Life expectancy of patch kits?
Bikes: 2012 specialized hard rock, 2014 trek 7.3,2015 trek 1.2
Quoted: 7 Post(s)
Although I always carry a spare tube I also carry patch kits. Park tool ,1 glue-less, and 1 glue kit. They have been kept in my messenger bag and seen temps ranging from 90+ down to below freezing for the last year and a half. The kits are a rather cheap insurance policy for flats. But how long before its time to replace them? I'm guessing after a while the adhesive loses it effectiveness. What's a good rule of thumb?
Quoted: 5787 Post(s)
Liked 2,580 Times
If the "glue" comes in a metal tube, then it's a few years unused, or a few months (up to a year, if you're lucky) once you break the seal.
FB
Chain-L site
FB
Chain-L site
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
You can buy glue separately from patches, too. I try to always carry an unopened tube as well as an opened one. Try the open one first; if it's a dud, open the new one and remember to replace it when you get home.
I buy both glue and patches on eBay. Patches in sheets of 50 or so, usually from China. I use a lot of patches, and the Chinese ones are fine.
I agree it's a good idea to carry glue less patches as well, but I only use them as a last resort. They doubt last long and are hard to replace when they go bad.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 14 Post(s)
Liked 13 Times
I've experienced quite a bit of variability in how long the sealed tubes last. Some many years and others much less. The tubes are solid uninterrupted aluminum except for the flat end where they're filled and then folded to seal. I imagine the variability arises in the quality of the seal in the folded end.
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
I've found unopened tubes dried out occasionally. I buy additional tubes of cement as needed. For home use I buy an 8 oz can from the auto parts store.
Really Old Senior Member
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Glueless patches stored in my bag become useless after a a few months or a year at most. Our high humidity and heavy rain kills them. On a tube they start to fail after a year. I'll carry them for convenience but you can't depend on them.
Tubes of glue once opened dry up fast enough that you might as well use them up once opened and only carry unopened tubes on the bike. Sure it's OK for awhile but I'll forget about it if I go a few months without a flat, then when you need it it's dry.
Bikes: 90's Bianchi Premio, Raleigh-framed fixed gear, Trek 3500, Centurion hybrid, Dunelt 3-spd, Trek 800
Quoted: 2167 Post(s)
I'm still using patches (the kind that require vulcanizing solvent) from a kit that's 20 years old. As long as they still have the foil on one side and cellophane on the other sealing out air, they may last a lifetime and beyond. It's the tubes of solvent that don't last long enough.
Quoted: 4806 Post(s)
Liked 3,928 Times
Life expectancy of my patch kits? Months. Then it's no more patches and an empty tube of glue. Life expectancy of my tubes? 5 patches is norm.
Ben
Ben
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I still use Rema patches that I purchased in the late 1970's and have no concerns about their performance. As long as your glue is compatible and not dried out, there should be no issue.
This helps a lot.
This helps a lot.
Bikes: RitcheyAscent, FisherMontare
I bought a can of Slime glue and poured some into an old nail polish bottle my wife gave me. (I cleaned the bottle w/acetone, BTW.) She has polishes that have lasted years w/o drying out, and it works the same for the glue. The applicator brush is just right for patching. When closed for a while (e.g. months between punctures) the cap gets stuck on, but the design of the cap solves this, too. (It's tall & easy to grip) Apparently, nail polish does the same thing. I often wondered why those caps were so tall..
On rides, I use peel&stick patches as a temporary repair until I get back home. I keep 'em in an old 35mm film can in my kit.
