ID frame based on lugs?
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
I saw a bike with what must be an old frame repainted satin black. Nice job, too. No head badge. No ID on seat tubes. The lugs were typical long points but with a small window cut into the top. I figure it was likely a major company? For anyone, does this ring any bells? Wish I'd gotten a picture; didn't have my phone.
Quoted: 4206 Post(s)
Liked 3,871 Times
Lugs are generally made by an outside supplier to a bike fabricator. If enough are ordered a "special" feature might be worthwhile. Cut outs in various shapes is a common feature to be played with.
Can you be more specific as to the cut out shape and locations? Do you know the frame's threading? Shots of the lugs, crown, BB shell, seat stay tops and stay ends would all help to eliminate possible brands but without more hints the range is still pretty wide open. Andy
AndrewRStewart
AndrewRStewart
Quoted: 350 Post(s)
Liked 24 Times
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
1) the frame is "old", but no idea how old.
2) the frame uses long point lugs with a small window cut into the top of the lug.
I should think there could well be literally thousands of different frames that meet this criteria. Good luck with your search.
Randomhead
Liked 3,698 Times
Frame ID can take a combination of factors, since builders generally all have the same parts available to them. Seat cluster, crown, lugs, dropouts are the main ones.
