Groupset or Wheelset
Quoted: 11 Post(s)
guys,
I am using Allez Sprint, with 105 groupset and a standard wheelset on it.
I want to upgrade either one, groupset or wheelset. If I changing groupset, I will save about 350g in Sram Force 22 from current 105 groupset. If I change wheelset to high profile, the bike will look a lot better for sure, perhaps giving some extra speed as well.
I am thinking to do groupset first because the force 22 is not in production anymore. Very hard to source it but I manage to find it now. The latest sram force axs is just too heavy compare to previous version I am getting.
What do guys think? Should I take groupset or wheelset first based on above situation?
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
For me replacing a groupset is only done when its needed. I would go wheels. It’s nice to have extra set of wheels too.
Quoted: 11 Post(s)
Quoted: 18883 Post(s)
Liked 10,646 Times
Wheels for sure. Force 22 is a step back. You already have a fine group set.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
I'd never, ever, ever change from Shimano to SRAM.
But from which wheelset to which wheelset?
I'd probably change tubes and tires first, then handlebars, then wheels.
Quoted: 20810 Post(s)
Liked 9,456 Times
If you find 105/Shimano in general to be frustrating and want to move to Force because you like the ergonomics more (???), then do it up. If you're doing it primarily for the 350 grams, pass.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
No, I don't think its big.
I consider 105 better than Force, but that is my opinion of course. One pound of weight is something like 451 grams so no 350g is probably 3/4 of a pound, that is not worth all the time, money, effort.
I would consider a really nice wheel set a much better upgrade depending what your riding now.
I also don't like getting rid of components before their life is over. Groupsets are spendy so I wouldn't replace a 105 for say Ultegra or higher unless it was not serviceable any longer.
I would never go to SRAM either....not a fan.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Have you done all the high payoff things yet? Tires, saddle, clothes? Any doodads you want like lights or sensors or power meters?
Genesis 49:16-17
Genesis 49:16-17
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I'd say wheels first.
One plausible reason to upgrade the groupset would be if you are using an older generation 10-speed 105 groupset (5700, 5600, etc.) and believe that you would benefit from having an 11 speed cassette. This might be the case if you run out of gears while climbing or want a tighter cluster for racing.
Quoted: 4717 Post(s)
Liked 1,882 Times
+1
I also wouldn't upgrade from 105 to Ultegra(unless it's Di2). I would upgrade from 105 to Dura-Ace mechanical if money wasn't a concern, but 105 to Ultegra Di2 would be a better upgrade.
What wheelst do you have now, and what wheelset are you considering? What are you hoping to gain with a new wheelset?
Quoted: 2952 Post(s)
Liked 3,106 Times
Morghulis
Road Cycling
1
05-13-17 10:32 AM
relnix
Road Cycling
22
06-17-13 08:28 AM
