How to determine bike frame metal from photos
Old 04-29-22, 10:22 PM
Cole Henrich
I知 considering buying a used bike and I want to know whether the frame is aluminum or steel; The seller does not know, so I have to guess by photographs. I知 wondering if there are some telltale signs that one could see in a photograph. Unfortunately, I as a new user cannot post photos of the bike (which would be very useful).
Cole Henrich is offline
Old 04-29-22, 10:28 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times in 7,209 Posts
...can you get a response if you ask the seller to stick a magnet on the frame ?
Otherwise, you can get a general idea from the shape and diameter of the frame tubing, between steel and aluminum alloy.
3alarmer is offline
Likes For 3alarmer:
Old 04-29-22, 10:44 PM
DVC45
DVC45's Avatar
Quoted: 20 Post(s)
Liked 13 Times in 8 Posts
Post a pic of the bike here or tell us the make and model. There is a great chance someone will be able to ID the bike and determine what material the frameset is made of.
DVC45 is offline
Cole Henrich
Thanks for your response. Yes, I can ask the seller to do that. If the magnet sticks, it痴 steel, if not, it痴 aluminum, right?
Old 04-29-22, 10:48 PM
Cole Henrich
It痴 a Specialized Allez, which are currently aluminum, but I don稚 know the year of this one and if Specialized ever made steel Allezs. Probably it痴 aluminum.
Old 04-29-22, 10:50 PM
DVC45
DVC45's Avatar
Quoted: 20 Post(s)
Is it lugged with DT shifters? If so, it is probably steel.
DVC45 is offline
Old 04-29-22, 11:00 PM
Cole Henrich
I had to look up those terms, but it is good to know that those are distinguishing elements. It does not appear lugged and does not appear to have downtube shifters. I知 pretty confident now that it痴 aluminum, and I can always ask the seller to do the magnet test. Still, I can apply this knowledge when looking at any bike now. Thanks for all the help, folks.
Likes For Cole Henrich:
Old 04-29-22, 11:12 PM
DVC45
DVC45's Avatar
Quoted: 20 Post(s)
Specialized had introduced steel framed Allez over the years.
2011
https://www.specialized.com/us/en/al...or=35595-23431
2005
https://products.roadbikereview.com/...mo-double.html
Almost always, aluminum frame tubings are bigger that steel tubing.
DVC45 is offline
Old 04-29-22, 11:47 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,932 Times in 2,557 Posts
Yes. General rule of thumb - if the tubes appear to be close to inch diameter - steel, significantly larger, like closer to 1 1/2" - aluminum. There are exceptions both ways. Again, in general, newer steel bikes can have bigger tubes but before 1990 that was rare. Aluminum has been made in old steel diameters in small numbers before 1990.
79pmooney is offline
Old 04-30-22, 11:48 AM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
...steel framed Allez were made and sold by Specialized for many years, prior to the switch to aluminum.
I think this might be one of the last steel Allez
3alarmer is offline
Old 04-30-22, 02:22 PM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
Look at where the tubes join. The welding beads on aluminum bikes look like clothes line. The welding beads on steel framed bikes are much finer.
Retro Grouch is offline
Old 04-30-22, 02:46 PM
Camilo
Quoted: 1109 Post(s)
Liked 1,200 Times in 760 Posts
Just ask the seller to do the magnet.
Camilo is offline
Old 04-30-22, 02:51 PM
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,810 Times in 3,318 Posts
Frame material really shouldn't be much of a concern. What should concern you is that the frame fits you well and that everything works.
Iride01 is offline
Likes For Iride01:
