Unclipping quickly after having to stop very quickly - tips and drills?
Quoted: 401 Post(s)
Hi,
I think this belongs in safety.
I've been riding clipless for 6 months now. I ride the Shimano SPD 520 and 530s pedals as they are easy to clip in and out of. I have no trouble clipping in and out under regular situation such as I know I need to stop in 20 feet.
However, a few times I've had to slam on my brakes to avoid a crash only that's when I just can't unclip in time and fall to the ground. I know I'm panicking but is there a nice tip someone can feed me or a drill to practice? I prefer to clip out with the pedal at 12 o'clock and twist and find its faster than clipping out at 6 o'clock and twisting out.
Quoted: 1638 Post(s)
Liked 741 Times
Don't put yourself in situations where you have to panic stop...
There has been countless situations for me, that if I believe I will have to stop, I unclip ahead of time. Many of those, I don't have to come to a stop and I proceed. Since riding clip less, I haven't ever had to panic stop.
You are doing something wrong having fallen from quick stops clipped in, a few times.
nine mile skid on a ten mile ride
Expired Member
Quoted: 3691 Post(s)
Liked 5,497 Times
I'll bite and answer as if this is a serious question and not more trolling.... I think your first issue is the 12 business. If you unclip at the bottom of the pedal stroke you can bring some leg into it, longer lever and less extreme twisting of the ankle. Also, your foot will be near the ground where you want it when stopping. Otherwise, more time on the bike and you will be more comfortable at slow to no speed and less likely to panic.
Quoted: 401 Post(s)
B) With 5 seconds to stop any competent rider can calmly and confidently come to a well controlled stop with no drama from any speed, 5 seconds is a long time.
-Bandera
Bikes: '93 911 Turbo 3.6
Quoted: 109 Post(s)
I would not call 5 seconds a panic stop. But, to answer your question, the first thing you need to do is adjust the pedal binding tension. Secondly, get out and ride more - the only way you'll become more comfortable and proficient and riding SPDs in, say, traffic, is to get out and ride SPDs in traffic.
Quoted: 401 Post(s)
Seriously, I ride a MUP alot and it doubles as a walking track. Its quite curvy and sometimes I come around a corner at 15+ mph and a kid is there. I can't ride around them so I have to slam on the brakes. I think my estimate of 5 seconds is generous now that I think about it. More like 1 to 2 seconds.
Should I unclip first and then brake?
I've set the tension on the pedals to the bare minimum.
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
Come on you can do better than that! How about stop riding in playgrounds!
Knowing that children have been and are likely to be "around a corner" slow down before the curve and proceed with a well controlled stop/avoid or resume. Never override your sight picture in any circumstances, "slam on the brakes" is not a viable riding technique on or off the MUP.
It's not about clipless pedals, if you "just can't unclip in time and fall to the ground" it's not the hardware at fault.
-Bandera
Quoted: 401 Post(s)
Great. Let me rephrase my question
Thanks for your help. Let me rephrase my question.
Is it even possible to stop suddenly and unclip in 1-2 seconds?
From my questions on going clipless in the Road forum when new to them I was always made to feel as a newbie it was all my own fault I was falling over!
@Bandera. This isn't a well populated bike trail, once every 5 rides I'll get into the situation with a kid/dog/slow-cyclist. If I ride like they around every corner I may as well not ride the trail.
Thanks again.
Thanks again.
Bikes: Trek Madone4.5, Fuji Newest, DaVinci Joint Venture, Pacific Dually, Kuota K Factor Thruster
I agree. I ride on a popular MUP with blind corners and I keep the speed around 10 mph except in the corners where I put on the breaks. Shift to your easiest gear and practice spinning while you enjoy the scenery.
Quoted: 550 Post(s)
Liked 325 Times
This isn't a well populated bike trail once every 5 rides I'll get into the situation with a kid/dog/slow-cyclist. If I ride like they around every corner I may as well not ride the trail.
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
Thanks again.
Thanks again.
Agree with others that if you find yourself in a position to make emergency stops, you are going too fast for the trail. 15 mph going into a blind corner is too fast, especially if you know pedestrians, children or dogs might be in your path.
Quoted: 2952 Post(s)
Liked 3,106 Times
First, you are going too fast for conditions, but that has been covered. Second, yes it is possble to quickly unclip after a quick stop. CX racers do it all the time. If this is a thing you need to do, then practice it.
Quoted: 1186 Post(s)
Liked 289 Times
Just relax. If you come to a stop and you're reasonably balanced you won't instantly fall over. With a little practice you have plenty of time to unclip and put your foot down.
And start riding on the roads...
Randomhead
Liked 3,705 Times
I've found that adrenaline makes it a lot easier to unclip. Unclip while you are panic braking. Practice unclipping. Not much else you can do.
Bikes: Trek 7.2 FX, Co-Motion Supremo
Quoted: 44 Post(s)
Reasons to ride defensively on my local MUP.
Things I saw on Friday on my commute to and from work.
Dog off leash
Dog on clothesline leash
Geese
Deer on shoulder (I tried to follow the three feet rule)
Pedestrians with earbuds
Two adults with a toddler walking three abreast
Skateboarder (on the college side of river)
Dude on bike with six garbage bags full of aluminum cans
Unpredictable people on bikes and walking(mental illness and/or drugs)
Limbs on trail from recent storm
Puddles
Ranger truck on trail with emergency flashers
At least the horses have their own separate trail
At other times of year we have rattle snakes and turkeys.
Dog off leash
Geese
Puddles
Expired Member
Liked 5,497 Times
Probably not what you want to hear but 15 mph around a blind corner on a mup, you deserve to fall! Either tootle along and enjoy the mup or get out on the road. Your pedals have little to do with your problems.
Liked 208 Times
Dog off leash
Geese
Puddles
Dog off leash
Geese
Puddles
he finally realizes I am right behind him and moves over but if he didn't, it was either stop or try to pass on the grassy shoulder, which is now muddy from melted snow.
genec
Quoted: 13658 Post(s)
Liked 4,532 Times
Opps I have to panic stop!
Opps I have to panic change lanes!
You guys sound just like motorists trying to avoid cyclists... and all because... yup you guessed it... you are riding (driving) too fast for the conditions. It is just that simple. Slow down, evaluate the situation, plan ahead, prepare to stop, and above all, maintain awareness of what is happening around you.
If you want unfettered exercise in a safe environment... go to a spin class. (or maybe a velo track) Otherwise, be aware that there are other unpredictable humans around, and act accordingly.
LET'S ROLL
"a few times I've had to slam on my brakes to avoid a crash "
A few times is a lot of times to be slamming on your brakes to avoid a crash.
This is a bigger danger than not being able to unclip in time. You may have
to adjust your speed/riding for the conditions you are in.
Shimano M520 pedals with Nike MTB shoes:
https://www.youtube.com/watch?v=FFyXxrqWbPA&index=58&list=UUHyRS8bRu6zPoymgKaIoDLA
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Surf Bum
Bikes: Lapierre Pulsium 500 FdJ, Ritchey breakaway cyclocross, vintage trek mtb.
Quoted: 13 Post(s)
Liked 5 Times
It happens all the time. But the is no reason one shouldn't be able to come to a complete stop while clipped in and topple over without unclipping and putting a foot down. Even if you have no bike balancing skills at all, the time required for the bike to topple over is longer than the time required to unclip foot and put it out to stop your fall.
Maybe practice? Go on to a grassy field and ride and come to a complete stop, come up off the seat, balance the bike to stay upright, unclip your foot, go forward and put it straight down on the ground so you are still perfectly straight up but just straddling the top tube.
Thirst is stronger than the rules. - Stars and Watercarriers, 1974
Quoted: 4815 Post(s)
Liked 3,945 Times
As gregf83 sats, just relax. Yes, there will be the days when you will fall over. I don't care how good you get. But if you just relax and accept you just made a fool of yourself, rarely does anything more happen than a bruise to the ego. And not tensing up will help a lot in actually unclipping so that falling happens less often.
I've been riding quality toestraps and clips with the straps pulled tight and the old school slotted cleats for decades and still do. Most secure street system for when you never want to unclip at the wrong time (like going downhill at 40+ mph on a fix gear).
Ben
Ben
Dog off leash
Geese
Puddles
Dog off leash
Geese
Puddles
