rate my form (pics)
rate my form (pics)
I had a post earlier this week about my stem length and soreness issues. I switched from an 80mm stem to a 60 mm that I had laying around to experiment. I actually liked the 60 but had only one 6 mile ride on it to base anything off of. I don't know if that was enough to make a judgement call. I put my 80 back on yesterday and today went on an 11 mile ride. Honestly I didn't feel quite as comfy being back on the 80. I was going to have my wife snap some pics of me riding with the 80 and then throw the 60 on and get pics with that stem too. I was then going to post both sets of pics and let you guys rate my form with each length stem. But after seeing her first pics with the 80 mm stem I admit I was more upright than I pictured myself being so I decided to just post those pics and get some opinions. How does my body angles look in the pictures? Am I too upright? Not upright enough? Anything look awkward to you more seasoned riders?
Just wanted to add here that I think in look way too upright. I wonder if a longer stem with more reach would actually help instead of going shorter. I have had issues with numb hands (especially the right ) with this bike. My sore lower back earlier this week I attribute to core muscle weakness and I am dealing with that by working out more to get stronger but that won't help my ice cold tingly hand issue and tired triceps.
First off, I think your seat is too high. Second, though I can't see it, your seat might be too far forward, and third, yes, I think a longer stem might be better.
Quoted: 8 Post(s)
Bench vise user
Bikes: 2004 Orbea Marmaloda, 1982 S12-S LTD, 1956? Maino, 1985 Sagres
Quoted: 79 Post(s)
Yes, I thought his saddle height looked ok. If that's too high I've been doing it wrong.
I get a little knee pain when it's lower than that, I believe from under extension.
I am tall and slender and pretty flexible. Flexibility has never been a problem with me. Maybe I am not taking advantage of my gift lol. I will start by dropping my stem down and moving my seat back. The seat height though seems OK by looking at it but maybe it is a little low.
I feel tension in my lower back when I shorten the stem beyond a certain point. I also feel an increase in pressure on my hands when I raise the handlebar beyond a certain point. I would definitely recommend to try flipping the stem to get some more reach and drop. Maybe also rotate the bar forward a little.
Seems fine for General cycling, and touring ..
Race low bent way over, like a quadraped, to reduce aerodynamic drag is Not for everyone.
just another gosling
Quoted: 3884 Post(s)
Liked 1,936 Times
Once my saddle is in the right spot for balance (I can briefly lift my hands off the bars), I judge my stem length like this: With my hands on the hoods and forearms horizontal, my elbows should be in front of my knees.
Results matter
Results matter
Quoted: 513 Post(s)
Liked 444 Times
Seat height looks fine, and the bike is the right size. Good gob. But you are sitting tall in the saddle, and the reach is kinda close. A lower back angle and more reach would help you get more power to your cranks by opening up the back and glutes. Yeah, it's more aerodynamic, too, but at this stage we're talking about power without sacrificing comfort. Getting lower will also sharpen your bike handling and confidence going downhill.
I suggest going lower before increasing the reach. The difference will be more apparent and it won't cost anything. Flip the stem and try it for a while. That will also extend the reach a bit. A little more saddle setback might be helpful toward keeping your weight centered over the cranks.
If you like it, try a bit more, and so on. If it's too much, back off. Then try it with a longer stem. Exactly how long, I don't know. Post more photos when you find your bar height and saddle setback, or see if you can find some loaners. I'm thinking 1 or two cm longer. I'm not trying to turn you into a racer, just a more dynamic and efficient weekend warrior.
Quoted: 513 Post(s)
Liked 444 Times
Sounds good. I didn't really mean you shouldn't change saddle height, because you're pretty much in the pocket, but by all means experiment. If you start to feel too much pressure on the perineum, or you find your hips rocking, or you can't increase cadence without bouncing, or if you're pointing your toes to complete the pedal stroke, bring it back til it stops.
Regarding KOPs, I tend to ignore it. For road riding, saddle setback is for maintaining balance over the feet. My guide is, if you feel yourself falling forward, move the saddle back. If you find yourself sitting on the nose too much, or if pulling yourself out of the saddle to accelerate or climb feels like crawling out of the back seat of a Mustang, move it forward a little.
Bikes: 1986 Cilo 12 Speed, 2003 Trek 7700 FX, 2016 Specialized Diverge, 2020 Specialized Turbo Vado 5-SL
Maybe it's me, but it looks like you could go to a larger frame. It looks like your seat is too far back and not high enough and that your top tube is too short. but then again, my opinion cost exactly nothing.
Quoted: 513 Post(s)
Liked 444 Times
A 58 cm frame generally works for guys int the 6'0" - 6'2" range. An 80 mm stem is extraordinarily short for normally proportioned riders who are correctly sized for a 58. Usually, they're delivered with 10-11 cm stems.
For the record, I'm a couple millimeters shy of 6', with long legs and arms. I've been riding bikes with 57-58 cm top tubes and 11-13 cm stems, depending on the bike and the handlebar, for the last 38 years. Although the numbers from the fit calculators don't support it, I perch on a 58 cm Madone wtih a 12 cm stem with a very Eddy-like profile.
Trail monkey, I think that as you gain experience, strength, and flexibility, you'll settle on a longer stem.
He didn't do the flat footed straddling the top tube test in front of me, in the Shop. Now how far can you pick the front wheel, up?
