Schrader to Presta conversion
Quoted: 8 Post(s)
I would like to convert from using schrader tubes to presta tubes. I know when doing the opposite you have to drill out the rim. Is there anything I can do to convert back? Is there some sort of adapter? Thanks for the help!
Quoted: 741 Post(s)
Liked 818 Times
Quoted: 1074 Post(s)
Liked 295 Times
I’ve never used anything, apart from, possibly, poking a smaller-than-average sized hole in the rim tape.
If you want to use a grommet or adaptor of some sort, it’ll have to go on the tubeside face of the rim to do anything good as a valve saver.
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 344 Post(s)
Liked 266 Times
Try EBay here: https://www.ebay.com/itm/SUNLITE-Bic...QAAOSwldlcy4HZ
Quoted: 8 Post(s)
SE Wis
Quoted: 2741 Post(s)
Liked 3,388 Times
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4335 Post(s)
Liked 2,977 Times
Non omnino gravis
Likes For DrIsotope:
Quoted: 4722 Post(s)
Liked 3,036 Times
I found some rubber grommets at my hardware store that worked well in this application. They had an inner diameter of 1/4" and were designed to fit a 5/16" hole.
Likes For T-Mar:
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,287 Times
If you live near any smog-infested area, note that any air gap that exposes the tube to the rush of outdoor air can cause cracking and failure of the rubber tube. I see this a lot here in CA.
I like the idea of an extra layer of Velox tape at the valve hole with a well-centered hole in it to support the rubber at the base of the valve, as this is a common failure point for any Presta tube. Fortunately, Velox is normally already doubled at the hole where it overlaps!
If the hole in the tape is a tight fit on the threaded valve stem, the tube rubber will be protected from exposure to smog/ozone that would attack the rubber. A stepped nut can then be used to center the valve and present a finished appearance, but should not be heavily tightened as that would try to tear the stem from the tube.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Is there a specific reason that you want to convert to presta?
I prefer the look of presta valves and like the function of the valve. However, I found that schwalbe makes Schraeder tubes that have much nicer valves than the typical ugly rubber ones.
Aside from that, I love schwalbe tubes in general.
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,695 Times
Hey, are those Merrell's?
Commence to jigglin’ huh?!?!
Quoted: 5888 Post(s)
Liked 3,471 Times
I sometimes just use the adapter that comes with the tubes as per post 9 many (most?) are not stepped. Sometimes I find a washer that goes under between the adapter and rim. It helps keep the tube from moving which may lead to the tube failing.
Quoted: 18353 Post(s)
Liked 4,502 Times
I don't know if they really do anything, but they look good.
Note, most rims are double-walled, and that nut only covers the outer wall.
Sullalto
Bicycle Mechanics
14
11-09-14 07:26 AM
dabac
Bicycle Mechanics
18
04-10-14 02:55 AM
bobotech
Bicycle Mechanics
24
06-27-12 06:00 PM
Closed Office
Bicycle Mechanics
15
12-02-11 09:46 PM
