Locking Skewers (Wheels/Seat)
Bikes: Lola (2012 Schwinn Voyageur 7)
I have the Delta Cycle Axelrodz from REI, but was looking at some reviews and saw that the botls can easily be stripped from overtightening. I do not have anything for my seat post, I would like to get something.
Anyway, I was thinking that, perhaps, I should replace them with another brand? Perhaps, one that has better reviews?
Thoughts? Does anyone else use these? Do you feel safe using them (i.e. added "piece of mind" for theft deterrent - to an extent -, actually riding on them etc.)?
Thanks!
Thanks!
Palmer
Bikes: Mike Melton custom, 1982 Stumpjumper, Alex Moulton AM, 2010 Dawes Briercliffe, 2017 Dahon Curl i8, 2021 Motobecane Turino 1x12
Quoted: 1646 Post(s)
Liked 1,785 Times
Without an in-depth understanding of the environment you leave you bike in, it's hard to advise. I always lock my wheels with the same u-lock(s) or chain(s) I lock the bike with. Someone will state the obvious, that with bicycles you can never reach absolute security - that might as well be me in the first reply. Anyway, in security skewers there's the Pitlocks and the Pinheads. Bicycle Bolts offers security torx screws for seatpost, saddle and stem.
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
The truth of the matter is that, if you overtighten anything, then you will either strip the threads or twist the bolt right off. Doesn't matter if it's bicycle skewers or the bolts holding rocket engines together. Overtighten if you want to have problems.
That said, IME the Deltas are a bit more frail than others, since their nuts use thread inserts instead of having threads cut into them. Still, they're just fine if you tighten sufficiently without overdoing it.
I've used Pitlocks, but it's easy to bugger up the threads on their skewers, then it's hard to remove them to fix a flat. Plus, in order to use their pit keys, you need a wrench that's uncommon in bicycle land (14mm instead of the usual 15mm). Although this is fine for things I don't need to change in the field. I still use their seatpost and headset bolts.
For skewers, I've reverted to the plain old hex-head ones sold by Sunlite, Nashbar and others. (Sunlite also sells the "Lock and Roll", which uses a weird five-sided key instead of a standard hex.) They work well enough for me. If I'm locking in a sketchy area, I use two locks anyway.
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
Super-spreader
I think it's high time we switched to locking sewers.
for the literature impaired,https://en.wikipedia.org/wiki/Jean_Valjean ..https://en.wikipedia.org/wiki/Les_Mis%C3%A9rables
there's a film Musical https://en.wikipedia.org/wiki/Les_Mis...es_(2012_film)
actually DHS sends out welders to weld up the manhole covers in case of insurrection.
to the original post.. I have regular hex bolt skewers .. rear
the tire wont come out inflated anyhow .. Front one came with the Dynohub..
Pitlocks are using a non standard Pit-key no 2 alike ..
unless you order the whole set same keyed.
like the custom wheel keeper lug nuts for your Mag -custom car wheels ..
my Koga has a ring lock for the back wheel, and a chain goes around
the front wheel and a post or something, to lock to, and it snaps into
the ring lock.. same key opens both..
Chain pin catch on the opposite side
of the lock m from the key.
I rely on heavy man hole covers to lock my sewers. No lock required.
For seat and wheels on my bicycle I use pitlocks from https://www.urbanbiketech.com. My kids have these on their bikes a major urban university for several years with no problems and the bikes are outside the whole time.
J.
J.
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 3078 Post(s)
Liked 1,631 Times
Their trick is that the bike needs to be upside down in order to open the lever and release the clamp, which is clever since a properly locked bike is almost impossible to flip upside down, and if you're needing a fix out on the road, upside down is one of the most convenient ways work on wheel and drivetrain issues that might necessitate wheel removal.
Bikes: Salsa Vaya
Quoted: 172 Post(s)
I use velo orange skewers which are pinned allen bolts. It gives a reasonable balance between security and convenience and you could get it open without a special key by breaking off the pin or drilling it out. Should be good enough to deter casual thieves.
Is there any rule of thumb -- as there is with QR skewers -- regarding how tight to make these? I generally go until there's resistance and then another half turn. Does that sound reasonable?
DancesWithSUVs
Quoted: 7 Post(s)
Yup. And if your bike has a computer,there's a magnet right there on the wheel a thief can pop off and use.
I'm also not a fan of these because since they look like regular QR's,I can see a thief messing with them thinking they're just really tight and damaging something trying to get them off.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
Thread Killer
Liked 1,631 Times
You guys are paranoid freaks.
Bikes: 2011 Raleigh Sojourn, 2012 Marin Four Corners, 2013 Soma Saga, 2014 Scott Spark 940, 2017 Brompton H6E, 2016 Trek FX 7.2
Quoted: 10 Post(s)
Yeah, for a commuter setup I have bombproof tires and the Sunlite Lock 'n' Roll Skewers. They basically use what looks like a five (instead of six) point hex-like key. I used to carry the little tool with me everywhere, it's not much trouble to toss it in the bottom or side pocket of any backpack or even keep it on your keys. But the tires I've been riding for years have never failed me, so far I've worn out three sets of the same model tire (Vittoria Randoneur) and have never ever had a flat; so now the tool stays at home. Even if I do get a flat, my commute is only five miles one way and public transportation can get me home easily where I'd rather do the repair than on the roadside. As mentioned prior, any security skewer is just a minor deterrent for a determined thief. I personally evaluated that for me, I'll take my chances with a more affordable skewer rather than blow a hundred or more dollars on a semi-custom set (pitlocks) that can be compromised nearly as easily by someone who knows what their doing. And yes I have had the Axle Rods from delta strip out on me. I am happy with the Sunlite Lock 'n' Roll's as the best balance between cost and security.
https://amzn.com/B002K2IYPY
I recommend getting the Onguard Three-piece Locking Skewers. Similar to Pinhead. This will lock your wheels as well as the seat post. The tool to remove the skewers is smaller than my thumb, fits on a keychain, and it doubles as a bottle opener.
If you're not locking the bike up overnight you should be fine just locking the frame with a good U-lock. I suppose if you live somewhere like NYC and/or if you have expensive wheels with disc brakes, etc, a thief could be tempted to defeat the locking skewers. If you have a valuable saddle, such as a Brooks, you'll want to lock the seat itself with something like a bicycle chain.
Thread Killer
Liked 1,631 Times
I'm at year 6 rolling on Vittoria Randonneurs flat-free! Same set, too, though they do come off about 4mos out of the year. Great tires in my experience.
The pitlocks make this more difficult because they have a piece that prevents you from grasping the locking nut, it's a collar that turns freely on one side.
J.
Bikes: Salsa Vaya
Quoted: 172 Post(s)
I have mixed feelings about seeing this posted publicly. It's valuable information, but, in addition to educating us, you're educating bike thieves. Is it possible you could edit your post to not include such detail? Perhaps say something like "it is possible to remove the Onguard locking skewers with the right tools."
Of course now he'll have to edit the quoted material your post also. I don't expect bike thieves cruise bike forums for tips.
I edited my post, but I think it's useless gesture in a big way. I found it on the internet and it many places. It's not hard to figure out either. There are no secrets anymore.
Personally, I'd rather have it posted so that the manufacturers do something about it. It's now harder getting it out than a broken skewer would be but you get to pay $70 or so for the privilege. None of this stuff works against a determined thief - noting that many can be through a U lock in <10 seconds.
The whole point of all of this is making your bike harder to steal than the one next to it.
Here, for example, are another 2-3 ways to get past them and almost any locking skewer.
https://www.bikeforums.net/showthread...1#post14353885
There is no theft resistant, there is only theft delaying products. The thing that gets me is when we are sold a product and it can be defeated rapidly - at least make it so that the bike gets destroyed by trying to get it free (Mutual Assured Destruction concept) or make it take a long time with obvious tools.
The good news is that if you park your bike where other bikes are parked, it's a given that virtually ALL of them will be less protected than your bike with a U lock and pinheads or pitlocks and, therefore, a much more likely target. My kids have their bikes at a university in a major city and with pitlocks (and for a year with pinheads) for a total of 5 bike-years without so much as an issue (fingers are crossed). To a thief, looking at our bikes, they are a *major* hassle compared to other bikes right along side. That's what makes it work.
Here's another product that caught my eye. Probably a whole lot cheaper than either pinhead or pitlocks for that matter.
https://www.brycefastener.com/security/penta-nuts.cfm
J.
J.
Thread Killer
Liked 1,631 Times
Originally Posted by geraldf
i have mixed feelings about seeing this posted publicly. It's valuable information, but, in addition to educating us, you're educating bike thieves. Is it possible you could edit your post to not include such detail? Perhaps say something like "it is possible to remove the onguard locking skewers with the right tools."
Not sayin' it happens, just askin' if it could... uh, wait a minute...I'd better go; I hear helicopters outside.
apocryphal sobriquet
[/i][/color]
I'm not saying a thief would do this, but couldn't one track your IP address from the vBulletin forum software using a decompiler and target an individual user, say for example, if they had a desirable bike?
Bikes: Salsa Vaya
Quoted: 172 Post(s)
No, not without a GUI interface written in visual basic. Ugh, now I feel dirty even mentioning that.
The Sunlite Lock & Rolls are sold under a variety of brand names, from many sources -- even Walmart. I have a set on my bike, and my sister's bike (hers had the wheels stolen a couple years back, her son locked the frame & not the wheels). I know how to defeat them, but I'm not telling. I'm getting another set for my daughter's bike too, now that she has one I'm actually concerned about losing.
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
I have one of the Zefal ones on my seatpost binder on my commuter. No issues so far.
Bike Nerd
Bikes: '04 Cannondale Track, Custom Steel Disc Road Di2, Rock Lobster CX
Here in NYC most thieves aren't interested in breaking locks. They'll typically just "pick" whatever is easiest, meaning saddle/seatpost, lights, bars, unsecured wheels, fork etc. Locking skewers are a great way to deter theft at those points. Nothing is foolproof, but even basic locking skewers and filling the remaining hex bolts with silicone are a good start.
On my two commuter bikes I currently I use Pitlocks to secure the headset/fork, front wheel, and seatpost clamp. All the remaining hex bolts are filled with silicone. The big deal for me is not having to carry a 2nd lock, that alone is worth the high cost of decent locking skewers.
