Speedplay Frog grease port
Bikes: Dawes Lightning DLX, 1988 Klein Performance, 1991 Peugeot Safari, 1985 Raleigh Alyeska, Carrera Phantom, 1973 Raleigh Record
Quoted: 282 Post(s)
Liked 129 Times
Does anyone happen to know what size screw is used in the grease ports on Speedplay Frog pedals? I've been meaning to replace one with a stripped head.
Incidentally, I have two pairs of the pedals, and one pair has screws with hex sockets, but the other has Phillips-head screws. The screws seem to be the same, otherwise. The stripped head is the socket-head-type.
Quoted: 2026 Post(s)
Liked 1,096 Times
I believe they are M3 bolts but a call to Speedplay should get you the exact size and probably free replacements. I had several pairs of Frogs over the years and the grease port screws came in both Phillips and hex types so that is normal.
Likes For HillRider:
Quoted: 303 Post(s)
Liked 136 Times
Just checked mine, the phillips flathead screw in the pedal on an eyeball check seems smaller than an M3
screw and indeed a genuine M3x0.5M screw does not thread into the pedal. I don't have any smaller taps than
M3 coarse/fine but they do look larger as well but suggest that the pedal screw is close to 0.5mm thread,
but without a lot of magnification distinguishing between 0.45mm and 0.5mm thread is hard and probably
irrelevant to the short pedal screw. I would go with 2.5M screw size, but IME calling Speedplay is best
bet. Finding a 2.5M screw would be hard but McMaster has them in 2.5M and 2.6M.
https://www.mcmaster.com/screws (scroll down in thread size box)
Quoted: 282 Post(s)
Liked 129 Times
I'm pretty sure we've got some M2.5 screws at work. I'll have to compare.
In any case, I did contact Speedplay. They didn't tell me what kind of screws they are, but they dropped a replacement screw in the mail. I haven't received it yet, but I don't expect any problems.
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
Random guess.. but probably (?) the same used in their road pedals:
https://www.excelsports.com/main.asp...ajor=5&minor=6
Quoted: 282 Post(s)
Liked 129 Times
The screws are on the left in this picture:
Screws on the left
Screws on the bottom
Quoted: 282 Post(s)
Liked 129 Times
I needed one screw; SpeedPlay sent me two. I think they arrived on Tuesday. It looks like they're M2.5x5mm flat-head stainless screws.
Lotus907efi
Bicycle Mechanics
4
05-20-19 05:42 AM
ovoleg
Road Cycling
10
04-17-13 08:29 PM
