Hill climbing gears Mt Washington?
Hello New here, was hoping to get some help with gearing on my bike for Mt. Washington Hill climb. I was thinking of going with 34T ring with 11-40 cassette, Iam limited to 34t ring with existing crank sram force 1.
This would put me at 1 to 1 and then some lower gears for bail out. This is my 1st attempt at the Mt Washington hill climb, I am looking to complete under 90 minutes. Thank you in advance for every ones input. Water68.
Quoted: 1815 Post(s)
Liked 1,693 Times
Do you know what it's like to ride a 12.1% gradient? For 7.4 miles? That's what you need to figure out. Figure out what gear you can comfortably ride at 12%. For 90 or so minutes. 12.1% is pretty steep in my book, especially over an extended period. And you may want to research what the maximum gradient is because I've only talked averages, and I'm pretty sure there are times you hit 19%, although I think those are short stretches. I would certainly have a gear ratio under 1:1 and you're well below that.
Quoted: 2493 Post(s)
Liked 738 Times
Quoted: 507 Post(s)
Liked 237 Times
Mother Nature's Son
Quoted: 852 Post(s)
Liked 1,433 Times
Mt. Washington Record Holders @ Welcome Mt. Washington Auto Road Bicycle Hillclimb. Check out the time records by age. That climb is an incredibly difficult one, the percent of gradient, the distance, the wind and the physical/mental fatigue are all part of the challenge. I do not think anyone can tell you what would be the best gearing for you. I do agree that just finishing the climb to the top is sufficient enough of a goal for the first attempt. I have seen some short takes on film of that ride. Definitely for strong riders.
Bikes: Corvid Sojourner, Surly Ice Cream Truck, Co-Motion Divide, Co-Motion Java Tandem, Salsa Warbird, Salsa Beargrease, Carver Tandem
Quoted: 533 Post(s)
Liked 435 Times
which hill climb ? The one I know of only goes to the tree line and not to the top.
Quoted: 3221 Post(s)
Liked 2,049 Times
Likes For Rajflyboy:
I've done Mt.Washington 3 times. All as a pure flatlander, no hill work worth mentioning done in advance. Show up and ride.
First time was on 42x28. That was nuts but I made the top in 1:26. Talked a bit to the second place finisher that day. He had also done it on 42x28 and said he could have raced for first if he had had a more reasonable gear.
Second time was on a low of 28x32 and also sick and feverish. 1:32 to the top. Bottom gear was only used for the final 27% ramp and was not necessary even there.
Third time there was a storm and the race was scrubbed. You do not get a refund. Instead did a lovely hike up Tuckerman Ravine on other side of mountain. The weather was sunny and beautiful. All the way up thinking we should have been allowed to race. Then sitting near top saw hikers in full expedition gear coming from other side of mountain looking like snowmen.
What you should expect is a ridiculously fast start. First half of mountain is steepest. A lot of tension is released as you leave the start line. If you are capable of a 1:30 finish you will hit halfway in 35-40 minutes, still in a big group. Halfway is also roughly the treeline. The road is almost flat for a hundred yards or so. Everyone backs off and tries to rest. Don't do it. The flat is just long enough so it will be crazy hard to regain any of the momentum that seemed so easy first half.
Forget pacing. Do not attempt to outsmart the mountain. Ride your bike. You are going to see all kinds of crazy rigs, all kinds of crazy strategy, most people finish. No one except top competitors who have done it many times before have the ride they expected.
Quoted: 18351 Post(s)
Liked 4,502 Times
STRAVA: Mt. Washington, Gorham, NH
Whew, that is a pretty steady 12% climb, although minor details may be difficult to discern.
According the Strava, the top 20 riders or so barely hit it in 1 hour.
Gearing choice will certainly be rider dependent.
Put me on a 34/40 gear, and I would just crawl up the hill.
I'd probably select something more like 34/23 to 34/25. But I also realize the higher gearing works for shorter slopes, but may break down for long steady climbs.
I'd encourage you to set up your bike like you think you need it, then go out and find some 10% to 15% slopes near your home and just practice. See what works, what doesn't work. Even doing a few repeats on a 1/4 mile climb will tell you a lot.
Quoted: 4791 Post(s)
Liked 3,918 Times
That last stretch is the hardest thing you will ever do on a bike. (A lot of people walk it.) I hit it and knew instantly that if I stopped, no way was I getting to the pulled tight toestraps before I fell over. Took everything I had to get to the parking lot. Then it was just a sea of people but I was oblivious. Deep oxygen dept and in post finish line mentality. Keep pedaling and slow gradually. Good thing I was in a tiny gear! That crowd grabbed me and pulled me to a stop before I ran out of parking lot. Lifted me off the bike and walked me into the lodge. (I was equally oblivious to the temperature in the mid-20s. I was dressed in tights and two jerseys, long sleeve and short.
I sent up additional clothing but carried almost nothing. Usual race stuff, cycling wallet, keys ... No food, water bottles or cages. Never crossed my mind to drink or that I even wanted too. Now, three years before I carried a lot more as I needed to be able to get myself off the mountain and maybe to survive.
I went up that mountain two other times. On the cog railway as a kid and hiked it 7th grade. I've had deep respect for the mountain since that hike. Our last night out was at the Lake of the Clouds AMC hut 1 1/2 miles from the summit. Our guide gave us the history of the hut when we arrived. After it was built but before it opened, they stocked a store shed with emergency supplies so any hiker caught out could use them. Across the "lake" (a small pond) was a cross. Dated December after the build and before the opening. So that hiker died not knowing food, clothing and fuel were 50 yards away, across a pond that was certainly frozen solid with maybe a foot of ice. There were no barriers to sight between the cross and the sign (except perhaps nightfall and a blizzard)..
Ben
Quoted: 663 Post(s)
Liked 496 Times
I've not ridden a bike up the mountain but I have hiked and backpacked a good bit in the area and on the mountain itself. You likely know already but mountains can generate their own weather. It would not be unheard of to have snow in mid summer. The temps at the summit are likely to be 15 or more degrees F colder at the summit than at the base. Many people misjudge the weather and as of a few years ago over 150 people had died on the mountain since it was first climbed. I would monitor weather carefully as the date of our adventure gets closer, especially so due to the no refund policy.
Liked 3,918 Times
+1 My second climb, when it was 20s at the top, we left in 50F at the tool booth.
Quoted: 7 Post(s)
I rode it 2 1/2 times back in the '70's when it was open to the public. The half ride was due to a storm that rolled in just as we rode past the halfway hut. I was young and strong back then, and I could climb well in relatively big gears, so keep that in mind.
- The first time was on my touring bike with a 38x28 low gear (Stronglight triple). The only problem I had was getting going again after stopping on the 5-Mile Grade (15%). It's not easy to get into toe clips on a steep grade with traffic going by, but I managed to do it by pushing off of a boulder. We rode down afterward and that was more painful than the climb.
- The second time was during my racing years and I used a 42x28, because Campy cranks only went down to 42-tooth rings and the rear derailleur only handled up to 28 teeth, with some tweaking.
- The third time, I built a special freewheel with 28,30 and 32-tooth cogs on the low end and the same 42 in the front. It seemed like it wasn't much easier and I just went slower in the lower gears, so I didn't use them much. This was the half ride, so I couldn't compare the overall experience.
Quoted: 550 Post(s)
Liked 325 Times
Figure out your maximum sustainable power output in Watts for 90 minutes. Multiply by 0.9 because when climbing about 10% of your energy goes into aerodynamic drag and rolling resistance.
In good shape I can manage 200W (what I measure averaging 20 MPH on "flat" ground) for 90 minutes * .9 = 180W climbing power.
Determine total mass of you and your bicycle. Multiply by 9.8 m/s^2 earth gravity for weight in newtons.
In good shape with shoes, clothing, water, and bike I total 73kg which is 715 newtons.
Divide your effective climbing power by weight in newtons to yield vertical ascent capability in meters per second. Multiply by 60 to yield meters per minute.
180 / 715 * 60 = 15.1 meters/minute
Convert the grade into a fraction dividing by 100. Divide into your meters per minute vertically to approximate road speed in the same units.
15.1 meters/minute / (12.1/100) = 125 meters per minute
Get wheel RPM dividing by wheel circumference in meters, where that's 3.14 * (bead seat diameter in mm + 2 * tire width in mm) / 1000
I ride 622x25mm tires with a circumference of 3.14 * .672 = 2.1 meters. 125 meters per minute / 2.1 = 60 RPM
Figure out the minimum cadence you can sustain seated. Divide that into your wheel RPM for your required gear ratio.
I can climb at 55 RPM. 60/55 = 1.09.
Divide that into your small ring tooth count to get cog size, or multiply by cog size to get the required ring.
I ride a triple so I can have tight gears for plains and low gears for mountains without changing cassettes.
With a 30 ring, I could ride a 30/1.09 = 28 cog.
With the 26 large cog I usually use, I could use a 26 * 1.09 = 28 small ring.
Ensure you also have a low enough gear for the switchbacks.
Determine what you need standing. 30 RPM is fine for me. Express it as a ratio to your seated cadence. Divide into cog and multiply by ring.
I can grind up things at 30 RPM. 55/30 = 1.8. 28/1.8 = a 16 cog, and 28 * 1.8 = 50 ring.
Adjust those by the difference between steep stops and average. They look to be under 20% except for 30% at the end, where you could exert yourself unsustainably.
20/12 = 1.7
30/12 = 2.5
16 * 1.7 = 27 cog; 50 / 1.7 = 29 ring.
I'd be OK with my regular climbing gear on the switch backs.
16 * 2.5 = 40 cog; 50 / 2.5 = 20 ring.
Divide by the setup you'd otherwise be using. 40/28 = 1.4
My regular climbing cog would work except at the end where I'd need 40% more power to keep the pedals turning over. That's OK for an overpass distance.
I'd probably use a 26 x 26.
Your mileage will vary.
20/12 = 1.7
30/12 = 2.5
Bikes: I have a few
Quoted: 340 Post(s)
Liked 209 Times
Kudos of figuring this out but OMG that is more effort for me as I am FAR to lazy and busy these days. I would take the easy way and just get a smart trainer and ride the GPX. I have done this to find out how challenging the hills are for the Eroica ride I am doing next month. BTW I have found I will be doing some walking. I think I will try this mountain on the trainer this weekend but I must say I didn't even like driving up it. LOL.
20/12 = 1.7
30/12 = 2.5
20/12 = 1.7
30/12 = 2.5
Cyclists do not produce constant power. Electric motors do that. Climbing makes power output more irregular. It's constant small accelerations and decelerations. Gravity is a constant. Gravity is never evaded. The smallest interruption to constant pedaling force means you slow down instantly. The slower the pedal rpm the larger the interruption.
Mt. Washington is a strange climb. Nothing constant about it. The roadway was not laid out by highway engineers. Made by a cheapskate private toll road and by the mountain itself. The road is all surprises.
It's a steep road and it suddenly gets steeper in or out of the switchback for no reason. It is very likely to be foggy, meaning no warning of what's hitting you next. In clear weather the sight lines are still all very short. Inertia does not carry you forward on this climb. More like you are continually re-starting from a standstill.
For imaginary calculations about climbing imaginary mountains better to figure what you need to never drop below 50 or 60 rpm. Note that in the extended calculations above that rider is traveling real slow. The object in top post was to get up mountain in 1:30. Also note there is 100 yards of easy on this mountain. All the rest is one big hill and it is steep. You are not shifting gears for the hard parts and the fast parts. It is all the hard part
