Cheap BMX minivelo
Cheap BMX minivelo
Old 05-08-09, 05:07 PM
atombikes
atombikes's Avatar
Bikes: homebuilt FWD recumbents, Genesis 20" folding bike, 1986 Schwinn Tempo, Cannondale Beast of the East, 70's Peugeot
Cheap BMX minivelo
After studying this for a week or so, I took the plunge and started to build up my homebuilt minivelo from junk bike parts. I started thinking that I wanted to build a bike that could easily be put in a suitcase by using sleeves as referenced in another thread, and I still intend to do that. But I decided I would build it up this way first just to make sure I like the ride before I cut the frame.
Here is where I'm at now. It will be a 52 chainring/16 freewheel single speed bike with front and possibly rear caliper brakes. I figure the less stuff I add to it the easier it will be to pack. I know the handlebars will probably have to be dropped some more.
atombikes is offline
Old 05-08-09, 11:53 PM
Lalato
Lalato's Avatar
Bikes: Dahon Curl i8
Quoted: 40 Post(s)
Liked 10 Times in 6 Posts
I like it.
That's an impressively long seat post. And is that a quick release on the stem?
Lalato is offline
Old 05-09-09, 12:27 AM
caotropheus
caotropheus's Avatar
First of all, lucky little me, I would not need such long seatpost and stem. And this build is giving me ideas!...
Second, a question. Do you consider 451 mm wheels?
Cheers
caotropheus is offline
Old 05-09-09, 05:18 AM
griftereck
Bikes: Grifter BSA 20
you might want to put the saddle as far forward as you'll be more over the cranks then
will be steadier to climb then
have you got a close up of the stem?
did you cut the quill tube from a stem and then clamp a plain tube onto it?
griftereck is offline
Old 05-09-09, 08:03 AM
atombikes
atombikes's Avatar
Originally Posted by Lalato
I like it.
Yes, it is a seatpost clamp and quickrelease.
Old 05-09-09, 08:04 AM
atombikes
atombikes's Avatar
Yes, I did exactly as you said, clamped as scrap seat tube cut from a frame onto a quill that had the stem cut from it, then filed flush. Works beautifully. And allows use of a quick release.
Old 05-09-09, 06:45 PM
rench123
Does the seatpost flex much?
rench123 is offline
Old 05-10-09, 07:16 AM
atombikes
atombikes's Avatar
Not that I have noticed- I have only ridden this bike for a short distance but I have not noticed that seatpost flex would be an issue. The wheelbase seems a bit short but nothing insurmountable.
The way I see it, this seatpost is no longer than a Bike Friday and some folders?
The wheelbase could stand to be a bit longer, that would open up the "cockpit" for easier standing sprints and hillclimbing, but again, it's usable as-is.
Old 05-10-09, 11:46 AM
rench123
i was thinking of the cockpit as well. the top tube seems too short for someone with legs long enough to justify that seatpost. of course its a scrapbike project, so understandably you use what you lay your hands on. please update us on how it goes!
rench123 is offline
Old 05-19-09, 08:35 AM
atombikes
atombikes's Avatar
updated pics
I added chain, front brake, and am now able to take this bike on short rides. I think this will be quite a nice little bike for short trips. It took a short while to get used to, but nowhere near some other bikes (like some recumbents).
I am still waiting for the chain tugs to arrive in the mail. I used a cheap v-brake lever for the front brake, I was able to expand the plastic clamp enough to fit over the larger diameter handlebars. I will add the rear brake later for safety. The foam grips are not permanent, eventually if/when I decide this one is a keeper I will strip it all down, remove the decals, clean everything up and paint the currently painted parts. I think I will leave the chrome as-is since it is so durable.
There's alot to like about this bike- low step over height, extreme portability, very nimble handling, low weight (for what it is).
Old 10-14-14, 02:59 AM
alecw35
Bikes: Many
cool bike. Ive modified some kids bikes, and rode them.
alecw35 is offline
Old 10-14-14, 04:06 AM
marxmini
very nice build. i have been toying with the idea of building a formula 1 BMX too. this diamondback BMX will be the guide.
File Type: jpg
marxmini is offline
Old 10-14-14, 09:52 AM
DVC45
DVC45's Avatar
Quoted: 20 Post(s)
Liked 13 Times in 8 Posts
Nice build!
I've been hunting Craigslist for a 24" tire BMX for a good price for the same project build. No luck so far.
DVC45 is offline
Old 10-14-14, 10:04 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Put a straight edge, on that seat post.. so you are able to compare it as it bends a little bit at a time.
to plan replacing it , before its too bent.
Is that one using chromoly steel ?
fietsbob is offline
Old 10-15-14, 06:21 AM
atombikes
atombikes's Avatar
Hey, that's my bike! haha. Well, it WAS my bike. This thread is 5 years old, and many things have changed during that time.
As I recall, the bike's handling was very nimble. It was simple, relatively lightweight, and fun to throw around.
My plan was to keep the frame intact, but braze in a second top tube and second set of seat stays along with a seat tube extension to stiffen the seat area. Similar to how some F1 bmx bikes were designed. In the end, I disassembled the bike and stored the frame and other parts for years, only to have recycled them about a month or two ago.
Here's what I like about the concept: compact frame, bottom bracket in "correct location" for 20"wheelset, if you get a bmx frame with a long enough top tube (~21") the bike is OK for adult size riders.
The challenges: the seatpost (as already discussed), need a riser for the handlebars, rear dropout spacing not correct for geared wheel.
I say if you can find a geared 20" mountain bike with a 21" or longer top tube, you might have something. Similar to the F1 bmx bikes that marxmini is using.
