A Friendly Gesture - Gifted an Early '80s Pro-Miyata
Old 02-17-21, 07:59 PM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
Liked 1,844 Times in 609 Posts
Hello folks!
This morning a gentlemanly friend of mine (a retired school teacher who rides in same circle as my uncle) asked me if I wanted his old Pro-Miyata, which he purchased new. It happens to be a 60cm frame which is close enough to my ideal size, and features some nice components, so I couldn't say no!
There's some surface rust around the bottom bracket, under the top tube on the seat post lug joint, and along the cable guides up top, and the decals are in fair to poor condition but still hanging on... Lots of grime but a lot of it wiped off during my quick inspection after getting it home. He said the only components he recalls replacing were the wheels, which now have Mavic MA 40 rims laced to sealed Suntour Cyclone II hubs. The front still spins nicely, but the rear freewheel was clogged up so I couldn't determine anything about the hub before I put it in storage.
Anyway, in storage it will stay for a while until I finish up a Mercian and a Carlton, but I haven't had a bicycle gifted to me in years and I feel honored that this fellow trusts me to do justice to his old steed, which he said he "easily did 100,000 miles on." I have no reason to doubt it!
I reckon it dates from between 1981-1983 based on a bit of research done on the forum and a PDF version of the 1982 catalog that I found online this morning. Anyone who knows better is welcome to chime in, please, as such bikes are not my usual cup o' tea! I'm also interested in confirmation regarding the model of the brake levers so that I can source some proper hoods... I believe they're an older version of the Dia-Compe AGC levers but don't match the 251s I've seen online, what with the little plastic bit on top, though another thread I discovered had someone refer to this exact one as AGC also. I'm also surprised that the headset is Galli. Is that typical for these? Cheers!
-Gregory
Kilroy1988 is offline
Old 02-17-21, 08:12 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1565 Post(s)
Liked 1,296 Times in 866 Posts
Very cool.
dddd is offline
Likes For dddd:
Old 02-17-21, 10:06 PM
67tony
67tony's Avatar
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times in 92 Posts
Yes, indeed, very cool to be rewarded for your dedication to, and appreciation for, vintage bikes. You will love the Superbe components. If it were me I'd swap to bar-end shifters, but of course your mileage may vary.
67tony is offline
Likes For 67tony:
Old 02-18-21, 07:40 AM
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 2422 Post(s)
Liked 4,395 Times in 2,092 Posts
Wow.
Your description set me up for a bike in much worse shape - but that thing is beautiful. A teardown, cleanup, and rebuild, some OA on the BB, and a few small sundries will turn that thing into a minty Pro.
-Kurt
cudak888 is offline
Likes For cudak888:
Old 02-18-21, 11:22 AM
Straightblock
Fast Old Guy
Straightblock's Avatar
Quoted: 145 Post(s)
Liked 672 Times in 177 Posts
Beautiful bike in one of my all-time favorite colors.
If the previous owner really put 100,000 miles on it, the headset could easily be a replacement. I would expect the Cinelli bar is not original and may have been changed when the bike was purchased.
The Hendrickson's Bicycles sticker brings back memories of many hours spent there in the 70's. My Colin Laing track bike was originally owned by Larry Hendrickson, the shop owner.
Straightblock is offline
Likes For Straightblock:
Old 02-18-21, 11:36 AM
tricky
Quoted: 634 Post(s)
Liked 444 Times in 298 Posts
That Sugino stem is pretty great! Congrats on your score!
tricky is offline
Likes For tricky:
Old 02-18-21, 01:56 PM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 1444 Post(s)
Liked 1,063 Times in 788 Posts
That stem looks like a "SR Super Light" but no, it's a Sugino, never seen one with that front "plug" before (velobase says it's a HP-GL and the one they have is a 25.4 bar clamp so "interesting" it's on Cinelli bars)! Very cool bike indeed and should be a very satisfying ride, the one problem area to be aware of is the brake pads for those "aero" Gran Compe calipers: unobtanium AFAIK. The Galli HS looks like a rebranded Stronglight A-9, not unusual to see and a very nice upgrade (but I may be wrong there also was a proprietary Galli HS and don't recall what those looked like). EDITS: no this does appear to be a re-branded A-9 but different in the GALLI brand is also on the cup and not just a pad-print on the top nut (much more typical). You got a PO who went in for some unique and high-end component upgrades, quite a nice gift!
unworthy1 is offline
Likes For unworthy1:
Old 02-18-21, 03:01 PM
squirtdad
squirtdad's Avatar
Quoted: 2338 Post(s)
Liked 2,827 Times in 1,543 Posts
83 looks about right https://www.ragandbone.ca/PDFs/Miyat...logue%2083.pdf
could be an 82 they are specced very much alike
83
squirtdad is offline
Likes For squirtdad:
Old 02-18-21, 03:47 PM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
Thanks for the comments, folks. I like how eclectic these bikes were right out of the factory... I've seen others with this Sugino stem so I'm sure that is original, and the Shimano 600AX seat post is purposeful but doesn't match any other parts on the bike! Interesting stuff.
I regret that it doesn't have the Superbe hubs any more but maybe I'll lace a set up to don't tubulars to keep around for special occasions... At least it has Cyclone.
I've decided that after I finish the touch up paint on my Mercian I'll let it cure for a few weeks before spraying the clear, so I'll get to tearing down and starting the restoration on the Pro-Miyata within a couple of weeks here. I'm excited!
-Gregory
Likes For Kilroy1988:
Old 02-18-21, 03:54 PM
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2298 Post(s)
Liked 2,055 Times in 1,255 Posts
It appears that the top-tube shifters may be standard, meaning not of the Symmetric family? I've never seen those.
clubman is offline
Old 02-18-21, 04:52 PM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
They look like these to me. Says Symmetric...
VeloBase.com - Component: SunTour Symmetric LD-2350 (Direct Mount)
Old 02-18-21, 05:12 PM
noobinsf
noobinsf's Avatar
Quoted: 1088 Post(s)
Liked 1,205 Times in 701 Posts
Yep, this style Symmetric came stock on my '82 Univega Competizione, a very similar Miyata-produced bike. Great bikes...
noobinsf is offline
Likes For noobinsf:
Old 02-18-21, 05:28 PM
clubman
Phyllo-buster
clubman's Avatar
Well there you go. That's gotta be the last thing I don't know!
clubman is offline
Likes For clubman:
Old 02-18-21, 09:15 PM
polymorphself
Quoted: 838 Post(s)
Liked 1,082 Times in 522 Posts
83
Frame sizes listed in mm?
polymorphself is offline
Old 02-18-21, 09:51 PM
jeirvine
jeirvine's Avatar
Quoted: 786 Post(s)
Liked 520 Times in 281 Posts
Nice. I spy a 41t chainring too.
jeirvine is offline
Old 02-19-21, 12:05 AM
gugie
Bike Butcher of Portland
gugie's Avatar
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,801 Times in 2,285 Posts
Ha! When I saw the shop sticker on it I was thinking of you. I bought my first pair of cycling shoes there. I believe they were Lambertini "handbuilts". Buddy of mine got a pair of Detto Pietros at the same time.
gugie is offline
Likes For gugie:
Old 02-19-21, 11:04 AM
Straightblock
Fast Old Guy
Quoted: 145 Post(s)
My first shoes came from there, too, also Lambertini. First shorts and jersey in the same purchase.
Old 02-19-21, 11:22 AM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
Rusty mentioned Larry and his shop when I went to pick up the bike and said I would have loved it there. Rusty's from Reedley but apparently he spent enough time at Hendrickson's to have fond memories!
-Gregory
Old 02-19-21, 01:30 PM
gugie
gugie's Avatar
I remember those shoes had super supple leather, fit like a glove. I believe I got the advice to put them on, hose 'em down with my water bottle, and they'd shrink fit exactly to my foot.
First shorts were wool + real chamois, I'm pretty sure I got them there as well.
Might have run into you at some point after you were finished making the mods to my Raleigh Super Course MkII over at Big Wheel. ;-)
gugie is offline
Old 02-19-21, 05:01 PM
due ruote
due ruote's Avatar
Quoted: 904 Post(s)
Liked 527 Times in 320 Posts
Are those seat stays unusually beefy, or is that an illusion?
due ruote is offline
Old 02-19-21, 05:08 PM
Kilroy1988
Kilroy1988's Avatar
Quoted: 981 Post(s)
They certainly look wider than classic "pencil stays" to my eye. When I get the bike to my apartment for the restoration I'll measure them compared to a couple other frames I have handy.
-Gregory
Old 02-19-21, 05:09 PM
SurferRosa
señor miembro
SurferRosa's Avatar
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times in 3,211 Posts
You can call it gentlemanly or friendly, but I can also agree with insane.
SurferRosa is offline
Old 02-19-21, 05:12 PM
unworthy1
unworthy1's Avatar
-Gregory
per the catalog specs they are "aero seat stays" and "oval chain stays" so probably shaped somewhat for cutting wind resistance.
Old 02-19-21, 05:55 PM
jet sanchEz
jet sanchEz's Avatar
Quoted: 947 Post(s)
Liked 850 Times in 386 Posts
Lovely
Small looking 60, almost looks like a 58
jet sanchEz is offline
Likes For jet sanchEz:
Old 02-19-21, 06:27 PM
TiHabanero
Quoted: 1746 Post(s)
Liked 1,376 Times in 721 Posts
Although I raced the next generation Team Miyata with splined tubing, the gold head tube and long point lugs are my favorite gen race bikes from Miyata. My buddy raced a 60cm Pro Miyata circa 1983 and I was on an 86 Team Miyata. Something about the color in the sun along with that gold head tube just had it going on. I will say the Nuovo Record on my bike did run quieter than the Superbe on his bike, and it always bothered him.
TiHabanero is offline
Likes For TiHabanero:
