Show us your Campy Triples
#76
Quoted: 4722 Post(s)
Liked 3,038 Times
I always been of the opinion that Campagnolo reluctantly gave in to pleading from the consumers/shops/bicycle manufacturers and provided triples. Regardless, my only triples are on my ATBs and none of those are Campag, so no pics.
#77
Quoted: 4512 Post(s)
Liked 6,386 Times
#78
only here for the "LIKES"
Quoted: 1643 Post(s)
Liked 2,239 Times
#79
Liked 6,386 Times
I get that, but that is an original triple with the short flutes for the factory holes, should have been left alone imho, may or may not be weaker now as well.
#80
Quoted: 765 Post(s)
Liked 660 Times
Yeah, two sets is overkill.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
#81
How long of a bottom bracket spindle is everyone using for the NR triples?
#82
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Sorry, missed your question before. I think I used a 122,
My Bikes
My Bikes
#83
Bikes: Yes
Liked 3,868 Times
This weekend I finished rebuilding the bike whose components are seen in the first post.
Now I don't have to walk up the mountain of which I am king.
The best part is the bike actually ended up a little lighter with these components than it was with the double. Take that weight weenies!
My Bikes
My Bikes
#84
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Dang, 21.2 lb?!? That is incredibly light given the components (triple crank, long cage RD) and capability (summiting Everest). How is the Syncro (or Syncro II) working out for you?
#85
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
#86
Bikes: Yes
Liked 3,868 Times
I've only used the current set up for around 18 miles, but it's working great. The shifters are Syncro II Veloce 8-speed. Did I mention that I'm using a Shimano rear hub and a SRAM cassette with this? So in theory the spacing is off by 0.2 mm. I biased the shifting toward the big cogs, so they're working excellently. On the stand the smaller cogs worked pretty well too but there was sometimes a bit of a hiccup on the transition from the smallest cog to the next smallest. I didn't have occasion to try that on the road, and rarely will. On the road I didn't have a single hitch. I expect that with a properly spaced cassette it would be perfect across the range. I also have a theory that I could switch the indexing gear and run this 9- or 10-speed. I don't have any plans to test that, but if another set of these shifters fell into my lap I might try it.
Since I'm talking about my experiences with Syncro shifting on this bike, let me say that it came to me with first generation Syncro shifters (the ones with the extra lever to put them in friction mode), what I believe is a first generation C Record rear derailleur, a 6-speed SunTour freewheel, and (I think) a Sedis chain (says "PG" and "France" on the links). The clicks on that setup were a bit mushy, but the indexing was great. I rarely use friction shifting, so if the lever wasn't picking the right spot for me I'd notice. Again, it was a small sample size (20 miles) but I thought it was great. I have a suspicion that Syncro gets a bad rap because many people weren't aware that they needed to use Campy's secret decoder tables to select from among the seven different indexing gears to make it work. Or maybe some of the combinations just didn't work as well as others, but as I recall the tables want to know not just which derailleur you're using but also freewheel and chain.
My Bikes
My Bikes
#87
Liked 2,024 Times
Great to hear! I have a tired C-Record Chorus groupset with Syncro II that I had to do a lot of work to de-gunk, clean, polish, and readjust. I sold the Monoplanars that came with it and am not super sad about that. The brake levers have no hoods now as they were toast when I got them. Still, I should put a bike together with them and test them out. I had to dig out the petrified grease and dirt from within the indexed shifter (ok, both, but the right shifter had more nooks and crannies), but I was successful and put new used G-springs in and mounted it on a frame to test the indexing. Indexes very well. Sure, Shimano's lever angle change from cog to cog is a lot more consistent, but the Campy unit gives positive shifts. No telling yet how it does when hooked up to the A/B slant parallelogram position Chorus RD. Actually yes, I know just the frame I'd build up (and likely sell to make more space) and have go to a new home...
#88
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Quoted: 267 Post(s)
Liked 334 Times
#89
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
I’ve got a 9 & 10sp triple.
9 on the Batavus: Veloce brifters, Centaur crank + RacingT ders.
#90
Bikes: Yes
Liked 3,868 Times
#91
Veteran, Pacifist
Liked 4,836 Times
Also my ergo favorite shifter, with bars that allow a long flat ramp.
Triples take me anywhere.
#92
1988 Italian-made Puch
Here’s my 1988 Puch - I think this is the first year that Bianchi had the brand. Originally came with first generation Chorus but now sports 8 speed Racing T with Record bits. Tubing is SLX. Stem and bars are Cinelli. Thanks to the several BF C&V members who contributed to her new jewelry ☺️
#93
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
#94
Quoted: 910 Post(s)
Liked 288 Times
I disagree. Sram hasn't supplied road triples for many years. Shimano never made triples with modern 11 speed systems, but you can get lower range triples still. Only Campagnolo made lightweight triples for 11 speed systems.
#95
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
Hello All, I want to replace my 30T chainring , on my Campy triple , with a Sugino 28T 74mm BCD. Question, for those who may have tried it, is there any shifting issues , with the FD picking up the 28T to the 42T (My setup is 30/42/52) ? Thank you. KB
#96
I have this bike, 1973 Paramount, with the Campy Triple.
Does anyone know which company first offered a bike with a triple stock?
#97
Liked 6,386 Times
I have this bike, 1973 Paramount, with the Campy Triple for sale on Ebay
https://www.ebay.com/itm/202609948683
Its one size too tall for me, I would consider trading.
Thanks,
Chris
Thanks,
Chris
and1homer
Road Cycling
30
08-09-12 02:08 PM
Ritterview
Bicycle Mechanics
26
03-30-10 09:20 PM
