Show Us Your Campagnolo Tools
Quoted: 787 Post(s)
Liked 522 Times
My collection is pretty modest, though I use most of these pretty regularly. What have you got?
Quoted: 237 Post(s)
Liked 352 Times
These are all I have:
(After taking the picture. I remembered that I also have the Crank-Puller.. maybe I have some more...I have to dig around!
Bianchi Goddess
Quoted: 2942 Post(s)
Liked 2,947 Times
I have the Ingrown toenail tool
Sugar "Kane" Kowalczyk
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 713 Times
One of my memories from working at Euro-Asia Imports was walking past a stack of Campagnolo tool kits nearly as tall as I am. I wonder how many are still there.
Good little article: https://jimlangley.net/wrench/campagnolotoolkit.html
Jeff Wills
Jeff Wills
Old fart
Quoted: 3597 Post(s)
Liked 3,421 Times
My early-80s kit with the plastic liner has a slot for this tool, but instead of holding a tool, it blocked by the recess for the grease tub:
Quoted: 3464 Post(s)
Liked 2,831 Times
I really like those all wood cases.
the switch to plastic happened in the 70's.
The shop for which I worked bought a kit in 1975 and it had the plastic tray.
the questioned tool I think is a handle- maybe for the fixed cup tool?
the business side of that has vice flats and a cheater bar, the other side as I recall has a transverse hole set in the tubular body.
i would have to go to work and verify but that is what I recall.
Quoted: 4722 Post(s)
Liked 3,041 Times
+1. the questioned tool in post #7 is the cheater bar for tightening the retainer the nut onto the fixed cup tool. The fixed cup tool was the 2nd and last Campagnolo tool that I bought. The plating on it was very fragile and started flaking off after the first use. The VAR tool is far superior in all aspects; price, ergonomics, versatility. workmanship, etc.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
I still have my original Paramount toolset with the plastic pouch...its somewhere in the garage, at least I hope so, that's why no pics.
Best, Ben
Best, Ben
Voltaire
Voltaire
Old fart
Liked 3,421 Times
Liked 2,831 Times
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,484 Times
That's the very kit that I used when employed at The Bicycle Center a couple years before Jim! I wondered where it went.
Brent
Old fart
Liked 3,421 Times
Now, I have to wonder when Campagnolo stopped including the tommy-bar with the tool cases. Curiously, the tommy-bar doesn't seem to appear in any of the Campagnolo catalogs and doesn't seem to have a part number.
Liked 2,831 Times
Good question- the plastic insert had a provision for it but also for the small tub of Campagnolo grease.
Fillet-Brazed Member
I'd love their wheel dishing tool, a friend of mine has the VAR version, which seems to be the same.
Compared to the Park Tool WAG-4 they're heavenly to use.
Quoted: 556 Post(s)
Liked 132 Times
I have all that are shown in the first two pics, headset and BB tools, pedal wrench, T handle, crank bolt wrench, and a dishing tool, etc. But when I obtained all of those I don't think this tool was available, so I think it's an 80's tool. But what a lifesaver.
Pedal tool for holding the lower, large nut in place against the outboard cone of the Record pedal while you tighten the small outer nut. Thin walled and offset head. Just a perfect design, as are most of Campagnolo's tools.
Jumped on this about ten years ago when I saw it. I haven't seen many of them.
Quoted: 4521 Post(s)
Liked 6,415 Times
There was one on efbay last month? that went for $60.
I had a pedal that the locknut was so tight it wiped the tab off the washer taking the locknut off since I couldn't hold the cone.
Going to make my own out of a socket with some dremeling and a wrench tacked on the outside.
Quoted: 787 Post(s)
Liked 522 Times
Super Modest
Quoted: 10979 Post(s)
Liked 4,645 Times
NR offset seat post wrench, headset wrench, crank bolt wrench, and the little chainring spanner.
Keep the chain tight!
