Bottom-bracket identification; this is my first time replacement
My cranks are finally wobbling and I have never replaced bottom-bracket bearings before. I needed new cranks anyway since my chainring has survived four chain/one cassette replacements and I want to add toe-straps for my harsh, mountain biking practice
This will be my final fix for this old bicycle (it was already "used" when bought); I would buy a new hybrid once I repass the fourth chain replacement.
Since there is - practically speaking - too many types of bottom-brackets to google on, I hope there is a 'Specialized' expert here who would instantly recognize the specifics tooling I would need. See the DSLR pictures attached. If it helps, the bicycle frame is a 'Specialized' and was designed on a 'Sun Microsystem'. Let me know if you require pictures from the chainring side.
Yes, the dust-cover has long been lost.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
looks like a standard cartridge square taper BB. If you're replacing the crankset you MUST buy the new BB that that particular crankset requires. You need to know shell width (likely 68mm or 73mm) and threading (almost certainly BSA/English) of the frame
Likes For dedhed:
Quoted: 6193 Post(s)
Liked 4,808 Times
As far as the wobbling goes, are you seeing it in the spindle going through the bb? Or are you seeing that between the crank arm and the spindle.
As for you saying you ride harsh.... if that's got to do with putting a lot of stress into the cranks, you might want to figure out if a bb with external bearings will work with your frame. That will likely require a new crank set as well. But if you aren't going to have it much longer, probably not worth it.
As always, more info about the exact model and year of bike you have would really be of more help. Specialized uses all sorts of BB types for their bikes.
Likes For Iride01:
Thanks dedhed. Seems like my BB being the standard cartridge square taper is a good bet. Looking at YouTube right now to find the right removal tools.
The spindle through the bb. Thanks for the external bearing advice.
Really Old Senior Member
https://www.parktool.com/category/crank-bottom-bracket
Wrench remove your cranks
Remove the BB
Go with external BB type ?, installation tool
Option: save on multiple tool buys , have Bike Shop do the work..
Remove the BB
Remove the BB
Remove the BB
SE Wis
Liked 3,390 Times
While helpful, the exact make and model # of the existing crankset is more helpful, particularly if they plan to just replace the BB and keep the existing crankset
SE Wis
Liked 3,390 Times
My cranks are finally wobbling and I have never replaced bottom-bracket bearings before.I needed new cranks anyway since my chainring has survived four chain/one cassette replacements and I want to add toe-straps for my harsh, mountain biking practice
This will be my final fix for this old bicycle (it was already "used" when bought); I would buy a new hybrid once I repass the fourth chain replacement...
So is your intent to replace the current crankset? or just repair the BB and use the old crankset? Not really clear.
Just replacing the cartridge BB? a cheap Shimano UN 26 or similar in the proper shell width, threading, and spindle length
Replacing the entire crankset? Decide on a cheap replacement crankset based on your gearing needs and riding style. The crankset will determine what BB it requires. The "final fix" says to me - Just another cheap square taper crankset and cartridge. Not "upgrading" to an external BB crank unless you're going to remove it and use it somewhere else when getting rid of this bike.
You are also going to find out in the current world pandemic that supply chains are creating shortages of both cheap replacement parts and upgrade parts. there's a chance you can't do this even if you want to, because parts aren't available.
Likes For dedhed:
Quoted: 2363 Post(s)
Liked 1,749 Times
In that case, as mentioned above, it's a new BB you're looking for, and your crankset may be fine. You mentioned multiple chain/cassette replacements. If that means you're concerned about chainring tooth wear (a well-founded concern, BTW), the next important identification question is -- are the chainrings bolted on, or riveted? If bolted on, you can replace them and keep your crankset. If riveted, then indeed, it's the whole crankset you'll have to replace. If you're unsure, post a photo of the right arm with the chainrings.
Look on the inboard side of the right-side crank arm. That should have a model number.
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
+1. If the cranks are wobbling then the issue is a loose crank bolt, maybe both. If the wobble has been allowed to go on to long, it's possible the square hole in the crank has been rounded and no amount of tightening will fix it. So check that. If it is rounded, it needs to be replace. If you do replace the bb, as noted above, spindle will need to be the same length as the existing one (and depending on the age of the bike the spindle could be symmetric or asymmetric, so check that), and if you have to replace the crankset, a new bb would have to be purchased to work with the new crankset.
Don't complain about the weather and cower in fear. It's all good weather. Just different.
SE Wis
Liked 3,390 Times
One of the issues is the future status of said bike. That to me would determine how much time, money, and energy I'm expending on it.
Likes For dedhed:
