Help -- Can't figure out foot pain on sides
I’m tracking down shoes that don’t cause shooting foot pain at 30-40 miles on the outside side of my feet -- from the small toe down about half my foot. I didn’t get far last year before shoes were out of stock and I just got stuck. I’ve been taking really good notes along the way. I'm using SPD pedals/shoes. Here’s everything I’ve tried so far below.
Started with shooting pain in my Sidi 46 wide MTB shoes (I used a heel piece to move up a bit because I knew the shoes were slightly big). I used to wear a size 11 running shoe, but switched just before getting the Sidi 46 Wides to a 10.5 wide and it helped my everyday foot comfort. 10.5 regular running shoes hurt like my bike shoes do.
After my Bike fit, realized my shoes were way too big. Went back to my old MPD Louis-Garneau 46 regular shoes, which fit smaller. With shifting cleat position around, I was able to clear my left foot pain at 40 miles. Bike fit also showed I should wear like a 44.
Did a shoe fit at Fleet Feet. They show me as a left foot 10.6B and right foot 10.4D – balls of both feet solidly narrow.
Tried Specialized Recon 3.0 Size 44 regular from a LBS. These destroyed my feet all over. Numb and red lots of places.
Tried a friend’s Sidi 45 regular width. Squeezed the sides of my feet.
Tried a Specialized Recon 2.0 45W – Specialized shoe pad says 45. Playing with cleats got me about what I had with the LG’s – left foot ok. But right still shooting pain.
Tried the Bikefit.com app to figure out varus. Left and right are 15-16deg tilt. Tried various cleat wedges instead of the specialized insert wedges with my LG’s. Started having some knee pain with cleat wedges. And not much foot help.
Printed out a Sidi sizing chart and tinkering around with measurements. Sidi says I’m a 43.5 NARROW!.
Some questions to me: Why do all the measurements say I’m a narrow? This makes no sense based on experience. Would a different style of pedal help at all? Look?
What would you try next? Thanks a lot!
Quoted: 6193 Post(s)
Liked 4,809 Times
30 to 40 miles and foot pain on the balls of my feet used to be a little bit of swelling in a snug fitting shoe. I started wearing some socks that give my foot a little bit of compression and that seems to have ended that annoyance for me. I like Swiftwick. They are thin enough not to compete with the cushioning already in my shoes.
If the socks aren't a pain in the butt to get on and off, they probably aren't doing enough compression for your foot. IMO. Or you are just younger and more flexible than me. <grin>
Quoted: 18883 Post(s)
Liked 10,646 Times
You said foot pain on the sides, I looked and didn't see which sides, forgive me if I missed it. Inside of the feet or outside?
Foot pain on sides ... if on the outside, could be tailor's bunion.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Sidi shoes are super narrow, and their "wide" shoes are normal width at best. I can't fit properly into any of their shoes and I get pain on the edges of my soles when I try (is that what you mean by "sides"?). Shimano makes a wide width that works for me. FWIW I wear a 11 or 11.5 E width running shoe and fit a 45 wide Shimano shoe just fine. North Wave also fits well.
It's like riding a bicycle
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
That sounds about like what I felt when I rode on Sidis and it turned out my foot was kind of hanging over the edge of the sole (best way I can find to describe it). Wider shoes (and the Sidi Mega didn't cut it for me) fixed the problem.
Likes For urbanknight:
Quoted: 850 Post(s)
Liked 344 Times
Try cleat wedges. That used to happen to me too. You're probably forced to tilt your foot to keep your knee alignment correct. I bet if you try to relieve your foot pain, your knee ends up tracking inwards and brushing the top tube.
another solution is to set your feet farther apart but that isn't as comfortable as having your feet right under your knee.
Quoted: 20810 Post(s)
Liked 9,456 Times
Most of the "wide" cycling shoes aren't actually wide - they're high volume. Try something that's actually wide - I'd start with Lake and doing the measuring/sizing as outlined here - https://lakecycling.com/pages/sizing-charts
Quoted: 741 Post(s)
Liked 412 Times
Outer foot pain could be a lot of different things, or combinations of things. For me ditching the varus wedge and moving the cleat back and a wider Q factor worked. If your feet are trying to be in a place they aren't able to be, shoes wont matter.
Shoe manufacturers can only get you into the ballpark of their lasts. So you may be a narrow in one and normal in another, or whatever.
Bikes: 2014 Cannondale Supersix EVO 3, 2015 Trek 520, 2017 Bike Friday Pocket Rocket, 2022 Moots Vamoots Disc RSL
Quoted: 285 Post(s)
Liked 267 Times
Just guessing, but here are a few suggestions:
1. If you are getting different shoe size measurements, make sure you always measure your size when you have weight on your feet for consistency. Also, not all shoe makers follow the standardized size charts accurately.
2. Pain from the little toe to the middle of the outside of your foot may be a tailor's bunion, as previously stated. Also: if the pain is radiating (electric like or funny bone like) it may be the local nerve being compressed between the bone and the shoe. This happened to me with a pair of running sneakers once. A week after I got rid of those sneakers, the pain went away.
3. If the pain is on the bottom of the outside of the foot, make sure there is no lip (thicker liner) along the outside of the bottom insert to the shoe. In other words along the perimeter of the insert. If there is, it may be pressing against the outside bottom of the foot causing pain. Thin it out even with the rest of the insert with either a knife or scissor if it's thicker.
4. Try a shoe with a more flexible upper material so it's not pressing so hard against your foot.
I recommend that you look for LAKE shoes. I recently purchased the CX241 for road cycling. I was in pain and numbness after riding for more than 4 hours and allegedly this sort out the problem. I am waiting for them to arrive.
