I found HI-VIS Polyester T-Shirts
Bikes: Surly LHT 26in 52cm 2008
I found HI-VIS T-Shirts Polyester in lime green and orange at $8.57 XL and $10.95 XL
and I am asking should that help to be seen by car on the street??? and I am looking to
get HI-VIS Cycling Jerseys from Aero Tech designs at $34.99 XXL... and I do like cycling jersey but most cycling jerseys do not fit me! and I like the Coolmax Extreme Poly T-Shirts
at $11.99 in Sand Tan XL from uscav(dot)com
Biketouringhobo
I like the Zoic Mtn zip and non-zip T-Shirts
Biketouringhobo
Sunshine
Quoted: 10965 Post(s)
Liked 7,493 Times
Depending on what you wear now, those may or may not help.
If you are wearing fluorescent shirts right now, the ones you mention probably wont be better.
If you are wearing cammo and black and riding at night without reflectors or lights, then yup, the shirts you mention will be better.
At those prices, its tough to beat if you want to be visible.
Right now I am wearing Terramar Olive green Polyester T-Shirts and Aero Tech Designs Padded Touring shorts and soon Aero Tech Designs Baggy touring shorts and I had to my Stealth Camping spot at 6PM -6:30/7pm and I stop at McD's to take a rest and 7:15 I bike to my Spot and gross 2 railroad tracks
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 523 Times
Studies have shown that the high vis. green is second only to flashing lights. It's a good idea to make yourself highly visible to traffic when on the road.
I can't figure out how you can't see for yourself that neon green would be more visible than olive green. Why do we have to tell you?
It will make easier to spot you from afar in your camp, though.
Anyway, you don't have to pay a lot for basic, good jerseys: Cheap Cycling Jerseys, Clearance Deals, Discounts, Free Shipping
Since you are in San Diego anyway, they have an outlet store at the factory in El Cajon, in an industrial area across from the Chemtronics duck pond, where you save up to an addition 25%:
and US made in Pennsylvania and I am still getting the Coolmax Extreme T-Shirts 12 at $11.99 Sand tan
for SHTF
Rhythm is rhythm
i have a Giro helmet that's high-vis green.
I like it a lot, but not sure it does much from behind when my head is down.
One of my friends put a big triangle reflector hanging from the back of his bike. that was a good idea I thought.
Bikes: Surly Disc Trucker, Trek Madone 4.7
Adventure Cycling Association gives these out for their sponsored tours. They are superbly visible, at least in daylight:
Jogalite Cyclist's Safety Triangle - Lights & Reflective | Adventure Cycling Association
Quoted: 18424 Post(s)
Liked 15,579 Times
I am looking feedback and I only have $70.00 on 9-17-2015 for HI-VIS Cycling Jeserys and I them to get Feedback on the HI-VIS T-Shirts and I am getting Aero Tech Designs HI-VIS Cycling jeserys on 10-3-15 and
10-15-2015 and I can also use the HI-VIS T-****s when Setup and Tear down in the Carnival games
Biketouringhobo
I have one of the Safety triangle and NiteRider LED Flashing Tail light
and I am getting a USB LED Flashing light asap
OP, why do you have TWO threads on the same topic?
Here's some good hi-viz shirts. I've owned and used these myself. The ANSI (meaning actually right color AND flourescent dye used) colors last through many washings. The fabric is tough but doesn't breathe really well. Also the cuffs are a little tight on the long sleeve version. I cut off the cuffs, which then permitted cooling air to blow up sleeves and yet still provide some UV protection.
https://www.alertshirt.com/potmanco.html
https://www.alertshirt.com/poloslmtanco.html
Quoted: 3376 Post(s)
Liked 5,522 Times
If you want some *really* high visibility, both day and night, check this out: BootBarn - Wolverine Men's High Visibility Reflective Long Sleeve Polyester T-shirt
I've been seeing outdoor workers along the roads around here wearing them.
Pocket T-Shirt 'Moisture-Wick' ANSI Compliant
Pocket Long Sleeve 'Moisture-Wick' T-Shirt ANSI Compliant
Aero Tech Designs HI-VIS cycling jersey and not the same and I am not a Fan
of Cycling jerseys but ATD is US Made in PA and on 9-17-15 I $75.00 for HI-VIS
cycling jerseys and I need 4 at $34.99 ea and I can get them in Oct 2015 and
I am always around Homeless People and I am a Advocate and I gone Homeless
by Choice on 11-2008 to get my gear and I stay with a Friend in Riverside, CA
and I do Stealth Camping in Vista, CA and San Diego, CA near Pacific Beach
and since I wear USMC Camo Pants when biking in the winter and ATD padded
Touring Shorts under ATD Baggy Touring Shorts summer and I have been wearing
Olive green and Sand tan and I like to be seen by morons driving Cars etc in
Southern California
Biketouringhobo
Biketouringhobo
Touring
4
08-28-15 03:33 PM
MatCartmill
23
04-20-14 09:03 PM
