My first Lejeune...
Bikes: Lots of French, some British and a couple of Italian
Quoted: 247 Post(s)
Liked 130 Times
My first Lejeune...
... and it was a freebie. Right place, right time, I was the first to say "I'll give it a good home", and the owner was delighted that it was going to a collector of sorts.
I thought the leather saddle might be a nice Ideale or french equivalent to a mid level Brooks. I was wrong.
Any Lejeune experts have an idea of what the frame might be? No tubing or other decals...
After I'd taken the seatpost out... It slid out like it had been fitted yesterday
Big rivets
A package tied under the seat?
Package contents!
Big rivets
Package contents!
Likes For MiloFrance:
Quoted: 1136 Post(s)
Liked 650 Times
Nice find. Quintessential 70s velo course. I don't know much about Lejeune models.
Is the crank a swaged SR Silstar? I'm assuming MAFAC Racers for the brakes.
Quoted: 247 Post(s)
Liked 130 Times
Brooks has not been the best at retaining its historical records and so we're relying here on my memory more than any printed evidence; I would estimate that the model was in production from circa 1978 to 1982 - for certain, no later than 1986 ."
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
Great color. Looks to be in excellent condition as well. A bit small for you, isn't it? Anyway, a very nice find!
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Nice. Frame seems to have some nice touches. Hard to see, but the stay ends and fork ends appear to not be domed, which takes a bit more work. No clue as to frame material. I would be inclined to say the frame is better than the components.
Quoted: 3811 Post(s)
Liked 3,337 Times
lug pattern BOCAMA Super Professional with cutout Nr. R1
date appears close to nineteen and seventy-eight
you may be able to view a date marking on the backside of the Juy rear mech...
headset appears Lightrace brand by Gourgaud et Cie
toeclips AFA so straps likely Lapize
the Sakae Ringyo Silstar chainset should have an open date marked on the inner face of the right crankarm
https://www.vintage-trek.com/component_dates.htm#SR
Quoted: 5888 Post(s)
Liked 3,471 Times
Nice find. I have a hard time turning down upper end French bikes when I find them and upper end MTBs. Both--in very different ways--are "classic" bikes as far as I'm concerned.
I worked in two different shops in the 80s that sold French bikes and I always liked their oddities. Finding parts sometimes involves a treasure hunt at least in the States. And--unlike Italian bikes--you can get great gear ratios since French bicycle manufacturers understood the importance of compact cranks long before they became a "thing."
If those are the plastic downtube shifters with a little metal sheath around them I would replace them. Very flexible and annoying to use from my experience with the set I had.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Brooks Pro Select Saddle
I had a NOS/NIB Brooks Professional Select saddle. The box was marked Sturmey Archer. As mentioned, the rails were black enamel and it was date stamped 1979. It had some kind of dull oiled leather treatment.
I sold it a few years ago because after riding Brooks Pros on most of my bikes since 1975, I developed some male problems and had to switch to modern saddles with relieved center sections.
The cheap plastic Simplex Prestige shift levers had a tendency to break even back in the 70's plus they never stayed adjusted. Get rid of them!
The aluminum Criterium levers were much better.
Nice find BTW. What size is the seatpost? That can give you an idea of the tubing. A 26.4mm seatpost would be indicative of better quality tubes. Butted Durifort and Vitus 172 would have used a 26.2mm seatpost in the mid 70's. Could be Durifort/Vitus 888 straight gauge main tubes too.
Pastali was THE BEST rim cement back then. A few years ago I pulled some dead tires of of some old wheels that I'd last glued on in 1979. The Pastali was still tacky enough to safely ride! The new Pastali cement is not the same.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Quoted: 247 Post(s)
Liked 130 Times
Thank you for all that, the hive mind never ceases to amaze me...
The saddle is stamped B79, the hubs are Normandy 35s with a 78 stamp and the Silstar NDS crank has indeed got a 78 on it... No date stamp on the JUY but I think if Sherlock Holmes were on the case, he'd say 1979...
Seatpost is indeed 26.2mm.
Not flashy but careful?
That's a lot of info
Liked 3,337 Times
spokes are Union Frondenberg - "BERG"
dropout adjusters made by ALGI but probably sold as Juy
Bikes: Masi Gran Criterium, Derosa, Ron Cooper, Davidson, Miyata 912, Le Jeune, Klein Rascals, AMP Research B3, B4, B5, PX10,Holdsworth, Schwinn Paramount, Frejus, Erickson, Simoncini SLX, Cecil Walker
Quoted: 54 Post(s)
Liked 115 Times
i have a similar LeJeune and the ride is unique and quite sweet. not sure what it is, but it is always compelling me to choose it. congrats on the find!
