TERN Verge P10 front wheel.
Bikes: Dahon Mu uno, Dahon P18 Visc
I was wondering if anybody knew where I could get a replacement front wheel for my Verge p10 I'm in the UK so I was wondering if anyone knew of a supplier in Europe? The current wheel has got a crack through the rim ☹️
Stardust
why just not to buy a new rim and replace the broken one?
Likes For BromptonINrio:
Stardust
there are plenty on aliexpress.
#Aliexpress R$ 271,52 5%OFF | SILVEROCK Alloy 20" 406 20 1 1/8" 451 22" Rims for Minivelo Folding Bike Trike Recumbent Bicycle 20H 24H 40mm Width Clincher Rim
https://a.aliexpress.com/_dWOr700
#Aliexpress R$ 415,71 34%OFF | 20" Folding Bike Wheels 451/406 Front Rear Bicycle wheelset 7-10s Aluminum Rims 100/135mm For BMX Bicycle Wheel set
https://a.aliexpress.com/_dYQ6UGG
Quoted: 980 Post(s)
Liked 582 Times
This ^^.
You'll probably need new spokes unless you can find a replacement rim with the same "Effective Rim Diameter" (ERD). I went through the same thing with the rear wheel on my Verge S11i. Once I found a rim that works, and got the correct spokes, it was an easy process to re-build the wheel.
I believe these may be an European alternative;
https://www.ginkgo-veloteile.de/gink...NbR-451mm.html
just - do your hubs really look like this (for common, angled spokes);
https://www.ternbicycles.com/sites/d...blkbgtblue.jpg
or like that (straight spokes):
https://hollandbikeshop.com/img/prod...95878-11-l.jpg
https://hollandbikeshop.com/de-at/fa...w-blau-495878/
(The Kinlin rim above won't work with the straight spoke hub I mean.)
