My Wife's full titanium Brompton clone
I think a lot of folks are wondering the same thing... by all means please be our first data point.
@Raxel... didn't you mention somewhere that these bikes are sized for smaller people... and that at least 3Sixty or EasyTi (can't remember which one) was planning on making something more standard sized?
@Raxel, Loving your work and thank you kindly for the posts. Before I dive in to all 303 of them, can you let me know what brand cables you are running/ prefer these days. This for a currently stock Ti Brompton. With thanks
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
[QUOTE=BromptonINrio;21000613]it does matter indeed.
Thor was banned for that if i can remember correct./QUOTE]
And here I thought that the blinding purity of his vision was causing so much
distress among those who bore witness,
that their tortured souls could not but cry out for vengeance.
But, I have been wrong before.
Quoted: 105 Post(s)
Liked 38 Times
Quoted: 105 Post(s)
Liked 38 Times
And last year's 3Sixty cro-mo bikes indeed had bit shorter top tube but now they are making large sized ones, which have very slightly longer toptube than UK brompton.
Here's a pic of 'L' sized 3sixty bike (chrome plated version) I took from 3sixty forum.
Likes For Raxel:
Bikes: Brompton Superlight, Cannondale F29 Lefty, Klein Mantra Pro carbon, Softride Powerwing
ZTTO cable
Hi Raxel. That's a gorgeous bike. After your recommendation of ZTTO cables, I'm pondering them for my own Brompton Superlight. Do you think they would play well with the stock drivetrain? Also, can the aluminum segments of the ZTTO cable be individually removed without damaging them so that two colors can be alternated?
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I ran into quality problems with ZTTO and had to drill through some of their segments to be able to use them. TRLEQ is just slightly more expensive, with more consistent quality. The colors can be mixed.
Cool, thank you. I'm not having any luck searching for TRLEQ cables. Where would you recommend I look?
Quoted: 573 Post(s)
Liked 118 Times
Quoted: 840 Post(s)
Liked 336 Times
Awesome, thank you kindly.
That’s amazing. Now do a Tern Eclipse x22!
question: does the material difference affect anything beyond weight and tensile strength? Like does it affect the engineering for the folds and other weak points? And how does titanium ride vs steel, aluminum and carbon?
my nice bike is at home
5.20 kg. / 11.46 lbs. is less than what my wife's purse weighs...
BMC Race Machine / BMC Team Machine / Rossin Record / 80's Pinarello Traviso / Merlin MTB / Raleigh "Folding 20" / Ti-Swift (!)
Erikson w/C&C couplers / Trek's: 2300, 1200, 990 / Jamis 'Sputnik'
will it be too "soft"?
will it be too soft?
I am planing to get one. but I have seem people talking about the ti frame, don't know which brand they are getting tho.
Quoted: 232 Post(s)
Liked 146 Times
>> Yes, since tensile strength is different, "by right" the thickness has to be adjusted accordingly to get the same strength.
That said, a lighter person would probably get away with a lot of this consideration vs a much heavier one.
>> This really has 2 ways to go about it. The hack/experimental way of making the folds similar to the one it was copied from and seeing what happens (or not at all) or proper design guided by the material strength.
weight+strength wise : Alu > Ti > Steel So generally, a Ti part copied from a Alu one can use a bit less material and a Ti part copied from a steel on probably needs a bit more (or a larger diameter )
>> It still depends on the construction of the bike, but generally :
Alu - (based on older 10-6yr ago designs ) feels rigid and solid. Oddly no metallic 'zing' in the handling of high freq road vibrations. I have read claims that modern alu is different with those triple butting and hydro form, but I have not tried one.
Carbon - high freq road vibrations feel "dud"... (Imagine a over damped freq response curve ).
Steel/Ti - They have that same "zing" in the translation of road buzz. Sort of like a tuning fork when tapped (but nicely damped ). So it gives that lively feel that some people describe as 'alive' (wrt the above 2 materials ).
In terms of low freq bigger bumps, I generally find all materials are about the same in that none of them will comply enough to make that big a difference (ie. rider will still feel that bump). This area is better handled by sprung saddles, suspension seatposts, saddle choice, thicker tape, suspension stem, etc. Perhaps there are some exceptions like the GT grade, Topstone, which try to add a little bit of more compliance with unique seat stay designs.
Likes For pinholecam:
Schwinnasaur
While Ti alloys rival steel for strength, its Modulus of Elasticity is about 60% of steel. So it is more flexible for the same size tube. This should allow for more suspension or compliance giving Ti bike a more comfortable ride. I say should because I have never had a Ti bike myself. Ti as a material for bikes seems ideal. Light weight, does not rust, greater comfort. Unfortunately its very expensive and more difficult to weld.
