Saddle Height For Mashing Vs Spinning?
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Does the optimal saddle height depend on whether you are mashing or spinning?
Define mashing as pedaling with higher force in a higher gear and lower cadence. For example, you are climbing a 4-5% grade in 53 x 17 at around 60 rpm. When I do this, I find that I tend to slide back on my saddle to get more leg extension and I'm also actively pushing and pulling.
Define spinning as pedaling with lower force in a lower gear and higher cadence. For example, you are climbing that same grade but have shifted to 39 x 21 at around 100 rpm. When I do this , I'm usually forward on the nose of the saddle.
This makes me wonder if mashing rewards a higher saddle and spinning a lower saddle?
Quoted: 41 Post(s)
Liked 11 Times
I would think the opposite. As you pedal with more force -- especially uphill -- the tendency is to drop your heel . . . which, effectively straightens out your leg. So you may be losing power. To check, you should do some uphill repeats. Start with the seat 1 cm lower than you have it now. Go up a short hill, and repeat several times with the seat 5 mm higher each time. Keep an eye on your speed. When you start going up slower, and/or you feel a jerkiness in your pedal stroke, the seat is too high. But, if you are sliding back on climbs, the seat may be a bit too low (or far forward.).
Quoted: 1858 Post(s)
Liked 664 Times
I find higher force is harder on the tendons in front of my knee. To mitigate this, I raise the saddle. For me, I'm not sure any style is aided by a low saddle.
I believe that "spinning" is my core high-performance peddling strategy. So my saddle position must be optimized to spin.
Mashing is a specialized method that I use for hills, rough roads, recovery, etc. It can comfortably be done from the base saddle position. Certain advantages arise from standing (leverage rider weight) and sliding back or dropping heel (engage posterior chain).
I've skirted your core question, but hope there's something useful here.
Bikes: EPX 202 Road Bike; Fuji Ace Road Bike
I set my spin bike to the very same setup as my road bike. So to me it makes no difference. The mechanics is the same on both
A properly set saddle height allows both because one uses both techniques on road rides, lots of well documented fitting systems out there to calc your ballpark/home fit. Special event positioning like time trialing or hill climbs can favor F/R bias and a plethora of other adaptations that make little sense for general road riding. Find an experienced fitter in your area and a good coach.
-Bandera
