First Time Tour Bike Buying Advice
First Time Tourer
For your size frame I think you might find that the LHT with 26" wheels might handle better and have less problems with toe overlap and wheel flop than the Marrakesh. Toe overlap is a pain at low speed and wheel flop affects higher speeds such as hill descents.
The most important thing is the the bike is the right size and you are comfortable on the bike. For position help have a look at the FAQ's at ....
Touring bikes are about low gears and the sales guy sounds like he doesn't have a clue. If you want to be able to compare different setups then use a gear inch calculator such as ...
For touring I'd be aiming for between 18" to 21". On your budget a 3x9 setup will be fine. You can have just as wider range with a 2x11 but not for your budget.
Aluminium racks will break long before a steel Tubus rack will but so long as you don't try to take the kitchen sink, you should be fine on a short tour like you have planned.
I really want to try out a LHT. They've been recommended almost nonstop, but no one in town carries the Long Haul or the Disc. I could just buy one, but it feels dangerous without riding one first!
Bikes: 1985 Cannondale SR500, 1990 Cannondale ST600, 1993 Cannondale M700
Quoted: 171 Post(s)
Liked 277 Times
https://www.bikeattack.com/jamis-aur...SABEgLkRPD_BwE
You might take a look at the Jamis Aurora Elite.
Reynolds 631
Tires are 35s.
Disc brakes.
Lots of great specs.
Reynolds 631
Tires are 35s.
Disc brakes.
First Time Tourer
I agree that a triple will give you the essentials. Make sure your gearing is low enough first and foremost. Maybe even lower than you'll ever need. With a triple you can get some reasonably high gears too. I love roaring down slight downgrades or long flats with a tailwind. You CAN have both.
The LHT are popular but be comfortable whatever you choose. My first touring bike was a straight gauge Japanese entry level touring bike that fit me perfectly. The entire gearing needed to be changed to a nice granny with half steps with barends. It had no typical braise-ons but never gave me a minutes trouble. It would not have accommodated the tires I think you'll need so a 700mm wheel will be useful for you.
Racks shouldn't be an issue unless your going off road. Get something wide enough to keep everything away from your spokes and low riders are a must. They're more likely to keep you upright especially on dirt roads.
Sounds like you're buying a bike for the trip. Be sure to ride it fully loaded to feel how it handles loaded. There's nothing like unpacking the plane and gearing up your nice new Trek 720 only to find it's way more flexible than the straight gauge frame you were used to when your many miles from home.
Thanks to everyone posting about the low gears. I am keeping that in mind as one of the most important factors.
Quoted: 671 Post(s)
Liked 49 Times
Kona Sutra & Salsa Marrakesh look pretty good IMO esp in re components. Marrakesh looks to have a fairly short stem; easy to swap in a longer and possibly riser stem. One nice thing about buying a frameset & building up is that sometimes they give extra length on the steerer tube (as with Trucker) so one can ride it for a while & then have the tube cut as desired. Marrakesh available in frame only but I don't see steerer tube length listed. Many bike tourists like a highish handlebar position. Relying on a riser stem to get that is sometimes problematic, available ones are mediocre quality & limited angles. With my Disc Trucker I ended up leaving more steerer tube than I had expected but handlebar has fairly deep drop so I'm fairly aero when I want. My Diamondback Haanjo EXP Carbon required a riser stem; height is good but should be 1" more forward.
Sutra & Marrakesh are limited to 40mm wide tires w/fenders. Many folks would find those wide enough for 100's of miles on dirt/gravel but not me. I agree it's a risk to buy a bike sight unseen but perhaps if you found the Salsa a bit too short in reach, the Trucker might fit well (it's known for the long top tube). If you have a current bike that's comfortable you can measure things to get a fairly good idea as to what would fit. Building up a frameset isn't hard, LBS can install the headset & bottom bracket. It can be fun to choose components as desired.
Quoted: 1188 Post(s)
Liked 1,154 Times
I'd love to go this route, but I'm not sure where to start with 90s MTBs, especially since I feel like most won't have disc brakes. I know the rim/disc brake debate is never-ending, but disc brakes sound positive to me in terms of braking on long descents, reliability in weather, and repair.
If you have any thoughts on where to start with MTB, I'd love the advice!
Don't get sucked into the disc brake hype, I currently ride discs, but mostly because I got a set of cheap wheels. Before I got them I rode V brakes and they were just as effective, with the added bonus of not fading when going down big hills slowly. Main thing is to spend the money on decent pads, with replaceable rubbers. Discs work OK when you have good airflow over the discs, but go slowly down a steep hill while heavily loaded and they'll cook.
Hi guys! I have found "authier ferraroli" MTB i think from early 90's steel frame, deore xt... Have pictures but can't post it (new user). What do you suggesting/changes to transform it into descent safe touring bike?
while its great to suggest using an older mtb, one has to be realistic about someone who has little bike knowledge or mechanical knowledge, getting into the used bike thing.
Its hit and miss already, and sure it can work fine, but it also can be a can of worms depending on the bike, the condition etc.
its not a black and white easy answer it all Im saying,and sometimes just getting a new or newish proper touring bike is going to be the best route for lots of people.
Liked 1,154 Times
Or you could buy one of these https://surlybikes.com/bikes/troll Already has everything you need except the racks. Pretty well what I ride now except I've got a Rohloff and ATS speed drive because why not carry 2kg of extra weight. Anyway, apart from the racks all you need to change would be the cranks, to a set with 22-30-40, that will get you some nice low gearing.
Looking at pictures of that Authier it looks like a very nice bike if it's in good condition. Do you have access to a good bike mechanic to look at it? If good it would need servicing, repack the hub bearings, change the bottom bracket to a Shimano UN55 sealed unit, or if you put some octalink 22-30-40 cranks on it, an octaliak BB. In terms of touring the main thing you need to do is change the handlebars to somethiing touring orientated, probably the VO crazy bar, as you could re use the stem and they are nice and wide for gravel work.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4681 Post(s)
Liked 5,799 Times
This may sound odd, but start by chosing your tires. You'll have more issues with tires on a long tour than any other component of your bike. For example, I know of a few people who are going with the Rene Herse (Compass) 26 x 2.2" Rat Trap tires for touring, and buit their bikes around them. I would definitely NOT use those on the trip you're planning, as they have very thin sidewalls and not much tread. I'd sacrifice the ride and fast rolling of those tires for something much beefier, since you'll be on a lot of rough gravel. A 26" tire is often stated as the most easily found emergency repair size. I'd get something wide - 2" minimum, which will give you comfortable ride and good traction on gravel. And make sure you have room for fenders with lots of clearance.
Liked 1,154 Times
What Gugie says about tires is true. For a trip like you mention Marathon Mondial are about as strong as you can get. I like the Extra Terrestrial style 2.5 balloon tires for touring now, they just roll over everything, pavement, gravel, sand. The ETs themselves are a bit flaky quality control wise, I had one chew out in less than 1000 miles due to a molding error. Surly gave me a new one and some swag for my troubles however. Great tires if you could rely on them.Next tires I might try are the Schwalbe Moto-X.
...I've ridden the Salsas that are recommended for this kind of trip (Vaya, Journeyman, and Marrakesh). I liked the steel frame of the Marrakesh, but the aluminum rear rack worried me for such a long trip. I was reassured that they made it extra strong to compensate. It was the only of the three Salsas I rode that has three front gears and is steel. The other two were great bikes but aluminum frames and only two front gears...
Salsa Vaya frame is steel, and has been for 9 years now. Up until last year the base model had a steel fork, now carbon fork is the only offering.
Quoted: 671 Post(s)
Liked 49 Times
I agree, in fact for several years we've seen a trend of touring bicycles allowing wider tires. However I feel some are still limited too much esp with fenders. A bike that allows wide tires can always be fitted with narrower tires if desired. Wider tires can be safer too by eliminating some front-end bounce on bumpy descents.
Liked 5,799 Times
And then of course, different tire models differ greatly, but a lighter wider tire will always be nicer on any rough stuff.
