2nd Hand Trek Madone 6.2 Safe to buy?
Hi Guys,
Have a chance to buy this bike, its a Trek Madone 6.2 from 2011 with a carbon frame and Ultegra groupset for 400USD. I have read warnings against buying used carbon frames. Unfortunately I will be unable to physically inspect the bike before buying, I can only rely on photos. Based on the picture of the shifters, looks like it might have been crashed?
Crash damage?
What do you think? Worth the risk or steer clear?
Crash damage?
Likes For Elvo:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
You can tear up the hoods and levers like that by having the bike tip over on you too. If you look at the value of the parts separately, how far behind are you if the frame is trashed? I'd still insist on a personal inspection, though I'm not seeing anything in the pictures that gives me immediate pause. Laying a bike down on its side is the 'best' way to crash a bike, vs. running headfirst into something or having your rear triangle hit.
Forum Moderator
Quoted: 3085 Post(s)
Liked 6,568 Times
If you are this apprehensive about buying the bike, don't buy it. Only buy a bike that you can inspect beforehand.
The dropped
Liked 1,014 Times
Yeah its 400 but its an auction site so it could be 400 for a reason I dont know. Would you still buy it if the frame was bad?
Unfortunately I cant personally inspect it. In your experience, what do you think of the damage exhibited in the photos? What kind of worst case would you think could be likely? What do you think is likely?
Expired Member
Quoted: 3657 Post(s)
Liked 5,393 Times
The groupset looks pretty clean except for the shifter. Usually the crank will be scuffed if it's had a lot of use. Personally, I would not buy a carbon bike of unknown provenance but not everyone has that level of concern. $400 isn't huge money so it's not a big deal.
Is it that much of a risk to buy 2nd hand carbon? I can see some other auction bikes that are Alu frames with Shimano 105's that look quite clean for the same price or slightly less. Is the risk with carbon worth just getting one of the Alu bikes instead? I ask because I have no experience with road bike.
The dropped
Liked 1,014 Times
There are other, additional areas to inspect for a carbon frame that we can't see. Depending on the construction, the dropouts could be aluminum bonded to the frame (I'm not familiar with the construction of this bike, consult with Trek's back catalogs if it's using bonded dropouts or integrated carbon dropouts). If they separate, that's the end of the frame. A sucked chain or a chain dropped to the inside of the cranks can be fatal for the frame, as carbon fiber is cut very easily that way. The thing is, few of these problems are without a similar issue on a steel or aluminum or titanium frame.
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
I dont see confirmed crash damage. I see wear and tear from normal use, plus a what could happen from a couple of bike tips while stopped.
The stem looks bad and scuffed, but its a stem. Just use some acetone and rub off the scuffed paint and itll look better than new since the paint design is fugly.
The right brake hood doesnt look good and it could be due to the bike sliding along the ground in a crash, or it could be from the bike falling a few times from being propped up poorly.
The chip in paint on the top tube is evidence that a 10 year old bike was ridden. Its a paint chip.
Quoted: 623 Post(s)
Liked 397 Times
I'm no expert on crash damage, but my shifters are pretty scuffed up from loading and unloading bike from the back of my vehicle.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
$400 isn't much a risk. I'd buy it if you like it.
Crashing isn't that big a deal. I've crashed every single one of my bikes multiple times and they're all fine except for one left shifter that somehow broke in half.
I'd probably buy it if I was needed a road bike for cheap. The components are worth more than $400.
