Road bike as a commuter bike?
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
I almost fell down a few times zigzagging across vehicles in traffic over uneven parts of the road where I'm still too fast to get off the saddle or unable to brake suddenly (because the motorist behind could rear-end me).
I lowered the seat 2 cm below optimal so I can stick one foot out in times like these and that solved the problem. But because I'm also at max setback adjustment, I'm only 1 cm under optimum leg extension so not a big compromise.
Dropper post is also a neat solution....If you can find one for road bikes!
Stuart Black
Stuart Black
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 190 Times
My commuter bike:
The yellow thing kind of happened by accident - next tape job is likely yellow as well.
Looks like a road bike. Fewer gears, I guess, than most road bikes.
One of the reasons I love my "gravel bike" so much is that it's so versatile. Commuting, dirt trails, tarmac... it does it all. Not sure what all the fuss about starting and stopping is, but I ride flats.
Likes For paloaltan:
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Same here. I ride 2015 Norco Search as my commuter, gravel bike, and the occasional amateur cyclocross race. It's essentially a steel frame/carbon fork road bike which was sold as an 'adventure' bike.
Bikes: 2018 Specialized AWOL, 2013 Surly Pacer, 2011 Raleigh One-Way, 1973 Raleigh Super Course, 2020 Surly Big Dummy
Quoted: 30 Post(s)
Liked 30 Times
So to answer your question, a road bike will work perfectly well to get you to and from work as long as you have actual "road" between your origin and destination. If you are going to be on other surfaces, you might consider something else. For me, I have actual paved road 100% between home and the office, so pretty much anything will work. From a cargo bike to a road bike, they all work fine.
I have a 2018 Specialized Allez Elite as my commuter. Currently in the shop now to get a tune up, new tires and fenders. It was originally my do-it-all bike. Since I recently got 2 more bikes it has it's main purpose.
Virgo
hi Phamilton , sarcasm or talking seriously ?
It’s a great commuter, less than 30 lbs with racks, fenders, and lights.
Likes For Phamilton:
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
To answer the question first, I prefer a pure road bike for commuting, have for over a decade. I also use a single speed, but you'd probably call it a road bike also.
Seat height is seat height, and unless you're getting a feet-forward cruiser or kids stunt bike it's the same regardless of bike.
The type of handlebar doesn't make that much difference in the rider's position. If you prefer flat bars, get flat bars. If you want raised up drop bars, you can do that. It's all good.
Many of us like an aero road position because it's faster and more comfortable for us. There are variations. We mostly settle in to what works for us.
Likes For wphamilton:
Gone Biking!
Bikes: Orbea Gain, Lynskey, Redline Conquest Disc, Bike Friday, Cannnondale T2 Tandem.
Quoted: 42 Post(s)
Liked 50 Times
Before I retired I commuted for almost 40 years. My commuting bikes over the years were basically my road bikes with drop bars. I would through on the backpack and take the longer route for more exercise. Or I would take my touring bike with drop bars and fenders and put on panniers to carry stuff. The only time I went to a flat bar bike was in the winter time because I like the feel of control with the flat bars and studded tires. Later in my commuting career I did switch from 3 bolt Look cleats to Shimano 2 bolt cleats. Made more sense at stop lights. But as has been stated before, ride any bike you want and modify it like you need to.
Likes For hsuBM:
Virgo
bOsscO
Quoted: 296 Post(s)
Liked 355 Times
I have traded the above bike for the below bike. I’ll provide any additional relevant feedback to the thread as I commute on it. But only a couple joyrides today, maybe 5 miles total. Somehow, no flats. I was sure I was gonna get a flat. A rock or a snakebite or something. 25mm CAN’T be enough tire for commuting.
Liked 4,218 Times
A 23 mm tire is enough for commuting...been there, done that. It’s not a tire that you can commute on at 50 psi but I wouldn’t commute on any tire short of a 2.1” at 50 psi. I would put at least 100 psi in a 25 mm tire but I also use about 90psi in a 35mm tire. Pinch flats are an indication that you don’t have enough air in the tire.
Stuart Black
Stuart Black
Virgo
Regarding your certainty about my comfort, my arse has no objections so far to a 25mm tire. My arse, being the final authority on comfort. You may feel free to direct your concerns directly to him, but it’s unlikely he’ll care. You probably won’t like him anyway.
Virgo
Dedicated Detritus Dodger
Bikes: Some mighty fine ones at that!
Quoted: 191 Post(s)
Liked 603 Times
Road bike to commute? Yes please!!
I do 150-200 a week on 32mm tires at 75 psi front, 80 psi back. This week with the air quality getting worse on the west coast, I might be taking the car on days with an AQI > 100.
Hopefully the wind will kick up and get that number lower.
Likes For bargo68:
This is most peculiar, as I have it on very good authority that no tire narrower than 32 mm can be used successfully for commuting. Could it be that it’s because you were only riding recreationally on your test rides? A 25 mm tire can be used for hundreds and hundreds of frivolous recreational miles over surfaces of wildly varying quality, but a serious task such as riding a short distance to work should cause it to flat the instant you leave your driveway. Please keep us informed.
[pic here]
[pic here]
But yeah, I've commuted with road bikes a lot and they're fine. One thing to consider is if you plan to ride with a backpack or messenger bag, though -- the forward position can make that more uncomfortable.
Quoted: 896 Post(s)
Liked 2,063 Times
Years ago I became concerned about wear and tear on my road bike as commuter, and convinced my wife I needed a dedicated commuter. I purchased a rigid mtb, threw on slicks and fenders, and it was great. The same week, a friend convinced his wife his mtb commuter was resulting in him arriving home late, so he got a new road bike for commuting.
All parties were happy.
Moral of the story is, no matter what, get another bike. If you must use ass height as a rationale, do it. All's fair.
Likes For downtube42:
