Go Back  Bike Forums > Bike Forums > Alt Bike Culture
Cutting Handlebars
Alt Bike Culture Chopped, dropped, stretched, lifted, and otherwise cut up and put back together. The art and science of choppers, cruisers, lowriders and the vast world of mutant bicycles.
Cutting Handlebars
Old 01-01-06, 07:26 PM
OrgFarmCY
Commuter
OrgFarmCY's Avatar
Bikes: To many junkers
Cutting Handlebars
So, if I needed to cut a pair of older handlebars, and I was on a limited budget, what would I buy?
Thanks
--Aaron
OrgFarmCY is offline
Old 01-01-06, 08:59 PM
Seggybop
o.O
Seggybop's Avatar
a hacksaw?
Seggybop is offline
Old 01-02-06, 03:04 AM
steve the tank
220 lb messer
Bikes: A few.
Hacksaw or a pipe cutter. You decide!
Pipe cutters are more fun.
steve the tank is offline
Old 01-02-06, 12:15 PM
bikejunkie
group W bench
Bikes: Raleigh Prestige, GT ZR.1, Burley Duet, Schwinn Voyagre, Giant ATX 990, a couple single speeds and a fixed gear, plus my bike collection
Quoted: 13 Post(s)
Liked 24 Times in 3 Posts
Most pipe cutters are meant for copper or plastic tubing. Steel ruins the cutting wheel pretty quick. You can get steel cutting wheels but the hacksaw would be cheaper and more practical.
bikejunkie is offline
Old 01-02-06, 01:14 PM
jaqb
jaqb's Avatar
Bikes: orange E8
bikejunkie jou right, it'l bee best way to cut handlebar
jaqb is offline
Old 01-25-06, 04:25 PM
hound-dog
hound-dog's Avatar
Definitely a hacksaw, that's what I use. There's also a discussion forum at www.chopzone.com about chopping bike parts and tools to use that you might find helpful.
hound-dog is offline
Old 01-25-06, 06:09 PM
phoebeisis
New Orleans
Quoted: 157 Post(s)
Liked 3 Times in 3 Posts
For a bit more(say $4 for hacksaw) you can get a Harbor freight 4 or 4.5" grinder-cutter.It will cut anything you want to cut-steel-aluminum-rubber(cut lugs off)-anything.Luck,Charlie
phoebeisis is offline
Old 01-28-06, 12:25 AM
slagjumper
slagjumper's Avatar
Bikes: Salsa Las Cruces, Burley R&R and a boat load of others.
I like using pipe cutters becuase you get such a strait cut. I only have the pipe cutters for cutting handlebars.
slagjumper is offline
Old 01-28-06, 08:30 AM
Mr Zippy
I came across the following hint at Jim Langley's web site - you use a cheap hose clamp as a guide for the hacksaw blade :
https://www.jimlangley.net/crank/genrep.html#cdm
Mr Zippy is offline
Old 01-28-06, 01:00 PM
mindfrieze
Just a thought.
Bikes: * Ciöcc MOCKBA '80, Giant Kronos, Specialized Rockhopper, Battaglin, Motobecane Grand Touring, Italvega, Bridgestone T700 *subject to change without notice.
Most handlebars these days are made of aluminum, which is about three times softer than copper. For an easy, clean, precise cut, I would highly recommend a pipe cutter, although a hacksaw would do the job in a hurry.
If you're not sure whether the bars are aluminum or steel, try putting a refrigerator magnet on them. Of course, the magnet will stick to only the steel.
mindfrieze is offline
Old 01-28-06, 01:39 PM
gm1230126
barnfullagts
Bikes: GT BI Ti/BI Steel - Edge Ti and Steel Xizang Ti and Psyclone Steel
Liked 3 Times in 2 Posts
Pipe cutter leaves a cleaner cut and can be purchased at a do-it-yourself home center for $3.50, just make sure it has 1-1/8" Capacity. I've even used them for cutting down threadless forks.
gm1230126 is offline
Old 02-13-06, 01:17 PM
bxbmx
bxbmx's Avatar
Hey guys, are there any disadvantages to cutting down bars? I thought bars are made out of crmo. Im def going to get it cut at my bike shop, they'll do it for free...is there any problems if i do it in a year or so? (then again, they use that sanding belt to remove the rough edges.), I guess you guys cut down the grips too?
bxbmx is offline
Old 02-16-06, 09:27 PM
Fast Eddie
gravity speed freek
Bikes: too many
ive cut alot of bmx handlebars to get the "horseshoe" style bars i use on g-bikes. ive used a hacksaw and the cutting wheel on my dremel roto tool. it eats up those lil cutting wheels pretty quick though. after a hacksaw i still use the sanders on the roto tool to de-bur the edges and put a slight bevel so that the grips slide on a lil better. i tried using a miter box once or twice, but since the ends get covered by the grips any way, i dont worry much about the cut being perfect. fast eddie outty
www.freewebs.com/gravityracing/
Fast Eddie is offline
Old 02-17-06, 07:54 AM
FergusF
Bikes: 2003 Kona Smoke, 2004 Fuji Touring, 2005 Brompton L3, 2008 Dahon MU XL Sport
No disadvantages unless you cut off too much ;-). Some are made of cromo, some steel - you can use a magnet to test for steel. No need to cut down the grips (I assume you're talking straight bars here) unless you want to, just move the brake and / or gear levers inwards by the same amount you cut, and you can use the original grips.
FergusF is offline
Old 02-20-06, 10:01 PM
bxbmx
bxbmx's Avatar
my handlebars are 2 piece, and i dont think the levers go in anymore...so cut the grips? i will go to the bike shop soon and maybe ask them
bxbmx is offline
Old 02-21-06, 10:40 AM
a77impala
a77impala
a77impala's Avatar
Bikes: 04=LeMond Arravee, 08 LeMond Versailles, 92 Trek 970
Quoted: 28 Post(s)
Liked 13 Times in 8 Posts
Instead of cutting the grips get some for gripshift shifters they are over an inch shorted than regular grips.
a77impala is offline
