Need 2nd opinion, can I still run this GP5000 till the TWIs disappear?
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Ride it as far as you're willing to walk, and as fast as you're willing to crash.
Likes For Ironfish653:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
The rubber tread provides traction and abrasion protection, not strength. I'm personally okay with cracks in the rubber, if the structural fabric is intact. But still, I wouldn't take that tire very far from home--maybe use it on a commuter--and replace it when you can, and when you can afford it.
Quoted: 6193 Post(s)
Liked 4,809 Times
Make your own decision. What would you do if there were not any wear indicators?
I've got no issue running till the first flat after the threads of the casing start to show. But if I was going to do an organized ride or some other ride that might be important or otherwise a challenging road environment I might change them before the threads showed.
Quoted: 2026 Post(s)
Liked 1,096 Times
I do the same with Vittoria rear tires but they never look that age hardened when they are worn down that far. Front tires actually wear very little but I replace them every two rear tires just because of age and exposure as a front flat or failure is worse than a rear. The OP's photo shows a front wheel and that tire must be OLD. It would have been replace way before this if it were mine.
Liked 4,809 Times
I was wondering why it looked that way too, but I was thinking they ride it while it's flat.
I wouldn't ride that tire fast or far from home.
And since I'm not willing to descend slowly, even when commuting, I wouldn't ride that tire at all.
If you cant afford to replace it get a cheaper one next time. Lots of perfectly fine tyres at 1/2 the price if you shop around a little. Id replace it.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
I ride them till they don’t show. I get at least 5500 miles on a set. I got 7k on the last 4000’s. I just got some of the aTDF with cream stripe look cool.
Quoted: 2604 Post(s)
Liked 1,933 Times
I'm hung up on why it looks so old; IIRC GP 5000's only been produced a bit over a year.
I'd probably take it for a short ride over some rough pavement (of which we have a lot, alas!) and see if I could wear the aged looking surface off. Then inspect it again and see if the wear indicators are still visible.
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Its fine, I'd keep going...
