Campy 9 Speed Lockrings - Different ID's?
Bikes: 02 Litespeed Ultimate, 84 & 85 Raleigh Grand Prix, '84 Raleigh Prestige, 85 Raleigh 555 RSL, '20 Raleigh Tamland, 38 Raleigh, 85 Landshark "Raleigh", '84 Marinoni Levi's Raleigh, SB4484, SB7979, Raleigh SSCXWC, 87 Raleigh USA 531 Prototype
Quoted: 202 Post(s)
Liked 147 Times
I am swapping a 9 Speed cassette from one wheel to another, and it appears that there must be multiple lockrings for 9+ Speed Campy hubs? The originating wheel (something other than a Campy produced hub) has a lockring that seems to be 26.0mm OD at the threads, The new wheel has a Record Hub, and seems to want to take a larger lockring (hard to tell with my calipers, but it looks like ~26.8mm. Can someone tell me which lockring I should be looking for?
Thanks!
Thanks!
Quoted: 2026 Post(s)
Liked 1,096 Times
I have lockrings from a Campy Chorus 10-speed rear hub and the threads mike 1.060" or 26.92 (nominally 27 mm) in diameter. That should be the lockring you need for your Record hub too.
If I understand it correctly, there were two versions of Campy 9-speed freehubs. The older one was Campy 8/9-speed compatible and the newer one was 9/10/11-speed compatible. The newer one takes the 27 mm lockring.
Quoted: 202 Post(s)
Liked 147 Times
Awesome! Exactly what I was looking for. Thank you so much for the help!
Quoted: 550 Post(s)
Liked 325 Times
Thanks!
Thanks!
