SRAM PC-1130 10 SPEED CHAIN - other ideas?
i run my fat Bike 1x11 using this type of chain
need to replace chain due to stretch
would any other chain similar to this SRAM PC-1130 10 SPEED CHAIN
would you recommend for my bike? or should just keep it all same still?
Quoted: 5797 Post(s)
Liked 2,615 Times
ANY 11s chain will be fine.
I try to choose from the middle of the range for any brand.
The bottom end chain is usually made to meet a price point, and better chains are usually made of better materials, ie. harder pins. Once you get to mid range, the "improvements" tend to be mostly cosmetic, ie. nicer plating, or weight saving, ie. holes punched in outer plates.
FB
Chain-L site
FB
Chain-L site
Quoted: 1438 Post(s)
Liked 1,092 Times
I have had good results with the SRAM PC-xxx series, but I will use any chain which comes with a master link, that is, not Shimano.
would i be ok by putting a SRAM PC1170 11SPD CHAIN vs the PC 1130 Sram, work the same
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Sure. Before you buy, consider that SRAM lists all four models, PC-1110, 1130, 1170, and 1190 as having chrome-hardened pins, which are key for long life. Therefore, the money spent on an 1170 would get you a lighter chain with hollow pins and shinier side plates (ooh, ahh), but it wouldn't last any longer than the 1130 you used.
Liked 1,092 Times
I have no problems with using them either but don't want to pay Shimano for the special pin (which is a deficient concept IMO) and throw it away AND pay additional for a master link; the other brands include the master link with the chain.
