Strength of bottom bracket housing with nothing inside?
Old 10-12-20, 10:03 AM
Badzilla
Badzilla's Avatar
Quoted: 37 Post(s)
I realize it might be difficult to figure and it varies from bike to bike, but generally speaking...
What would you guess is the strength of a bottom bracket housing tube? I mean, just the round steel tube with nothing inside of it. The tube that the three (or four) parts are welded to. The part that a bottom bracket screws into. Less generally... I'm talking about a larger tube that requires an adapter to screw a modular bottom bracket into. I suspect the larger diameter bottom bracket housing would be less strong. But I'm only asking for guesses about anything.
If you use the bottom bracket area with nothing inside of it, does that weaken it to the point of breaking? I'm guessing the innards provide some strength, but maybe not so much that it makes a big difference.
I'm asking for guesses since the subject might never have even come up before.
Thanks.
Badzilla is offline
Old 10-12-20, 10:23 AM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
Although I doubt there is any chance that the bb housing itself will fail, I would guess larger diameter tubes in general are stronger.
John
70sSanO is offline
Likes For 70sSanO:
Old 10-12-20, 10:45 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
Strong enough to tolerate what?
HillRider is offline
Likes For HillRider:
Old 10-12-20, 10:55 AM
guy153
Quoted: 321 Post(s)
Liked 263 Times in 212 Posts
They're usually very strong although they're available in different sizes. They're all 34.8mm on the inside (English threads) and some are as much as 40mm on the outside. That's 2.6mm wall thickness. And they're usually cromoly as well (rather unnecessarily given how thick they are). The other tubes on the bike are usually about 0.5mm increasing to 0.8mm at the ends to give you an idea how thick that is.
guy153 is offline
Likes For guy153:
Old 10-12-20, 11:02 AM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
How could you test this? Without the spindle, bearings, cups and crankarms installed you can't ride the bike except to push it along with your feet on the ground. I expect that wouldn't put much strain on the bottom bracket
alcjphil is offline
Old 10-12-20, 11:07 AM
CargoDane
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times in 199 Posts
John
Assuming the same wall thickness, the larger tube will be weaker from forces hitting the tube perpendicularly. It will be stronger in other ways (twist, mainly), but nonetheless.
That said, I'd buy a cheap bottom bracket and install that if I was worried about transporting a crank-/BB-less frame.
CargoDane is offline
Likes For CargoDane:
Old 10-12-20, 11:34 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3674 Post(s)
Liked 5,431 Times in 2,759 Posts
I think it would depend on how you use it. Uses for a bike frame w/o a crank seem pretty limited. Wall art, yard art, mail box support.... Give us a clue
shelbyfv is offline
Likes For shelbyfv:
Old 10-12-20, 11:42 AM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
Strong enough.
davidad is offline
Likes For davidad:
Old 10-12-20, 12:27 PM
dsaul
Quoted: 714 Post(s)
Liked 800 Times in 475 Posts
It's not too hard to find the mechanical properties of 4130 steel. ASM Material Data Sheet
The real question is what kind of strength are you looking for? resistance to crushing? shear strength?
dsaul is offline
Likes For dsaul:
Old 10-12-20, 12:35 PM
SJX426
SJX426's Avatar
Quoted: 1607 Post(s)
Liked 2,216 Times in 1,103 Posts
It is strong enough for its intended use and that includes holding the BB assembly. Its equivalent to asking the question of "how strong is an innertube."
SJX426 is offline
Old 10-12-20, 12:40 PM
ridelikeaturtle
ridelikeaturtle's Avatar
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times in 260 Posts
This sounds like someone wanting to use a bike frame for something with a motor in it.
Which would probably not be a great idea.
ridelikeaturtle is offline
Likes For ridelikeaturtle:
Old 10-12-20, 04:51 PM
Pop N Wood
Quoted: 668 Post(s)
Liked 529 Times in 355 Posts
Not sure if you are trolling or simply clueless but a BB with nothing inside of it should last forever, never wear out and never break, because after all it won't be used for anything.
Pop N Wood is offline
Old 10-12-20, 05:10 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Not very many frames are made from 4130, most are generally higher quality. I think the last one I had was a bmx frame in the late 70's. Cheap dept store bikes might be using it.
cxwrench is offline
Old 10-12-20, 05:26 PM
Trakhak
Trakhak's Avatar
Quoted: 2482 Post(s)
Liked 2,955 Times in 1,678 Posts
You're thinking of 1030 steel or the equivalent. 4130 is chromium-molybdenum, e.g., Columbus SL tubing.
Trakhak is offline
Likes For Trakhak:
aggiegrads
Quoted: 336 Post(s)
Liked 309 Times in 180 Posts
Huh? Do you mean mild steel? Most tubes are 4130, with different butting and heat treatments.
aggiegrads is offline
Likes For aggiegrads:
Old 10-12-20, 05:30 PM
dsaul
Quoted: 714 Post(s)
I build steel bike frames. I can assure you that almost all of the bottom brackets in quality welded steel bike frames are made from 4130 tube. Dept. store bikes are made from mild steel or Hi-tensile steel.
dsaul is offline
Likes For dsaul:
Old 10-12-20, 06:26 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Yep, you're all correct and I made the error...thanks for the clarification!
cxwrench is offline
Likes For cxwrench:
Old 10-13-20, 06:21 AM
andrewclaus
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times in 430 Posts
I don't think any kind of spindle and bearings will add strength to a shell.
andrewclaus is offline
Likes For andrewclaus:
Old 10-13-20, 07:25 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3588 Post(s)
Liked 3,400 Times in 1,934 Posts
But cups would.
That said, I think we need to know the OP's ultimate plans in order to assess the matter properly.
JohnDThompson is offline
Likes For JohnDThompson:
