Show Us Your Vintage Cannondale!
Old 12-15-20, 08:29 PM
  #1201
zachleft
Quoted: 40 Post(s)
Liked 11 Times in 10 Posts
Originally Posted by joejack951 View Post
Cannondales have stiffer chainstays than most steel frames but they will still flex easily enough to accommodate the wider hub. I did the calculation once, as someone had posted some fear-mongering link off the internet suggesting that bad things would happen if the dropouts were not realigned. IIRC, assuming the dropouts were perfectly straight to start (unlikely), they'd sit at ~0.5 degrees after being stretched. If you can eyeball that, you are better than me! As noted already, don't even think twice about it. It will be fine.
I can't let a question go by about going threadless on a vintage frame without commenting, or at least inserting a pic. Below is an SR500 I built up on a budget using some Mavic wheels (early 2000s but Mavic got lucky and made them with a freehub that accepts modern 11 speed cassettes) and Shimano 105 5800. The headset is something I designed allowing threadless stems to be cleanly fitted to threaded forks. These old fat-tubed Cannondales work well for this type of conversion, in my opinion. I left it uncut for this pic but the stem can be 'slammed' down on top of the upper bearing or fitted with up to 50mm of spacers as shown.
I think I'm in love
zachleft is online now
Likes For zachleft:
Old 12-16-20, 10:43 AM
  #1202
joejack951
joejack951's Avatar
Bikes: 2016 Hong Fu FM-079-F, 1984 Trek 660, 2005 Iron Horse Warrior Expert, 2009 Pedal Force CX1, 2016 Islabikes Beinn 20 (son's)
Quoted: 1208 Post(s)
Liked 56 Times in 39 Posts
Originally Posted by zachleft View Post
I think I'm in love
Pop over to this thread if you want to read more about the headset/stem details: https://www.bikeforums.net/classic-v...n-headset.html
joejack951 is offline
Likes For joejack951:
Old 12-29-20, 02:39 PM
  #1203
zachleft
Quoted: 40 Post(s)
Originally Posted by jeffmendoza View Post
Just finished building up, the wheelset was the last piece.
'89 3.0 crit frame, size 58.
Originally an SR400, but the bottom bracket, headset, and stem are the only original parts left.
What set up do you have for cassette and crank? Is your dropout 126mm? I'm looking to buy one of these frames and the stock gearing is kind of limited at 52/42 crank and 13-23 freewheel, but the hub is only 126mm. It looks like you have a solid range of gears there.
Old 12-29-20, 08:16 PM
  #1204
jeffmendoza
Quoted: 8 Post(s)
Shimano 6400 parts. FC-6400 53/39 crank. Hub is the 126mm freehub 7-speed that accepts both uniglide and hyperglide cassettes (FH-6401 I think). Cassette is a new HG-51 8 speed 11-28, but I'm not using the 11, so it's 13-28. I needed a 1mm cassette spacer as well. Also using 8-speed shifters (SL-6401) to match the spacing on the cassette.
39-28 is tough but manageable on the hills I have around here. The capacity is a bit more than the RD can wrap, the chain might sag a tad in small-small, but I don't ride like that of course.
jeffmendoza is offline
Old 12-29-20, 08:56 PM
  #1205
zachleft
Quoted: 40 Post(s)
Thank you! How come you aren't using the 11? You just removed it and put the spacer in it's place..? Sorry I'm a noob
Old 12-29-20, 09:10 PM
  #1206
jeffmendoza
Quoted: 8 Post(s)
Only 7 speeds fit. The freehub body is for 7-speed cassettes.
https://www.sheldonbrown.com/k7.html
https://www.sheldonbrown.com/cribsheet-spacing.html
Likes For jeffmendoza:
Old 01-04-21, 11:34 PM
  #1207
oldtimeyirv
Cannon-dad
oldtimeyirv's Avatar
Bikes: 1988 Cannondale SR 500, 1995 GT Timberline, 2010 Cannondale CAAD 9, early 80s Nishiki Olympic 12 Mixte (wife), 1983 Fuji Monterey (ss frankenbike),
Quoted: 21 Post(s)
Liked 13 Times in 7 Posts
1988 sr500
This bike has been with me a while now. Picked it up at a swap meet in Chicago about 10 years ago. The original wheels were gnarly and it had lots of worn out components. I worked at a bike shop at the time, so I had help making it rideable with some donor parts... It looked appropriate for a broke 20 year old, rampaging around the city.
Finally decided to give it the love it deserves and dress it up. Very sentimental bike to me because of all the adventures. Usually very fast adventures, it doesn't do slow very well.
Still waiting on some parts, but most came off of a CAAD 9 I'm not riding at the minute. Brown bar tape, pedals and a new saddle should make it feel loved 🥰🤣
oldtimeyirv is offline
Likes For oldtimeyirv:
Old 01-13-21, 09:32 PM
  #1208
velojym
velojym's Avatar
Bikes: 2000 Kona Jake the Snake, 2000 Kona Fire Mountain, Montague Fit, Surly LHT, Montague Paratrooper, Cannondale M500, Santana Arriva, Bridgestone 200, Trek 1200
Quoted: 101 Post(s)
Liked 177 Times in 102 Posts
It might be wrong, but it could be oh-so right. Just playing with spare parts and this frame, though I won't do anything irreversible.
Gonna be, at least for a little bit, a 2x1. 53/39 by 16
Sort of a pseudo TT bike, but I'm guessing the geometry will never be perfect for that, other than being a little undersized for me. Just gonna have fun with it.
I also have a trimmer saddle that would look better here. The 2x1 setup is just for kicks, not a lot lighter anyway due to my use of an old derailleur as a tensioner. The single speed tensioner I have doesn't have enough capacity for the 53/39 chainrings. I just wanna ride it and see how it does. If I frickin' love it, I might leave it like that for a while. If not, I'll start to find parts to get it back to something sorta similar to its original configuration, though with a somewhat wider cogset range than it originally sported. Probably stick with the downtube shifters (already have the front one working fine), and if I go back to a fully geared drivetrain, may still keep the bullhorn bar. We'll see. This bike doesn't really fill a 'need', so it's purely experimental. I do kinda take a fancy to the idea of using it to pick up a KOM or three.
velojym is offline
Old 01-15-21, 01:24 PM
  #1209
BluePx10
Bikes: '96 CKC, '91 Batt., '86 Simoncini Cromor, '85 Allez, '78 PX10, '76 Gran Jubile, '73 Arctic, '73 Interclub, '72 TdF, '71 PX10, '70 Mondia SS
Liked 4 Times in 2 Posts
My winter project, finished early. Wanted something that would ride completely different from my steel bikes. This one's a '98 with a parts-bin build. Built to be light and fast, which it is. Got a few rides on it before the snows set in--stiff but not harsh. I like it, but my favorites are the Black Lightnings with Superbe Pro...
BluePx10 is offline
Likes For BluePx10:
Old 01-16-21, 02:42 AM
  #1210
zachleft
Quoted: 40 Post(s)
Originally Posted by flying_rhino View Post
What year is this? Can't tell if it has fat tubes or not. Also what's the best way to strip the paint like this? Did you polish it at all?
Old 01-16-21, 02:24 PM
  #1211
zachleft
Quoted: 40 Post(s)
Originally Posted by dumpsterhuffy View Post
the earth tones on this are just *chefs kiss*
Likes For zachleft:
Old 01-17-21, 10:43 PM
  #1212
sheddle
Bikes: my precious steel boys
Quoted: 407 Post(s)
Liked 520 Times in 311 Posts
in what was possibly the dumbest thing I've done recently, I got a 1986 SR600 from a guy at the homeless shelter next door for 250 (he offered 200 which seemed like a ripoff)
Replacement rims need to go, some of the bearings (particularly the pedals) are in rough shape but the majority of the parts are original.
sheddle is offline
Old 01-19-21, 05:50 AM
  #1213
flying_rhino
Quoted: 29 Post(s)
Liked 5 Times in 3 Posts
Hi zachleft
It's a 90's Criterium frame. I used generic paint stripper and then wet sanded everything, then finished with Mother's aluminum polish. Took me a couple of hours spread over a few winter Sunday's. Final step was putting Bike Lust on it. The frame's been sitting in the garage (gotta get it on Ebay one of these days) and isn't showing signs of outrageous oxidation.
John
flying_rhino is offline
Likes For flying_rhino:
Old 01-19-21, 07:40 AM
  #1214
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 1841 Post(s)
Liked 585 Times in 417 Posts
H400 from the co-op's dumpster, missing hanger and with broken cable guides. It hung indoors for a few years and they finally got rid of it. This would make a nice project for someone who fits it. I won't be hanging onto it but I could not let it go to the dump or recycling.
thumpism is offline
Old 01-19-21, 04:59 PM
  #1215
thumpism
thumpism's Avatar
Some more H400 pix. I assume all the missing stuff is available.
Needs a seat collar and cable guides.
I remember those early stainless hangers with the thin sections sandwiching the frame's dropout.
thumpism is offline
merziac
Classic & Vintage
9
05-21-19 06:20 PM
Standard Issue
Classic & Vintage
8
12-20-17 08:50 AM
Lazyass
Road Cycling
28
06-12-15 01:58 PM
Wiggles_dad
Classic & Vintage
8
02-10-14 09:56 AM
SLPRJP
Classic & Vintage
50
03-16-11 03:29 PM
