Don't know which to go for???
Hi I have the option of an older 2015 brand new Jamis xenith comp. Its a 105 groupset but a FC-RS500 crankset with 105 breaks and carbon frame. For the same price I can get a 2018 Giant contend sl 1 disc. It has a full 105 groupset with disc breaks but aluminum frame. What would you suggest?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Jamis.
Is it for use as a road bike with a more upright position and narrower and higher pressure tires or for dirt and off-road hilly back country mountain biking with knobbies and lower gears?
Looking for best option for all around riding. I am new to road biking but would guess i would change the jamis tires from a 23 to 25mm
The '15 Jamis has a pretty tight cassette, only going to 25T but the compact crank is normal even by '19 standards. You could probably put on a wider range cassette for some lower gears but you'd have to add some chain and possibly a larger capacity derailleur.
Quoted: 276 Post(s)
Liked 6 Times
Should go without saying but ride both. The Giant is more relaxed and upright geometry. Giant has hydraulic discs that are cable actuated. I've never used those brakes so I dont know how they perform vs full hydraulic but I like the mechanical shimano levers much more then the hydraulic levers. I think Giants house wheels are probably better then Alex on the Jamis. The rest of the finishing parts are probably a wash. Aluminum has come a long way and Giant makes nice frames.
Quoted: 2432 Post(s)
Liked 638 Times
I would get the Jamis. I like discs but not the hideous Giant Conduct's, and I like a racing geometry. I like snappy, sharp handling bikes. For a race bike the Jamis doesn't have a real short stack like race bikes used to, it would be more than comfortable enough for me. Probably weighs a couple of pounds less as well.
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 28 Times
Test ride both bikes, get the one that you like to ride.
Quoted: 276 Post(s)
Liked 6 Times
I would agree between the two. But for the record, the listed weight on that Jamis is the same as the Fuji Roubaix I just got with Tiagra for about $765 new and the Fuji has more traditional race geometry. The Fuji is aluminum but sub 1100 gram frame. Most of the new Tiagra parts are very close in weight to 105 . The big difference is crank weight but neither bike has the series crank . The oval/praxis crank on the Fuji weighs less then 105 cranks . I'd imagine the non series Shimano cranks on the Jamis are a bit heavy on top of being ugly . That's the one real negative on that bike for me aesthetically but an easy upgrade
Bikes: 2019 Supersix Evo, 2002 Trek 2000
Quoted: 273 Post(s)
Liked 45 Times
Both appear to come with pretty basic wheels, but, all else being equal, I'd go with the Jamis.
brett.naylor
2
10-06-15 08:24 AM
HawkeyeBike
Road Cycling
25
02-18-15 12:30 PM
