Go Back  Bike Forums > Bike Forums > Fitting Your Bike
A new (I think) rule of thumb regarding bike fit
Fitting Your Bike Are you confused about how you should fit a bike to your particular body dimensions? Have you been reading, found the terms Merxx or French Fit, and don’t know what you need? Every style of riding is different- in how you fit the bike to you, and the sizing of the bike itself. It’s more than just measuring your height, reach and inseam. With the help of Bike Fitting, you’ll be able to find the right fit for your frame size, style of riding, and your particular dimensions. Here ya’ go…..the location for everything fit related.
Old 07-08-13, 06:40 PM
rebel1916
rebel1916's Avatar
Quoted: 67 Post(s)
Liked 83 Times in 44 Posts
What happens if the pants shrink in the wash?
rebel1916 is offline
Old 07-08-13, 08:40 PM
Loose Chain
Loose Chain's Avatar
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times in 56 Posts
Originally Posted by rebel1916
Holy shnikes, clean out your listening ears. I didn't say rules of thumb don't exist, I said that they could not be extrapolated from the single experience of one man. Even if he has been riding for almost 6 months now.
I am having a conversation, if you wish to have a melt down, go ahead. I had no problem with what you said, I was just adding on to it. Of all the forums I watch from scuba to boating to astronomy, this forum is by far the worst for getting along. It is clear the OP was really just funning.
LC
Loose Chain is offline
Old 07-09-13, 03:45 PM
sreten
Bikes: 20" Folder, Road Bike
Originally Posted by jyl
Problem with the OP's proposal is that no-one agrees on what an appropriate pants inseam is. One person likes floods, another likes a deep break at the instep. OP says his pants inseam could be from 28" to 30", that is a 2" range which is large enough to make the rule not workable.
Hi,
My clothing inseam is 29" but pants/ trousers generally come
in length sizes in multiples of 2", 28/30/32/34" etc in the UK,
and for say loose fitting jeans 28" usually fit better than 30".
Still I was surprised how close the crank centre to seat height
was for my "inseam", the number most people know for clothing.
For the hell of it I'll posit if the "crank centre to seat height" is
shorter than your normal clothing inseam, the seat is too low,
and it is a pretty good way of setting the initial seat height.
rgds, sreten.
sreten is offline
Old 07-09-13, 04:19 PM
sreten
Hi,
FWIW the labels on shrinkfit clothing, which may be
well before your time, reflected the shrunken size.
rgds, sreten.
sreten is offline
Old 07-10-13, 09:50 AM
PatrickGSR94
PatrickGSR94's Avatar
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times in 13 Posts
Originally Posted by sreten
Hi,
My clothing inside leg is 28"/29", I prefer the latter, but an unusual
size, and 28" fits better than 30", depending on acceptable crumple.
I measured both my bike today, centre of the crank along the tubes
to the top of the saddles, the road bike is 29", the folder 28.5".
Seat height is set so my legs will lock out using my instep over
the pedal. i.e.very near as high as it will go, with no consideration
of being able to touch the ground sat in the saddle for the height.
rgds, sreten.
Center of crank? So then that method completely ignores crank arm length, which makes the "method" pretty much useless. I think it's purely coincidental that your inseam seems to match the crank center to saddle measurement on your bikes.
PatrickGSR94 is offline
Old 07-10-13, 11:17 AM
sreten
Hi,
Yeah right. More meaningless criticism. I'm average height and use average
cranks. You either use 170mm cranks or are short and use shorter cranks
or tall and use longer cranks. It hardly renders the observation useless.
rgds, sreten.
sreten is offline
Old 07-10-13, 11:44 AM
PatrickGSR94
Quoted: 676 Post(s)
uh whut? I use 172.5 cranks on one bike and 175 cranks on another bike. I'm pretty average height but have longer legs and shorter torso.
However... I used to wear more baggy pants with a 32" inseam, but recently started going with more fitted pants in a 30" inseam (my actual heel-crotch inseam is around 32" I think). I just checked crank center to saddle on my road bike (the one with 172.5 cranks), with the saddle set by the shop owner when I purchased the bike, and it's right at 30".
I'm going to check to see what the height is on my MTB later - theoretically it should be a touch lower since it has the 175 cranks on it.
Old 07-10-13, 11:56 AM
sreten
Hi,
Your the first person to actually state the relevant details for you and your bike .....
rgds, sreten.
sreten is offline
bobbyl1966
Fitting Your Bike
5
02-19-16 10:58 AM
Spartacus713
Fitting Your Bike
4
09-01-15 01:49 AM
unlisted
Fitting Your Bike
0
01-12-15 02:26 PM
Conan
Road Cycling
4
06-24-12 07:21 PM
dennisa
Road Cycling
19
01-23-10 07:28 PM
