Need a longer rear axle and cones for a 79 Raleigh Competition GS
Old 03-03-20, 06:44 PM
tammons
Quoted: 46 Post(s)
Liked 3 Times in 3 Posts
Before I order something, I though I would ask.
I am going from 120mm rear to 126mm rear and would like a new axle. 6mm longer than the factory axle.
One rear cone is pitted, so I might as well replace them all back and front, but have no clue where to source them.
Thanks
tammons is offline
Old 03-03-20, 06:56 PM
alcjphil
alcjphil's Avatar
Quoted: 1813 Post(s)
Liked 1,691 Times in 972 Posts
What hubs? I am only familiar with earlier Competitions that I seem to remember had Normandy hubs. I upgraded the Normandy hubs on my Peugeot UO8 with cones for Campagnolo hubs. The cones you need to look for will depend on the hubs that were used to build your wheels. Of course, you will also have to redish your wheels when you go from 120 to 126 spacing
alcjphil is offline
Old 03-03-20, 07:54 PM
tammons
Quoted: 46 Post(s)
The hubs are factory Campagnolo Gran Sport small flange.
tammons is offline
Old 03-03-20, 08:03 PM
Mad Honk
Quoted: 1295 Post(s)
Liked 1,882 Times in 1,132 Posts
Look for a donor hub or parts on Flea Bay; right now there are a couple in the cue. Smiles, MH
Mad Honk is offline
Old 03-03-20, 08:15 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,834 Times in 2,293 Posts
IIRC the GS version speced Campy Gran Sport hubs. So the rear hub would use a 9.5mm by 26TPI axle. Unless the wheels are not stock or "specifications may have been changed". Wheels Manufacturing makes a range of axles and they are available on line and at better bike shops. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 03-03-20, 09:24 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,391 Times in 1,927 Posts
Campagnolo rear hub axles are 10mm x 26tpi thread. Wheels Mfg offers replacement axles in this thread spec. in 141mm length for 130mm OLD spacing. You'd need to trim the axle a bit for 126mm OLD spacing, but that's a couple minutes work with a hacksaw.
https://wheelsmfg.com/products/hub-p...s/axle-08.html
JohnDThompson is offline
Old 03-03-20, 09:37 PM
tammons
Quoted: 46 Post(s)
Thanks. Yes I measured and it is 10mm.
tammons is offline
Old 03-03-20, 10:59 PM
Andrew R Stewart
John- You are correct. A memory slip on my part. Andy
AndrewRStewart
Old 03-04-20, 08:12 AM
Iride01
Iride01's Avatar
Quoted: 6163 Post(s)
Liked 4,779 Times in 3,297 Posts
How long is your original axle? I went from 5 speeds to 7 on the rear of mine years ago and used the same axle. I only needed to add a spacer to get the freewheel clearance from stay or dropout. My axle measures 133.something mm.
Iride01 is offline
Old 03-04-20, 08:44 AM
tammons
Quoted: 46 Post(s)
My rear axle is a tad over 127mm.
tammons is offline
Old 03-06-20, 04:54 PM
oldbobcat
oldbobcat's Avatar
Quoted: 512 Post(s)
Liked 444 Times in 334 Posts
Take your axle and cones to your local bike shop and tell them what you want. If it isn't in stock they should be able to order a replacement from QBP and get it in a day or so.
oldbobcat is offline
Old 03-09-20, 08:08 AM
Mr. 66
Mr. 66's Avatar
Quoted: 1134 Post(s)
Liked 1,726 Times in 950 Posts
I would only replace what is needed.
Mr. 66 is offline
