Frame Identification Game
Old 02-16-21, 03:24 PM
kansascity
Honorary Bicycle Rider
Bikes: N+1's
Quoted: 42 Post(s)
Liked 67 Times in 38 Posts
Frame Identification Game (1990's Giant Allegre)
I know for someone this be a very easy game, but I am interested in learning more about frame identification in general.
Clues:
  • Serial Number running parallel to frame is probably '6M019350' although it has been painted to make this much more difficult to decipher
  • Bottom bracket also marked with 'CB' in the Center
  • Under top tube at lug marking 'G2'
  • 'Swooped' at tire on front steel fork
  • Vertical Rear dropout
  • Downtube stops
Non clues include the entire 105 9 speed setup, the FSA headset, Promax seatpost, Nitto stem.
kansascity is offline
Old 02-16-21, 03:29 PM
Senrab62
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times in 147 Posts
Vintage trek is my guess. Early 90s-ish?
Senrab62 is offline
Old 02-16-21, 07:26 PM
francophile
PM me your cotters
francophile's Avatar
Quoted: 1137 Post(s)
Liked 588 Times in 420 Posts
When I saw that cluster, first thing I thought was Trek also, but I feel like some expected cues aren't there.
Have you run a black crayon along the BB shell to help highlight the "50" or whatever mid-shell, or the number off to the side?
francophile is offline
Old 02-17-21, 04:43 PM
juvela
juvela's Avatar
Quoted: 3801 Post(s)
Liked 3,324 Times in 2,170 Posts
steerer appears to exhibit internal splines/"rifling"
how many are there?
juvela is online now
Old 02-17-21, 04:59 PM
T-Mar
Quoted: 4722 Post(s)
Liked 3,036 Times in 1,874 Posts
I don't see any splines/rifling. It looks like there are four blocks that cast into the crown to act as a seat for the steerer tube insertion during fork manufacture..
T-Mar is offline
Old 02-17-21, 06:06 PM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 1438 Post(s)
Liked 1,052 Times in 779 Posts
I wonder can we draw @JohnDThompson
into this as the Trek expert? I agree the socketed stay caps/seat lug looks Trek-ish but that fork does not (to me, anyhow). And OFTEN you'd see the Trek logo cast-in to whatever the investment-cast piece in question (also not here)
unworthy1 is offline
Old 02-18-21, 06:41 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,393 Times in 1,927 Posts
It doesn't look Trek-ish to me. The Trek socketed seat lugs had shorter sockets, and the tang was on the side, not the back. The fork doesn't look like anything Trek used while I was there, at least (1980-86).
JohnDThompson is offline
Likes For JohnDThompson:
Old 02-20-21, 12:23 PM
francophile
PM me your cotters
May want to spend some time in this thread for other samples. There are a couple other fastback stays threads I've seen.
https://www.bikeforums.net/classic-v...eat-stays.html
Old 02-20-21, 09:24 PM
kansascity
Bikes: N+1's
Quoted: 42 Post(s)
The Mid-shell reads 'GM019350', although that first character could be a 6. I am going to pull the fork tomorrow and look for more markings.
Old 02-21-21, 07:28 AM
kansascity
Bikes: N+1's
Quoted: 42 Post(s)
Took the fork out this morning, but it did not provide any more markings.
What would the shape of this fork be called?
Old 02-21-21, 08:38 AM
T-Mar
OK, revised GM0 prefix for the serial number makes it consistent with Giant mid-1990 manufacture and the frame features match their Allegre model.
T-Mar is offline
Likes For T-Mar:
Old 02-21-21, 11:11 AM
kansascity
Bikes: N+1's
Quoted: 42 Post(s)
Thanks! Now if we just had more catalogs for 1990's Giant Bicycles.
Old 02-21-21, 12:11 PM
T-Mar
I do have price lists for 1990 and 1991 and a catalogue for 1992. In 1990 the Allegre was 2nd in a line of six road models. It cost $499-$550 US MSRP and was spec'd with SunTour GPX. For 1991 the component group was switched to Shimano RX100. 1992 was also spec'd with RX100 and the frame appears identical to 1990 except for a more elaborate paint finish.
T-Mar is offline
Likes For T-Mar:
Old 02-21-21, 08:04 PM
francophile
PM me your cotters
Unicrown.
Old 02-22-21, 06:04 AM
T-Mar
Unicrown.
While it looks similar, Unicrown forks use blades that are attached directly to the steering tube, eliminating the traditional crown. They are typically lighter, more rigid and less expensive than a fork with a traditional crown. Generally, they are TIG welded and the weld beads are plainly visible. The subject fork uses an investment cast crown. While I'm not positive, I believe this one is proprietary to Giant.
Personally, I just generically refer to it an an aero(dynamic) crown, as it is sheltered almost entirely behind the brake caliper with little area directly exposed to the airflow. Giant's literature calls it a "flat side, investment cast crown".
T-Mar is offline
Old 02-22-21, 08:51 AM
francophile
PM me your cotters
I never mind being wrong, as long as I learn something new
had to scroll back up to look really closely at that one. I now see the weirdness on the inside and lack of apparent weld, plus the round-out on the inside. Glad to hear it's apparently a one-off, I've definitely never seen anything quite like it from the inside view.
