Dura Ace 7410 crankset and BB options
Quoted: 2337 Post(s)
Liked 2,819 Times
As usual, I get a new to me bike and drive my self crazy with parts and options for my vision on how to build it.
I am looking at 7410 cranks, which as I understand take a 103 spindle length be caused of the low Q factor.
Has any one use other BB alternatives in 103 like the IRD or SKF?
or gone ahead and used a 107 length.
this is going on an 84 team Miyata. it has 7200 EX front and rear derailers and don't plan on changing those out.. The only reason I am changing the crankout is that the current one Dura Ace 7110 is 165 and I just can't make that size work and finding a replacement is basically impossible
thanks
thanks
Keener splendor
Are you looking for that bottom bracket or just information on an alternative?
I have a spare 7410 English thread bb that I don't need. PM me, if this is what you are after.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Do you have a "newer" Campy Record or Chorus 102 to test the crank on? Just to see if it doesn't bottom out on the cups even before trying in the frame?
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
The correct DA 103mm bottom bracket in the correct thread (timmyT's?) is your best bet.
Token and IRD both sell a 103mm BB, lowest cost for them seems to be Amazon/eBay.
However, a 7400/01/02 crankset will probably be less expensive and easier to find a bottom bracket for. And it will visually mate better with 7200 stuff.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I haven't thought about it in years, but I first bought a Dura Ace 7410 crankset in 1996 and I could swear I paired it with a 107mm BB. If I'm correct it is the only BB it has ever known.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
The aero-inspired Dura-Ace (7???) AX crankset did indeed use a 108mm bottom bracket spindle, as did the later boutique Sante 7000 crankset.
107mm worked perfectly with those for me, but for the 7410 model it should be 103mm with JIS taper.
Tange also has offered a 103mm JIS bottom bracket known to be of very high quality, but a genuine 7410 bottom bracket isn't very hard to find these days.
Few things annoy me more than a too-long bottom bracket spindle, which tends to force an earlier shift off of the large chainring to avoid excessive chainline angle.
Crappy bikes made for beginners used to consistently come with long bottom bracket spindles, intended to center the freewheel with the small chainring's chainline.
Bikes: colnago titanio oval master, pinarello treviso es, centurion prestige, tomac ti 26er, lemond buenos aires, mbk 753, vitus 992 and zx1, rocky mountain hammer disc,bd century titanium, specialized venge expert
Quoted: 130 Post(s)
Liked 39 Times
Merlin has a miche 102 jis bottom bracket for dirt cheap right now...also a titanium Italian threaded miche version for around $30.
Bikes: Rossin Ghibli, Gios Compact Pro
I also have the DA 7410 crank. Looks like the spindle on the BB-7410 is 103 mm JIS low profile. I ordered OMNI Racer Square Taper Cromo Steel Bottom Bracket JIS 2°: 70x103mm- ITALIAN (for my Gios frame) from e-bay. Hopefully I can use standard JIS instead of JIS low profile. Not sure how it will fit in the crank or affect the chain line.
Don't think Campy Chorus 102 mm BB is an option as it's ISO.
Liked 2,819 Times
also @TimmyT has a 7410 BB he might part with
Keener splendor
My understanding is that 7410 is JIS. I think low profile more refers to the crank Q factor. VeloBase.com - Component: Shimano BB-7410, Dura Ace 7410
Quoted: 378 Post(s)
Liked 1,409 Times
Liked 1,295 Times
"Low profile" isn't about Q-factor (pedal stance) at all. It refers to the "hub" of the crankarm having been moved (offset) inward, allowing use with a much shorter bottom bracket spindle, thus saving weight and increasing stiffness while improving clearance to the rider's shoe and ankle.
I hope this is helpful.
