Downhill technique: Flairing one's knee
#51
Quoted: 4806 Post(s)
Liked 3,928 Times
If you have your weight on a pedal and that pedal is down, you are basically hanging yourself from the BB, effectively your weight is acting on the bike as if it were lower than the bottom bracket. Outside pedal is strongly preferred because at high lean angles there is on danger of the inside pedal scraping. If you descend with your cranks horizontal, now your weight on the BB is acting right through the BB, not acting as if it were lower.
Likes For 79pmooney:
#52
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
It's good semantics. It's useful and accurate to call this countersteering. Even if you're not moving the bars past the straight-ahead alignment to change lean angle*, you're still moving them in the opposite direction of your desired lean angle change.
*I think at high speeds you are usually moving the bars beyond the straight-ahead alignment to increase lean, but at slow speeds you might not. This is much easier to analyze on a motorcycle where you can explore this physics for hours on a winding road or a track.
I've been on a bicycle which oversteered, a relatively new Giant. A friend lent it to me to make a long somewhat technical descent and I had a heckuva time with it. I remarked on it later and the owner had no idea what I was talking about. We get used to how our bikes handle.
Results matter
Results matter
#53
Liked 3,928 Times
Not entirely true. You can use an outside force to initiate a turn. I used such a force when a Jeep pulled a right turn on me when it was right beside me as I was going straight through the intersection. We got so close the jeep wheel nudged my fork, initiating the lean I needed to make the turn.
#54
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
If you don't think you countersteer through corners, fine. You don't. I've never ridden with you, and chances are slim that I ever will, so I can't show you what the rest of us are talking about.
Quoted: 3949 Post(s)
Liked 7,295 Times
What is to be gained by continuing this? Do you think you're going to change my mind? Somehow convince a guy that's been racing for the last 24 years that he's wrong about how to go fast on a bike? I'd be happy to post a shaky GoPro video of me descending a 3600' mountain at 1.5-minute pace off of the record (that I hold).
If your answer is no, then we have no disagreement. If your answer is yes, then I'm going to state that you are wrong.
These things have been studied, and they have been measured. Below is a measurement of a right hand turn followed by a left hand turn, where the third plot is the angle of the handlebars. You can clearly see counter steering as a downward spike at about 15 seconds, with the bulk of the right turn (region marked by the arrows) occurring from about 25-55 s. During the turn, the handlebars are turned to the right, in the direction of the turn. (In this case, the angle is about 8° for a turn radius of about 9 m at a velocity of about 11 mph.) You can see counter steering again at about 75 s for the left hand turn, with the bulk of the turn ocurring from about 90-130 s.
Likes For tomato coupe:
#56
Jedi Master
Likes For kingston:
#57
mechanically sound
Jobst was convinced that the knee flare was just habit, didn’t contribute to the bike’s control. I believe in the whole countersteer thing because it has been proven,but visualizing it is hard.
Likes For DaveSSS:
#59
Liked 7,295 Times
The handlebars must be turned in the direction of the turn after counter steering initiates the turn. That is easily proven.
#60
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I have no doubts that you have a lot of race experience. But, that doesn't mean you are correct with the physics of this. I have a lot of physics experience, and I also rely on the what I have taught by my coach, who has a lot of racing experience at the highest level.
You didn't answer my simple question: "Are you stating that your bars will turned to the left during the entirety of a right hand turn?"
Last edited by tyrion; 03-10-20 at 05:08 PM. Reason: changed "arc" to "turn radius"
#61
Liked 7,295 Times
Speed is a factor here. At higher speed you need more lean for the same arc. As the bike leans, the tires act like rolling cones and provide the turning forces and less handlebar turn is needed for the same arc. At higher speeds you can actually be turning right with the handlebars turned slightly left.
#62
Liked 2,011 Times
You can calculate the steering angle if you know the lean angle, the turn radius, and the wheelbase of the bike. Speed only comes into it via the lean angle, and there is no lean angle that causes the steering angle to go negative. (This all assumes the back wheel isn't skidding.)
#63
Liked 7,295 Times
Here's some easy experiments: Lock your handlebars straight ahead with some tape. Push the bike, lean it to the right, and see if it turns to the right. Lean it to the left, and see if it turns to the left. Next, lock the handlebars a little bit to the right, lean it to the either side and see which way it turns. (Obviously, you should push the bike, not ride it.)
#64
Many amusing responses above. Calculations don't mean squat. Take a motorcycle training course. My instructor was a motorcycle cop for over 20 years. He knew how to turn a bike. Push on the right side to turn right (counter steer). Quit pushing and the bike will straighten up. I passed the course, bought a motorcycle and took it up and down twisting mountain roads with little experience. His instructions were absolutely correct. A bike won't turn unless you're pushing on one side of the bars. Otherwise it will go in a straight line. At very low speeds, the steering is normal - turn the bars right to turn right.
#65
Liked 7,295 Times
#66
Quoted: 8279 Post(s)
Liked 9,033 Times
I've actually ridden 3 motorcycles that were lighter than I am. I do feel that most, if not all, techniques are similar.
#67
Quoted: 645 Post(s)
Liked 797 Times
This - if you look at racing motorcyclists cornering hard, they don't just drop their inside knee, they shift their whole body over, so their ass is hanging off the seat on the inside. By shifting their center of gravity to the inside, that can keep the bike as upright as possible and maintain maximum grip in the corner. Cyclists can't do that - if the outside pedal is down and their outside leg is at close to full stretch, they couldn't shift off the saddle even if they wanted to, but their inside knee drops and I imagine they shift as much body weight to the inside as possible to achieve the same thing - move the COG of the rider/bike combination to the inside, so that the bike can be held as upright as possible to maximize grip.
#68
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
#69
Quoted: 562 Post(s)
Liked 64 Times
#71
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Roll downhill, put out a knee, see where the bike wants to go... that's why it's done. In fact you can to a large extent steer by just moving the knee in or out.
Likes For sfrider:
#72
No one has claimed that bicycle and motorcycle steering is identical, but the basic principles of how the steering works are the same. There is no need to flare a knee when proper steering technique will accomplish the same thing. I've ridden the same winding mountain roads on both bicycle and motorcycle. A motorcycle takes a lot of deliberate effort to turn and is much more tiring. One big difference with a motorcycle is the ability to ride at higher speeds both up and down a mountain, so the need for constant countersteering is obvious.
All the talk of what road racing motorcycle drivers do is irrelevant. That won't be discussed in any class geared toward safe riding techniques on city streets and highways. Race coarses are often made with special asphalt that creates better traction and they won't have sand on the road like a real winding mountain road. Motorcycle or bicycle riding in the mountains requires a careful watch for rocks and sand at all times.
#73
When you enter a right turn you first countersteer to move the bike that sits under you to the left (which means you start falling to the right, since you moved the bike left, but your body kept going straight because of inertia). As you start the turn, your mass will pull you outwards, so what you do to avoid kissing the ground is use the handlebars to keep the bike in a delicate equilibrium that equals the centrifugal force that's pulling you outwards while you turn, with the gravity that's pulling you to the ground. As you exit the turn, you just steer harder to the right until the bike is under you again.
This means that it's impossible to counter steer the whole turn unless your rear tire is partially skidding. In a tight turn, you probably countersteer only to enter the turn, while on a wide one it's possible to countersteer partially through it, but not during the whole turn.
Likes For Amt0571:
#74
Jedi Master
MotoGP racers lean off the bike in corners to keep the inside peg from dragging on the ground. The suspension also works better when the motorcycle is more vertical which helps a bit with traction. Motocross racers don't have the problem of the inside peg dragging so they actually lean to the outside of the corner to make the bike lean more than the rider. I watched a few fast bicycle decent videos, and they seem keep their bodies pretty much aligned with the angle of the bike, so I'm not sure how relevant the motorcycle leaning comparisons are. I did see a number of cyclists flare the inside leg, but only on tight corners. Looks to me like their leg just naturally does that as they look around the corner with their outside leg down.
#75
This affects cornering because more mass means more inertia, and in this comparison, mass is placed at vastly different locations, which affect the CG among other things.
Likes For Amt0571:
