Tire pressure, how often do you fill up?
Bikes: 2021 Litespeed T5 105, 1990 Gios Compact Pro 105
Quoted: 167 Post(s)
Liked 325 Times
I use my pump to check my tire pressure, and normally I fill it up before every ride. Lately, I've gone 2 rides (consecutive days). Do tires lose enough pressure from one ride and the time until the next day's ride to need a fill up every day?
I also figure the very act of checking your tire pressure makes it lower.
Wider with Heavy Duty ,Thorn resistant tubes, quite infrequently .
OTOH, super thin high pressure containing tubes, more frequently,
checking often..
checking often..
Non omnino gravis
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Depends....
Not all tires and tubes lose pressure at the same rate.
Also, you tend to lose pressure faster at higher pressures.
Also, some applications demand more specific pressures than others.
I go several weeks without topping off the air in my commuter bikes, but I check and adjust every ride for mountain biking.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
It depends on your tires and tubes. Low pressure tires and thick butyl rubber tubes hold air well on my Raleigh 3-speed. Narrow tubulars with latex tubes lose pressure quickly and need to be topped off before every ride. And if you last filled the tube using a CO2 cartridge, check again before you ride, as rubber is more more permeable to CO2 than to plain air (mostly N2 and O2).
Quoted: 5224 Post(s)
Liked 3,581 Times
Typically, b4 every ride.
Quoted: 2432 Post(s)
Liked 638 Times
If you don't want to take 30 seconds out of your life to check the pressure, at least give the tires a squeeze to make sure you didn't get a slow leak overnight.
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
It depends on how thick your tubes are, too. Thick tubes and/or lower pressure keeps air longer.
I often don't check if I rode the day before. (Yes, squeezing the tire to verify it's still full is a good idea.)
Two days later: yes, it's often 5-10 psi down.
Squeezing:
I squeeze the sidewalls together with finger and thumb. I get a better idea of the tire pressure this way, instead of pushing on the tread with a thumb. (Do it a few times after inflating with a floor pump to see how a full tire feels.) And this is how I decide if there's enough pressure after fixing a flat.
Squeezing:
Bikes: Brompton, Time, Bianchi, Jan Janssen, Peugeot
Quoted: 598 Post(s)
Liked 5 Times
Don't check pressure as such, apply the pinch test before every ride on the road bike and inflate on a weekly basis. On the Brompton, only about once a week and inflate about once a month. The difference, as some have noted, is the road bike has high pressure, thin tyres and does drop a few pounds relatively quickly, whereas the Brompton has lower pressure and does not.
Quoted: 2281 Post(s)
Liked 1,710 Times
If I don't make an effort to pull the air compressor (with the gauged inflator) out of the garage, I'll at least give the tires a squeeze with my thumb before my daily morning rides. But before a long ride I'll always make sure they're up to where I want them.
Quoted: 167 Post(s)
Liked 325 Times
Thanks everyone. They're 700c / 25mm Vittorias. I eyeball the pump gauge and fill them to near 100psi.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Generally go two-three weeks before refilling. Always give them a quick squeeze before leaving. When they need it, I pump them up to the max and let them bleed down to min, except for my Travel Contacts which are far more susceptible to low pressure.
All my tubes vary slightly. Even the ones from the same mfg in the same size can bleed at a different rate.
Bikes: Look 566 - Raleigh Mountain Deore (1988)
Quoted: 1027 Post(s)
Liked 325 Times
For my commutes, every couple of weeks (I'll check to make sure they aren't flat before each ride). For my "serious" rides, I'll check and fill the tires before each ride.
Quoted: 18373 Post(s)
Liked 4,507 Times
I usually fill up to a bit over 100 PSI (23 or 25mm tires), then typically will ride for a couple of weeks before refilling, probably letting the pressures get down into the 70's or 80's.
I do a thumb test periodically, and have a slow leak on one trailer tire, and perhaps the rear of my road bike (nearly fast enough on the road bike to require refilling while out on a ride).
Quoted: 3352 Post(s)
Liked 1,056 Times
Before every ride. If down more than a pound or two, it indicates a small leak that I can address at home.
Fredly Fredster
The tires/tubes on my road bikes hold air at 100psi pretty well. I can get 2-3 rides out of them in the summer and fall before having to pump them up again. Winter and early spring, I have to pump them up more often.
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
Every ride. Now that I ride lower pressure, I don't want it dropping too far below the initial inflation. Helps to have a pump with a slip chuck (Lezyne), makes it all the faster to re-inflate.
