Gravelking tires for smoother/softer ride?
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
I have a Felt Z75 disc and am riding 25mm continental gp4000 now. I generally have the psi up high to avoid pinch flats now so I can really feel every little bump. When I ride my cyclocross bike it's a much more pleasant ride. So I'm curious if there are any options that might smooth the ride for my Felt. I ran across the Gravelking tires in 26c and am wondering if this might help? Pretty sure I could fit these. I watched a youtube review and the guy seemed to be saying they were much better over small bumps. Anyone have experience with these? Looks like the Gravelking sk comes in the same size and has more tread. If not gravelking any other options would be welcome.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
I have a number of bikes that run GK slicks. GK slicks tend to run narrow. You may be able to mount 28mm tires on your bike..they run 27mm or slightly under.
I've not run gp4000s so I can't offer anything there. The SKs are slightly knobby..probably not what you're looking for on the road, although they're surprisingly fast on pavement.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Are you running tubeless on your CX bike? That's prob why, plus bigger tires. How much pressure are you running in your GP4Ks? Chances are you could prob drop down a bit and still not pinch flat.
Likes For Rides4Beer:
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
Likes For datlas:
Quoted: 202 Post(s)
Liked 71 Times
No, it's an old CX bike and it running tubed 30mm tires. So not huge tires, but much more pleasant on the road than my road bike. I'm running 110 because I got a pinch flat running 100.
Likes For trailangel:
Quoted: 202 Post(s)
Liked 71 Times
Likes For BikingViking793:
jj
Quoted: 140 Post(s)
Liked 110 Times
Probably not.
I have GP5K’s and GK’s and the GP’s are definitely more supple. The GK’s area of shining is flat protection without being as resistive to rolling as Marathons.
The GK’s might be softer due to being able to run lower psi without worry of flatting.
Quoted: 202 Post(s)
Liked 71 Times
It looks like the max pressure is 105 for the GK so I wonder how low I could go and safely not worry about pinch flats? Now I'm also wondering if their 28C is really not very wide. The guy in the review felt the 26C were about the same width as his 25C gp4000.
Liked 8,925 Times
jj
Quoted: 140 Post(s)
Liked 110 Times
The one frame of mine for which 28’s are tight, the crown-to-axle is the limiting factor. Neither Corsa 28c nor Pasela 28c fit the front without jamming lots of debris up in there.
I weigh ~170lbs and my GK 32c’s on my geared bike are typically at 45F 50R Monday morning and when I get the “isht, I’d better pump them before I pinch them” they’re at 30F 35R.
My 28c’s I’ve got pumped to 50F 60R and they’re handling bunnyhopping on jaggled potholes streets just fine, however they are on wide-ish rims (Archetype) which does seem to affect the ride a bit.
Quoted: 202 Post(s)
Liked 71 Times
So I guess a little tread probably won't make much difference and it's all just tire pressure?
Quoted: 202 Post(s)
Liked 71 Times
Quoted: 759 Post(s)
Liked 810 Times
I think they are 17mm(?) The rims where I run 700x28s are H Plus Son Archetypes. Outer width is 23mm. I'm not finding and inner width online. By the look of the scale drawing on the H Plus site, it they aren't 17mm, they're pretty close.
"You didn't get the tube in there correctly. Not possible to pinch flat at 100 psi IMO."
I weigh 230 lbs and can verify that my experience is quite different. I have pinch flatted several times running 110psi on 25mm tires. Switched to 28mm tires many years ago and have not pinch flatted since. I run the 28mm tires from 90 to 100 psi. Continental Ultra Sport 2. Cheapo tires that last a lot of miles. If I rotate them every 1500 miles I get about 6000k from a set.
Likes For TiHabanero:
Quoted: 202 Post(s)
Liked 71 Times
https://www.panaracer.com/lineup/gravel.html
Quoted: 759 Post(s)
Liked 810 Times
Is the slick tire the Gravelking plus on this page? I don't see a slick reference.
Rather than wade through the GK site, the following are GK slicks. Bikesmiths also carriers 32-38mm sizes in anther link. They're prices are typically pretty good. I've picked up quite a few set from them in various sizes. The slicks are a tire with a metal-file type tread.
https://www.thebikesmiths.com/collec...12924455911458
Likes For fishboat:
Quoted: 202 Post(s)
Liked 71 Times
Panaracer is really expanding the GK line..you almost need a manual to figure out what you need.
Quoted: 202 Post(s)
Liked 71 Times
I just got a new battery for my caliper and I'm a bit surprised. My 25mm gp4000 are measuring just slightly over 28mm wide on my 17mm internal rims. I haven't ridden for a bit on them so the inflation is probably 100 or less. Is it because they are like 3 years old?
Quoted: 202 Post(s)
Liked 71 Times
So I got some 28mm Gravelking plus slick from the bikesmiths for a great price. The good news is I have plenty of clearance for them, but it's strange that they really are not very wide. I'm only getting about 26.55mm wide with my caliper at 90psi. It varies a little on different parts of the tire. I ment to double check the internal width of rim but forgot, but it is supposed to be 17mm. When I do the other tire I'll try to get it then. I measured my 25mm GP4000 again before taking it off and it was really wide. The width could vary quite a bit too. Went from just under 28mm to about 28.4mm at widest. So I'm still curious if a tire will widen and stretch out with miles and a heavier rider? The front gp4000 was a bit less wide and measuring around 27.5-27.75mm. It's cold around here but I'm gonna try a couple mile after I get the front tire on. Mounting was pretty average, not easy but not real hard either. Thinking I'm gonna try 95psi in back and 90psi in front. These tires have a max 105 psi so I'm hoping these can be run with less pressure than the gp4000.
Quoted: 202 Post(s)
Liked 71 Times
Because its so cold I only went for like a mile ride with about 90psi in both tires. Felt pretty good. Measured the internal on my rim and only got about 15.75mm which is odd cause the spec says 17mm. Will see how I like them in spring when I can do some big rides.
Measuring accuracy
BikingViking, do you have something you can measure that you otherwise know the dimension, to check your calipers? No offense intended.
Quoted: 202 Post(s)
Liked 71 Times
