Help me not hate tubulars!
#126
Quoted: 1946 Post(s)
Liked 2,004 Times
I just got a can of Mastic after using nothing but Continental for 9 years. I can't tell the difference but the price of a can of Mastic is so much less than all those tubes. What we is interesting, is the directions provided with each product. Vitoria only asks for two coats on the rim and one on the tire. Continental basically has you permanently bonding the tire to the rim.
#127
Quoted: 767 Post(s)
Liked 1,898 Times
Maybe it was discussed in detail here and I missed it, but what is the actual weight savings of a good tubular setup vs a good clincher setup.
Let's say two wheelsets, same freewheel hubs, same spoke/nipple type, one with Mavic Open Pro clinchers, the other with Mavic Open Pro tubulars (or any similar comparison), both with light, supple, high-end tires - how much lighter is the tubular setup?
#128
Quoted: 3464 Post(s)
Liked 2,827 Times
#129
Liked 2,827 Times
Likes For repechage:
#130
“Senior” Member
I have used conti glue but lately Vittoria. I also bought a bunch conti glue when performance went belly up. I now follow the 2 coats on rim and one on tire no matter which glue I use. I found with the extra coats I always had glue (after 100s of miles) squeeze out as little rubber cement noogies. Did not like that look.
#131
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Comparing Challenge's Paris-Roubaix variants, 285g for the clincher version, 330g for tubular. Figuring that a latex tube would be about 75g, you are still coming out 30g ahead with the tubular. The tire I wish I could go back in time and try was the Clement Campionato del Mondo, which was fat but only 290g altogether. So you pretty much get the tube for free compared to the Challenge Paris-Roubaix clincher!
RUSA #7498
Originally Posted by noglider
#132
Mavic specs a weight of 435g for the clincher Open Pro, 360g for the tubular Open Pro, so I get a difference of 75g each in this case. Lighter tubular rims would not be hard to find, at that...
Mavic rims always always weigh just a lot more than spec. Not unusual to see weights more than 100 above spec. Weighing tires is a waste of time, nothing you can do about it. Rims, well, you can at least avoid Mavic rims over 500g. Or just avoid Mavic. Who owns the company now? Are they going to continue? A 360 gram rim will just plain feel light, a Mavic will not.
#133
Liked 2,563 Times
Del Mondos never weighed as little as catalog spec. Always over 300 and 330 could happen. Just weighed a very well worn Challenge P-R. Missing tread weight probably much more than weight of glue residue. 346grams. Weighed a well worn clincher P-R and got 310grams.
Always appreciate your contributions, @63rickert.
#134
Quoted: 3011 Post(s)
Liked 3,786 Times
You won't find a lighter rim than a tubular. Just a fact of the closed-wall structure, no matter the brand.
Likes For iab:
#135
Quoted: 1635 Post(s)
Liked 823 Times
Want a good lightweight C&V tubular rimset that is still quite durable, try out Mavic's GL 330s.
They were a staple in the race scene for non-time trial events. You go over to Mavic's GEL 280's for those events.
The 330's generally came in close to their quoted 330 gram per rim weight +/- 10 grams.
#136
Quoted: 767 Post(s)
Liked 1,898 Times
I may do a winter wheel build project. It may involve tubulars. This thread is very helpful.
Ride what you like.
#137
Quoted: 331 Post(s)
Liked 332 Times
Tub pressure
"It's about what Scott was saying: it's the satisfaction of doing it the old way — of re-living a former age of cycling."
I apologise, it was Scott who you were quoting regards BITD. My point was clinchers have as much tradition as tubs - they just don't have, and never did have, the performance of a tub.
My 4 best bikes have tubulars and they all 1970s. It would be weird to change them to clinchers but I don't do many miles on them any more.
I do about 7 to 8 thousand miles a year and I just couldn't manage the cost using tubs. My final trip on tubs cost me 300 dollars as I punctured both my front and back. Clinchers would have reduced that cost to a dime.
Admittedly I no longer have to traverse a city center wherein there are all sorts of tub unfriendly debris on the road but I don't try and average 25 mph anymore so for me the low performing clincher makes more sense all round.
Having said that for my Colnago Supers and Eddie Merckx, what modern sealant do you recommend for a tub, how do you get it past the valve and will the sealant hold 120 psi?
Take a close look at your valve. You will see that it is made in two pieces. Two piece valves have been around at least since the 1990s and are now almost the only kind. Find the two small wrench flats. Remove the valve core with a pair of pliers, a 4 inch adjustable wrench, a dedicated valve core tool, or sometimes it can be done with your fingers. It's a big opening. You can figure how to get the sealant in.
Panaracer Smart Seal. Orange Seal. Orange Seal Endurance. It is now cold outside. Sealant will not fix your tire while riding below 50 degrees F. Bring it inside and pump it up. In warm weather you could flat and never know it. Sealant does not last forever, it will dry out. Lasts longer inside a tube, could last a year, do not plan on more than 6 months. For bikes that spend lots of time on display and not many miles ridden, wait until you flat before using sealant.
Of course sealant holds pressure. 120 psi could be why you are flatting. If you are a large rider and need that much air in a skinny tire, replace with a wider tire. Excessive pressure was always a reason for repetitive flats. Rock hard tire slamming into sharp objects punctures more readily than a tire that flows over.
Shake well before using. 1 ounce does a skinny. Two ounces does a CX tire. One and a half ounces for 28mm tires.
I have use numerous tubs with one piece valves but shall seek out the two piece ones for the good reasons you have pointed out.
#138
Yeah, I've got a spare unworn Open Pro downstairs that weighs 10g over spec. The extrusion die must have been pretty fresh at the time!
#139
Quoted: 1163 Post(s)
Liked 441 Times
I would not want to put sealant in my tubulars. A couple of my tubular riding friends have had very good luck running Continental Sprinters (not the Gatorskin version), going almost 2 years on a set of tires with no flats at all for one person and only one flat for the other person.
110 psi is maybe more psi than you need for clinchers or tubulars on ordinary roads. I’ve come to really enjoy the ride I get with my 25mm open tubulars on my Velocity A23 wheels running like 82psi front & 88 or 90 psi rear.
#140
I can't recommend a pressure. To make a first guess would need to know how much you and bike weigh and which tire you have. And how wide it is if it is not one where I'm real sure what current production is like.
Best and almost only place to find a pressure chart that means anything is the Berto pressure chart. Google that. Everyone has an opinion about that chart. There is plenty of information for how the data was compiled and why he took the readings he did. Basically if you want to argue with the chart you are arguing with the engineers who designed your tires.
So first step is measure your tires with a caliper. Size printed on sidewall is unlikely to mean much. Always remember your pressure gauge is not that accurate. Approximations are more than good enough. And seat of pants is a good enough reason to depart from the chart.
I can tell you that the chart has never directed me to an unworkable value. I can tell you many pros are riding at less pressure than given in chart. Some things I don't know, such as how pros can sprint on so little air. In principle I can understand why CX tires are inflated so low but cannot myself ride a CX bike with 20psi. For myself do not wish to ever again to inflate so high as 100psi. If there were some classic 80s/90s bike that for some reason had my name on it imaginably it would be skinnies and that much pressure, in most circumstances would avoid that.
Likes For 63rickert:
#141
Liked 2,004 Times
At 160 lbs., I can ride hard, fast, and careless with tubular 25s at 90psi without flatting on a rough mixed surface course. When I did the same course in a similarly reckless fashion using 25mm clinchers at 90psi, I pinch flatted. I am safer at 100 with clinchers. (The tires in this experience were Gatorskins and Sprinter Gatorskins--my go-to mixed surface event tire.)
#142
Quoted: 457 Post(s)
Liked 462 Times
Bicycle tire pressure calculator
For me at 165 pounds ready to ride with a 20 pound bike and 25c tires it says 62 PSI up front and 98 in the rear, and it does work quite well! I have upped the front to 70-75 though to get more pinch flat protection. One thing that is interesting is that with 62 and 98 I have the same sized contact patch for both tires. I live on a gravel road, so when I ride from home the tires get light colored dust on them, and then I get on pavement and ride in a straight line for a mile plus which wears the dust off the tires and the front and rear have the same sized clean strip down the center of the tire when I do this.
#143
Liked 2,563 Times
^ For what it's worth, that calculator is built from the Frank Berto charts referenced above. My suggestion would be not to use the 40%/60% setting unless you ride an upright bike in a flat city. 45%/55% puts a bit more of the air in front to avoid pinch flats and wallowing, and your butt may appreciate having only 89 psi in the back.
Likes For ThermionicScott:
#144
Quoted: 1854 Post(s)
Liked 661 Times
Jobst Brandt believed tires used in his California and Colorado mountain riding needed significantly higher pressure than the Berto chart, to maintain shape and rim protection on fast corners that may be bumpy.
#145
Liked 661 Times
#146
Quoted: 331 Post(s)
Liked 332 Times
I would consider a 85 psi tire as flat. Me and my bikes are over 200lbs. BITD when I was 40 lbs lighter the tires were narrower but just as hard. The calculators above seem to agree with my experience.
In my experience a pinch flat is almost impossible on a soft road tub but on a clincher an almost certainty.
The amount of extra power you need to put into the cranks as you pass 20 mph on 80 to 90 psi 23-25 mm Continentals 4 Seasons becomes blatantly obvious on your legs after less than a 100 yards.
In my experience 100 plus psi tires puncture much less (leaving aside pinch flats) than a soft tire - especially in the rain. It was once explained to me it was simply coz less area of rubber is in contact with possible debris on the road surface.
My dirt bike riding is limited to 35 - 38 mm tires which is IMHO completely different.
Having said that I'm very grateful for people sharing their experiences and I'm inspired enough to attempt a few changes as to how I approach tubular riding and maintainence.
So many thanks.
So many thanks.
#147
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
Will this help you?
Tubular to me...
Tubular to me...
#148
Quoted: 331 Post(s)
Liked 332 Times
#149
Liked 2,563 Times
It's likely that my road bikes with me and my gear aren't exactly 45/55, but it works so well on my bikes, I can't think of a better arrangement. My hands and wrists are plenty comfortable, and I have yet to get a pinch flat anywhere.
But also to your point, the Berto stuff probably isn't appropriate for tubulars, since they don't have the same constraints.
#150
Liked 661 Times
That's the thing -- I'm sympathetic to both Berto's and Brandt's viewpoints, so I tend to use and recommend something in between. Even if you accurately measure a 40/60 or 35/65 weight distribution on your bike, that leaves the front pretty low if you ever have to brake hard while descending a steep road.
Bottom line, I conclude it doesn't matter very much. I tend to use 45/55, because it gives a harder front tire for better braking control. Back in college days I made the tires equal, and I liked that, too. And when I've tried it with 60/40, it also doesn't seem much different.
Getting my saddle setback to a comfy point is a LOT more important!
Likes For Road Fan:
