Show your Trek Multitrack!
Old 10-05-20, 06:48 PM
  #551
Cmichini
Bikes: 1998 Specialized Crossroad Sport Hybrid, 1998 Trek 800 MTB
Quoted: 13 Post(s)
Liked 8 Times in 7 Posts
New 700 Multi Track Project Bike
I just picked this up on Craigslist for about $60.
From what I have found it's a '93?
I wanted to get schooled on working on bicycles so this is my lab rat.
If things work out, I'll use this for commuting my 2-1/2 mile commute (when I go back to the office - TBD), as a back-up and loaner.
The frame is solid (not pretty), pedals and shifts surprisingly smooth, wheels seem solid (tires will last for test rides, etc).
It's got grime, but no rust.
I'll take everything apart, clean it all up, learn how to reinstall & adjust, and replace items that need it.
I'll have to consider the frame. There are lots of chips, but I like the original graphics.
Either manual touch-up (lots of it - unlikely), full media blast/refinish, or mix of blast/refinish & mask/manually clean up the graphics areas.
I'm not technically knowledgeable about bikes, but hope to come out the other end of this having earned a few chops.
I'll post more pictures, details, etc.
Cmichini is offline
Likes For Cmichini:
Old 10-06-20, 11:59 AM
  #552
Powerman
Quoted: 7 Post(s)
Liked 7 Times in 5 Posts
That's the color I wanted when I bought my '93, but they had run out.
Have fun with your rebuild!
Powerman is offline
Old 10-06-20, 02:32 PM
  #553
raava
raava's Avatar
Came to bikeforums for other reasons entirely (lots of great info here as I consider purchasing/fixing up an old road bike) but loving this thread!
I have a 2001 (I think) 700 (year based on the color after some online research - a darker grey to light grey fade). Seems like it's a bit more of a recent model than would be exciting for you all to own, I gather because it has an aluminum vs. steel frame? It also has some really funky Shimano shifter display dials, no idea if those were original. Anyway it's a Frankenstein's Bike of the co-op where I purchased it and then the second co-op that helped me fix it so not worth the picture I'm not yet allowed to post, but I'm enjoying reading about your Multitracks
raava is offline
Likes For raava:
Old 10-07-20, 04:07 AM
  #554
fujifinest
Quoted: 15 Post(s)
Liked 6 Times in 5 Posts
I've been looking for awhile for a Multitrack Trek 750 or 790 lugged bike 19", but I'm not having much luck. So I have widened my search to additionally include 520 and 720 Touring bikes. While I understand the frames are all very similar, the 520 and 620 usually have drop handle bars. So I've been thinking about converting one to upright with new stem and handlebar. Additionally these 520/620 have down tube shifters. I'd like a brake shifter setup on the upright handlebars. I'm looking for good quality part suggestions for brake/shifters, stem and handlebar. Thanks, Nelson
fujifinest is offline
Old 10-07-20, 06:39 AM
  #555
dmark
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times in 142 Posts
The 520/620/720 all have higher spec components than the 750 (more like the rare 790)
Multitrack 750/790 are much like the 520 except for the unicrown fork on the Multitrack. The 620/720 Touring have more prestigious steel eg 531 and the 720 Touring is a rare grail bike with long chainstays for touring.
Last new bike 1991
dmark is offline
Old 10-08-20, 08:05 AM
  #556
mechanicmatt
Hoards Thumbshifters
mechanicmatt's Avatar
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 245 Post(s)
Liked 327 Times in 191 Posts
Originally Posted by wrightstuff
This is the 1992 790 I've been rambling on about. It came almost 100% stock from what I can tell. These images were taken after a good shine up and removing some things off of the frame like fenders, a kickstand, and a rear rack.
I have a few hundred miles on the frame now and have made a large number of component changes including a drop bar conversion. Here are some stats/thoughts that might be useful/interesting to others:
Bike details:
1992 Trek Multitrack 790, 21 inch frame.
Sizing:
I would say the 21 inch frame it is on the large end of fitting well. If I had to guess the 19 inch frame might be on the small end of fitting well. I am 5'9" with about a 30.5" inseam.
Weight:
26lbs as pictured (stock)
Wheel spacing:
Front: 100mm Quick Release
Rear: 135mm Quick Release
Side note: I am using a 10 speed 130mm rear wheel right now on the frame and it seems to be running fine. I may try to have a custom wheelset built around the original spacing of 100/135.
Tire clearance:
With fenders: I would guess max width to be around 35mm with fenders. Go with 32mm to be safe.
Without fenders: I have a pair of semi slick 38mm tires on the bike now with clearance for more (but no clearance for fenders). I will likely attempt to fit a pair of more aggressive ~40mm tires at some point for more heavy duty trails/gravel. I doubt anything more than ~44mm will fit.
Seatpost Diameter:
26.6mm
Ride Quality:
Great
So how does it look now?
mechanicmatt is offline
Old 10-08-20, 08:26 AM
  #557
wrightstuff
Quoted: 8 Post(s)
Liked 12 Times in 5 Posts
Originally Posted by DFPyne
Beautiful bike!
Thank you! It has been a great bike pre and post conversion!
Show some pictures post drop bar conversion.
I have not had the chance to perform a proper "photo shoot" post conversion - Too much time on the bike I guess . I will certainly provide an update with images but it still might be a week or two.
wrightstuff is offline
Old 10-09-20, 11:39 AM
  #558
Powerman
Quoted: 7 Post(s)
1995 700
Found this locally on the cheap. It's steel with a chromoly seat tube. The weight difference is really noticeable from my other all chromoly 700s.
Powerman is offline
Old 10-18-20, 08:12 PM
  #559
DFPyne
Quoted: 12 Post(s)
Liked 7 Times in 3 Posts
Recently on my local craigslist I saw what looked like a Trek 750 that had a colorway I couldn't quite date. It appeared black with white and blue decals. It had the '3 dot' multitrack logo that looks to have been used from 1992 to 1994. More importantly it was lugged which would make it a 1993 at the oldest.
Vintage-Trek has listed for those years:
92, white with red decals
93, lunar to black fade with white decals
94, ice violet to ice indigo fade with white decals
The easy answer would be that it's a 1993 but it really looked solid black. Anybody have any thoughts? Was there an alternate colorway offered in 1992 or 1993 that wasn't in the catalog? I'd post a link to the craigslist listing but it appears like someone already snatched it up....
DFPyne is offline
Old 10-19-20, 07:36 AM
  #560
dmark
Quoted: 184 Post(s)
Originally Posted by dfpyne
recently on my local craigslist i saw what looked like a trek 750 that had a colorway i couldn't quite date. It appeared black with white and blue decals. It had the '3 dot' multitrack logo that looks to have been used from 1992 to 1994. More importantly it was lugged which would make it a 1993 at the oldest.
Vintage-trek has listed for those years:
the easy answer would be that it's a 1993 but it really looked solid black. Anybody have any thoughts? Was there an alternate colorway offered in 1992 or 1993 that wasn't in the catalog? I'd post a link to the craigslist listing but it appears like someone already snatched it up....
1991
Last new bike 1991
dmark is offline
Old 10-19-20, 09:14 AM
  #561
DFPyne
Quoted: 12 Post(s)
Originally Posted by dmark
1991
That was my next guess but was the 3 dot multitrack logo used in 1991 or was that the last year of the mountain logo?
DFPyne is offline
Old 10-19-20, 09:22 AM
  #562
dmark
Quoted: 184 Post(s)
I have a 91 white letters blue shadow on black frame. 3 dots I am not conscious of will have to look at home. Is it a graphic near the word "Multitrack"?
Last new bike 1991
dmark is offline
Old 10-19-20, 09:26 AM
  #563
DFPyne
Quoted: 12 Post(s)
Exactly. From what I can tell from 1990-1992 the multitrack graphic was a mountain and from 1992-1994 the multitrack logo had 'Function Specific Design' to the left of multi and 3 dots between multi and track. I would post side by side images but I am still 2 posts away from being able to post photos. Now 1 post away....
DFPyne is offline
Old 10-19-20, 10:14 AM
  #564
dmark
Quoted: 184 Post(s)
Smile
5 Multitrack's in the garage and that is something I never considered.
Last new bike 1991
dmark is offline
Old 10-19-20, 03:28 PM
  #565
dmark
Quoted: 184 Post(s)
'Function Specific Design' to the left of multi and 3 dots between multi and track on the black 91; white 97 730 in front.
Last new bike 1991
dmark is offline
Old 10-19-20, 03:46 PM
  #566
DFPyne
Quoted: 12 Post(s)
That's the one! My black 1991 750 has the mountain multitrack graphic. I guess they switched mid-year.
I also have that same yellow Blackburn water bottle cage on my 1992 790. Now that I can finally post images I will shortly.
DFPyne is offline
Old 10-19-20, 04:15 PM
  #567
dmark
Quoted: 184 Post(s)
After returning to the garage my black 1990 750 has a silver mountain behind the word Multitrack; no dots or FSD.
The suspense is broken we can all relax.
Last new bike 1991
dmark is offline
Old 10-19-20, 04:27 PM
  #568
DFPyne
Quoted: 12 Post(s)
Recently posted in the introductions forum and am also posting here to shamelessly get my post count up. With everything going on in the world I recently gave into my long lingering urge to get back on a bike for the first time since my youth. After spending some time lurking on this forum and specifically this thread, I decided a trek hybrid is probably the best choice for me. After only about 2 weeks of searching, a 1992 Trek 790 popped up on OfferUp which was a little under an hour away. It wasn’t a crazy bargain, but I feel like I got a reasonable deal considering how long I had to wait and the craziness of the Covid market. I picked it up yesterday and couldn't be happier. The blue is incredible and actually feels comfortable for my 5’6” height, which had been my hurdle up to this point.
The bike seems to be stock. Knowing next to nothing about working on bikes I’m not sure were to start, or if it really even needs major upgrading immediately. I think I’ll start with getting a new seat and a water bottle holder.
I’ll post images once I’m able to.
Finally able to post images.....
I'd like to get brown leather grips but I haven't found any I like.
I also have a more beat-up 1992 790 that I'd like to do a drop bar conversion if I can teach myself how to do it. Recently picked-up a 1991 750 for my fiancé though she's yet to ride it....
DFPyne is offline
Likes For DFPyne:
Old 10-25-20, 02:18 PM
  #569
wrightstuff
Quoted: 8 Post(s)
Here are some images from yesterday's fall color tour - post dropbar conversion.
It is currently a 1x10 setup running a 40t in front with a 11-32 cassette in the back. I plan on continuing to tweak out the build in the coming months/years and will likely end up ultimately running 2x10 with a different wheelset.
Also - I will not always be running aerobars, but I am considering entering into a gravel race next weekend and was giving the race specific setup a try.
Happy riding!!
Likes For wrightstuff:
Old 11-01-20, 02:42 PM
  #570
John Valuk
Quoted: 80 Post(s)
Liked 168 Times in 109 Posts
I am the original owner of this '95 730. It had been mostly hibernating for a long time, but I woke it up a few months ago.
After learning that the original FC-MC12 crank arms were under a voluntary recall from 1997, I replaced them with some used FC-MC16 arms (keeping my original chainrings).
John Valuk is offline
Likes For John Valuk:
Old 11-11-20, 01:36 PM
  #571
fujifinest
Quoted: 15 Post(s)
So over a period of time I have been reading on this forum about Trek Multitrack bikes. I have enjoyed the read a lot. One thing I have not seen is any talk about the Trek 750 using lugged assembly versus welded frames. Is there anybody out there that has ridden both methods of assembly and can comment about the ride quality? Thanks, Nelson
Old 11-17-20, 10:05 PM
  #572
jaxgtr
jaxgtr's Avatar
Quoted: 760 Post(s)
Liked 1,714 Times in 1,002 Posts
I put 8K miles on this thing as a commuter. I eventually sold it to a young kid needing some transportation...
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Originally Posted by AEO
you should learn to embrace change, and mock it's failings every step of the way.
jaxgtr is offline
Old 11-18-20, 06:07 AM
  #573
DorkDisk
Quoted: 576 Post(s)
Liked 1,000 Times in 488 Posts
There are some nice parts on that. Is that a Ti Syncros seatpost?
DorkDisk is offline
Old 11-18-20, 06:29 AM
  #574
jaxgtr
jaxgtr's Avatar
Quoted: 760 Post(s)
Yes it is. The bike shop had it on clearance 12 years ago or so, so I bought it. I got the bike through as a work prize in 2003. In 2008 or 2009, I stripped it to the frame and and start buying parts here and there, mostly on eBay. If I recall correctly, the Shifters and Derailleurs were XT, Brakes\Crank were LX. XT hubs on the Velocity rims, and a 105 12-25 cassette. I live in Florida, so don't have to worry about hills, jagwire housing. It was an awesome ride.
jaxgtr is offline
Old 12-16-20, 05:14 AM
  #575
hokiefyd
hokiefyd's Avatar
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times in 568 Posts
There's a lugged 750 in DC for a good price. I have absolutely no connection to this seller and cannot assist with inspection or purchase, but if you're close by -- it looks like it's worth looking at.
https://washingtondc.craigslist.org/...247752050.html
...and a tig-welded small frame 720 as well:
https://washingtondc.craigslist.org/...247653633.html
hokiefyd is offline
