rear rack light
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
I can't make out the mounting tab, but you have plenty of options. If it only has one hole, you can install an adapter like this and then you can use the B&M Toplight 4DOr you could just get inventive with some zip ties and basically whatever and as many lights as you want to your basket.
Community guidelines
Liked 6 Times
Planet Bike's BRT-5 comes with a rear-rack mount as well: https://www.bike.com/item/planet-bike...srccode=GPBIKE This is one of the few lights on the market with a legit passive reflector built in, and in the United States you generally must have a reflector to be street-legal at night (don't give the lawyers any easy loopholes if their client hits you). It's reasonably bright for a budget light and pretty reliable.
Dirt Bomb
Quoted: 5476 Post(s)
Liked 288 Times
The possibilities are endless. I make mine out of 1/8" x 3/4" aluminum strap purchases at Home Depot. It's easy to cut, drill, and bend.
cell phone bad picture shows a basket, and so skngy is as good an idea as any.
you make one, is how you find one.
most US battery lights use 2 20mm apart holes vertical,
rear lights from the EU seem to be 2 mount holes 50~60 mm apart horizontal..
that thing in #2 works like an adapter ...
the 1 bolt thru a DIY piece, or a big fender washer, to span the basket wires.
