IRD sliding dropouts hitting chain
I have a Soma Wolverine 3.0 with the IRD sliding rear dropouts. The screws attaching them to the frame are hitting the chain in the smallest cog. Is it safe to put some lock washers between the screw and frame?
or put a flat washer under the bolt head so it will not stick out on the back side..
washer's thickness = to how much you see sticking out , as in your picture.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Check Soma documentation, I'll wager you're missing some hardware.
Paragon Machine Works sliders for example require both a flat and a locking washer on each slider bolt....in addition to adequate torque (which for them is 25Nm per bolt).
EveryManALion
Singlespeed & Fixed Gear
12
06-30-10 05:12 PM
ConstantinosYEA
Bicycle Mechanics
4
04-01-10 01:55 PM
