full coverage fenders easy to take on and off
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Are there fenders that are easier to take on and off? I mean after the initial set up. I'm attracted to traditional metal fenders (like VO, Gilles Berthoud) and I know they can be tricky to set up, which I think I can handle, but after setup can they just be unbolted/rebolted?
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,536 Times
Liked 2,011 Times
They wouldn't be needed very often because it doesn't rain much here. I'm looking at 700x60mm+ full coverage fenders, so that's not an insignificant weight to carry around when they're not needed, and they're only needed a few days out of the year.
Maybe it's not feasible to change add/remove them easily, maybe I should go for less coverage - that's what I'm trying to figure out.
jj
Quoted: 140 Post(s)
Liked 110 Times
Yes they can. Don’t bother with less than full coverage, you’ll still feel like you maybe should’ve worn swim trunks on the ride if you do.
The only potential issue arises with the seatstay mounting bracket if the frame has canti/V/drum brakes and you're trying to be classy and put the bracket on the front side of the bridge. In that silly instance you have to wrestle with it a bit to get it out and back in again.
Grease your threads and you’re good to mount/dismount as many times as you please.
It is nice to have both your fair weather bike and a fender’d and racked bike ready to go.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
I will agree with hsuBM regarding the full coverage. I think whether or not you can easily mount and remove the fenders depends on both your bike and the fenders. I have a Soma Smoothie from which I can easily mount and remove a set of SKS fenders, cannot remember which model. The other 2 bikes I have had fenders on, a Schwinn SS DBX and a Lemond Poprad, took some modification, and or, some tinkering to get them to a workable fit. They are a bit easier to deal with after the initial install, but still a bit of a pain. The Poprad I will probably just leave the fenders on all the time, the Schwinn will probably never get fenders again.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
SKS has removable fenders. Not sure which ones fit wider tires. I think I have the Pros for 23mm tires. Good coverage. The front goes from the fork crown back down pretty far. Rear from brakes.
Likes For biker128pedal:
Quoted: 896 Post(s)
Liked 2,063 Times
I've never seen any kind of full coverage fender quick-disconnects. That would be nice for airline travel and bike shipping.
There are a couple tips that can make it easier to remove/replace normal full coverage fenders. First is isolating front brakes/headlight mounting from the fender mount. Get some Sheldon Brown problem solver nuts. Next, mark the fender stays, showing where they are clamped once set up. Same with adjustable brackets. Other than that, practice makes perfect. It's a little fiddly, but not too bad. One other tip, just go ahead and take the wheels off despite what you think you can do with the wheels on.
Likes For downtube42:
Quoted: 668 Post(s)
Liked 529 Times
I have SKS plastic fenders on multiple bikes. they are super easy to remove. Front requires 3 bolts, rear has 4. Leave the stays on the fender and unscrew the allen bolt at the dropouts. They roll right out without removing the wheels.
The plastic fenders are also pretty light.
Likes For Pop N Wood:
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Once everything is fit and installed, i would imagine i could take the Velo Orange style fenders off a bike in less than 5 minutes, and have it ready to ride again without fenders. I would think about 10 minutes to reinstall and have ready to ride again. Just store them with the stays installed on the fenders and leave the mounting hardware on the bike to speed up reinstallation (and make sure things do not get lost).
Likes For SalsaShark:
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
If it's easy for them to come off, they will--against your wishes. BTDT.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
If you live in an area where full coverage mudguards are important, either leave them on the bike all the time or get a second bike so you can have one with mudguards to ride in wet conditions and one without to ride in dry conditions.
Likes For JohnDThompson:
Quoted: 6963 Post(s)
Liked 10,963 Times
+1 this. Effective full-coverage mudguards require multiple anchor points for stability and safety (and noise reduction). Multiple anchor points make installation and removal more difficult.
Likes For Koyote:
