Is there a way to tighten a freewheel?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 460 Times
I'm not talking about tightening it on the wheel but tightening the freewheel itself. My Suntour
Winner freewheel has a very small amount of inward outward play holding the center ring causing a slight creaking
sound that vibrates into the frame.Can this play be tightened any way?
Quoted: 4212 Post(s)
Liked 3,883 Times
Besides the noise is there a functional issue? If not, then I suggest just flushing and lubing the freewheel. The creaking is likely from rough bearing surfaces (be they rust or pitting) and/or a lack of lube. Freewheels really like a slight freeplay, call it negative preload. As long as it's not enough to cause auto shifting the freeplay, onto itself, is not usually an issue. However a slightly tight/too great a preload, can cause all kinds of coasting problems. Andy
AndrewRStewart
AndrewRStewart
Quoted: 677 Post(s)
Liked 460 Times
The is no play at all on the shimano freewheel
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
They were often adjusted with thin washers between the freewheel hub and body. Not a job for the faint of heart.
https://www.bikeforums.net/classic-v...o-heavy-3.html
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
SunTour "Perfect" and "Pro-Compe" freewheels used shims to adjust the bearing pre-load. The "Winner" freewheels used a cup-and-cone arrangement with a special wrench to set the pre-load:
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
PS I have (or had) that tool. Brings back some good old memories!
Quoted: 2432 Post(s)
Liked 641 Times
I never run vintage freewheels like that with non-ramped teeth anymore. With ramped teeth the shifting is 100x better, especially with friction shifters. Much less fumbling around with the shifter to get it in the perfect position. I use Sunrace freewheels and despite the fact that you can buy them for $10-15 they are very good quality. Shimano also makes them but I think theirs are ugly with a black big cog and huge logo.
https://www.ebay.com/itm/18522038986...0aAp8lEALw_wcB
Quoted: 1944 Post(s)
Liked 2,164 Times
Remove the cogs, don’t open it up, soak in solvent and let dry. You might use compressed air.
After dry, drip in Phil’s Tenacious Oil until it quiets down.
It may, or may not, solve your problem completely, but it is the route I would go.
John
John
Liked 3,883 Times
With the exception of the cogs removed from the core this is what I mentioned. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
