-19, 09:28 AM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2301 Post(s)
Liked 263 Times in 198 Posts
12k miles on a cup and cone hub without service? Might as well open it up to see, but it might be too late.
Originally Posted by noglider
RUSA #7498
ThermionicScott is online now
Old 07-01-19, 09:45 AM
CliffordK
CliffordK's Avatar
Quoted: 9214 Post(s)
Liked 208 Times in 161 Posts
Hard to say what to do without some details about what is wrong beyond "going".
If it is a basic cup & cone hub, then it should be easy enough to rebuild. Races can take a lot of abuse. Cones can be replaced. Freehubs can be replaced.
A couple bucks worth of parts, and you're back on the road, good as new.
CliffordK is offline
Old 07-01-19, 10:11 AM
arsprod
arsprod's Avatar
Quoted: 142 Post(s)
Yeah, I hear you. It's always the bike I use the most (daily commuter) that I ignore the most
I'm slow, go around
arsprod is offline
Old 07-01-19, 10:26 AM
noglider
noglider's Avatar
Quoted: 5684 Post(s)
Liked 254 Times in 178 Posts
You don't say what "going" means, so I can't say if it's time to repair or replace. But it's worth looking at to decide.
noglider is offline
Old 07-01-19, 10:29 AM
Iride01
Iride01's Avatar
Bikes: '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 880 Post(s)
Liked 32 Times in 28 Posts
Are you just bored and need something to do or is the hub giving you problems?
If it is cup and cone, even some of the more abused ones run well with just cleaning and proper adjustment. However if this is the first time you ever ventured into the world of adjusting bearings, you'll wind up spending more than if you just take it to a bike shop.
Replacing the freehub body won't do a thing for you unless it's also is giving you problems. The freehub is really an entirely separate issue from the axle and bearings. They just co-habitate but live separate lives.
Iride01 is offline
Old 07-01-19, 11:07 AM
arsprod
arsprod's Avatar
Quoted: 142 Post(s)
By "going" I mean it doesn't sound right. I've never done bike hubs but do them on cars, which is leading me to take it to a shop instead of messing with it myself!
I'm slow, go around
arsprod is offline
Old 07-01-19, 01:45 PM
davidad
Quoted: 330 Post(s)
Liked 20 Times in 20 Posts
I overhaul my shimano rear hubs every 2500 miles or so. Because of this I rarely need to replace the balls, just clean and reassemble. One of my hubs has over 70k miles on it.
davidad is offline
Old 07-01-19, 03:32 PM
seedsbelize
necessary illusions
seedsbelize's Avatar
Quoted: 4886 Post(s)
Liked 62 Times in 47 Posts
In my experience, bike hubs don't take to being rebuilt correctly the first try. Do you have a hub vise? It helps immensely.
seedsbelize is offline
Old 07-01-19, 07:03 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 755 Post(s)
Liked 99 Times in 85 Posts
Sounds like what? Bearing roughness/rumbling/grinding? Freehub ratchet noise? Squeaking? "Going" doesn't give us much to "go" on.
dsbrantjr is offline
Old 07-02-19, 05:08 AM
arsprod
arsprod's Avatar
Quoted: 142 Post(s)
Sounds like a bearing that's going! Not grinding yet but not the smooth noise I expect when it spins.
Based on everyone's comments I stopped at a shop near my office yesterday and they're going to rebuild it for me. I don't have the right tools or patience!
arsprod is offline
Old 07-02-19, 12:17 PM
davidad
Quoted: 330 Post(s)
I believe that this is your hub. It is serviceable. Formula
davidad is offline
Old 07-02-19, 12:43 PM
robertorolfo
robertorolfo's Avatar
Bikes: 82/82 Lotus Unique, 86 Lotus Legend, 89 Basso PR
Quoted: 594 Post(s)
Liked 36 Times in 26 Posts
Excellent
robertorolfo is offline
Old 07-03-19, 04:59 AM
arsprod
arsprod's Avatar
Quoted: 142 Post(s)
Does Formula make SRAM's hubs, or at least the cheap ones?
arsprod is offline
Old 07-03-19, 11:58 AM
davidad
Quoted: 330 Post(s)
I don't know. I would need to see it, even then it' \s difficult to tell between it and other Chinese manufacturers such as Novatech or Joytech.
davidad is offline
Camilo
Classic & Vintage
2
06-05-17 06:20 PM
TW100
Bicycle Mechanics
14
01-23-17 02:29 AM
edotomato
Bicycle Mechanics
10
06-10-13 12:57 AM
plpete
Road Cycling
14
05-09-12 07:25 AM
Geturfix420
Bicycle Mechanics
4
10-25-10 08:02 AM
